Cable Routing With Front Mounted Governor...
Site Admin
PostPosted: Wed Jun 18, 2014 6:52 pm    Post subject: Cable Routing With Front Mounted Governor... Reply with quote
At 02:56 PM 6/18/2014 Wednesday, you wrote:
Hi Matt,
How's this working out for you in the long-run? Any issues?
Hi Tim,
It worked out great! The only issue I had was heat from the engine causing some stickige after about 20 hours or so. I replaced the cable and added two sleeves of the firesleeve from FlyBoy Accessories and after 150 more hours never had a problem. I'm not totally convinced that it was heat that caused the cable to go bad. Could have been just manufactured poorly and started to stick for other reasons.
Here's a link to the firesleeves I used:
http://www.flyboyaccessories.com/Fuel-Line-Heat-Rejection-Sleeve-p/2403.htm
Attached are a few pictures of my RV-8 installation with the firesleeves.
Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
 Filesize:  222.95 KB
 Viewed:  2288 Time(s)
 Filesize:  238.22 KB
 Filesize:  254.52 KB
