Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27640 Location: Livermore CA USA
Posted: Wed Jun 18, 2014 6:52 pm Post subject: Cable Routing With Front Mounted Governor... |
At 02:56 PM 6/18/2014 Wednesday, you wrote:
Hi Matt,
How's this working out for you in the long-run? Any issues?
Hi Tim,
It worked out great! The only issue I had was heat from the engine causing some stickige after about 20 hours or so. I replaced the cable and added two sleeves of the firesleeve from FlyBoy Accessories and after 150 more hours never had a problem. I'm not totally convinced that it was heat that caused the cable to go bad. Could have been just manufactured poorly and started to stick for other reasons.
Here's a link to the firesleeves I used:
http://www.flyboyaccessories.com/Fuel-Line-Heat-Rejection-Sleeve-p/2403.htm
Attached are a few pictures of my RV-8 installation with the firesleeves.
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
RV-6 #20916 N360EM "The Flyer"
http://www.mattsrv6.com - Matt's RV-6 Revitalization Log
Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Matt's Livermore Airport Live ATC Stream!
Check out the live ATC stream directly from my hangar at the Livermore
Airport. Includes both Tower and Ground transmissions. Archives too!
For entertainment purposes only. http://klvk.matronics.com
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
| Description: |
| Filesize: |
222.95 KB |
| Viewed: |
2996 Time(s) |
| Description: |
| Filesize: |
238.22 KB |
| Viewed: |
2996 Time(s) |
| Description: |
| Filesize: |
254.52 KB |
| Viewed: |
2996 Time(s) |
_________________ Matt Dralle
