kolber3(at)atcyber.net Guest
Posted: Sun Jun 15, 2014 4:05 pm Post subject: 582 Engine Vibration on Mark III |
Hoping some of you fellow Kolbers have some troubleshooting ideas. One a recent flight, the 582 engine on our Mark III suddenly went from being the usual silky smooth to instant roughness/vibration – almost as if something suddenly broke. We managed to get it back to the home airport about 13 miles away. The whole airframe was shaking, but the engine seemed to be developing full power. Switching from one ignition source to the other had no effect. The engine monitor indicated CHT and EGT to be nearly the same on both cylinders and within the normal range. I’ve since changed spark plugs, removed both carbs for disassembly, cleaning and inspection. I completely drained the fuel system and put fresh premium alcohol free fuel in. All has had no effect on the vibration. Engine mounts appear to be OK - not broken. The engine develops full power, but still shakes badly. Prop is visually OK. Would appreciate any tips on what to check next. The next step planned is a compression check. Thanks.
Gary
gajindra(at)sbcglobal.net Guest
Posted: Sun Jun 15, 2014 5:51 pm Post subject: 582 Engine Vibration on Mark III |
check torque on prop bolts
Gary Jindra
mark 3 912 ul
Gary
[quote]-= the many List utilities such as List h[b]
brubakermal(at)yahoo.com Guest
Posted: Sun Jun 15, 2014 6:38 pm Post subject: 582 Engine Vibration on Mark III |
B gear box? check inspect gear lube for gear wear C/E gear box check rubber dampener and fly wheel end bolts around starter
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Sent: Sunday, June 15, 2014 9:51 PM
Subject: Re: 582 Engine Vibration on Mark III
Gary Jindra
mark 3 912 ul
Gary
| Quote: | | -= the many List utilities such as List h[/url] |
[url=http://forums.matronics.com/]
| Quote: | http://www.matronics.com/Navigato_blank" href="http://forums.matronics.com/">http://forums.matronics.com</ rel="nofollow" target="_blank" href="http://www.matronics.com/contri===
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Mon Jun 16, 2014 6:26 am Post subject: Re: 582 Engine Vibration on Mark III |
If prop is ground adjustable make sure all angles are the same and one has not turned.
rickofudall
Posted: Mon Jun 16, 2014 8:30 am Post subject: 582 Engine Vibration on Mark III |
Gary, The first place I would look is for any broken welds or fractured tubing in the fuselage weldment in the area immediately adjacent to the engine. Start the engine and being careful of the prop feel all around the various tubes that you can easily reach to see if the vibration can be localized to a given area on the frame. I wouldn't put any stock in "Prop is visually OK". You do not say what kind and how many blades it has but all other indications being in the green, particularly CHT and EGT being normal and matched would rule out it being an engine issue, since the onset of trouble was sudden Since it is cheap and easy I would suggest you pull the prop off, taking note of the condition of its attachment bolts and their torque and the prop hub as well. If it's an IVO, check that one of the adjustment rod lever arms hasn't broken off by removing the adjustment screw. For all props get a piece of 1" tubing for an axle and a couple of matching drinking glasses and do a quick check of the balance of the prop blades. If you can borrow a prop that you know to be running smoothly put it on and see if the vibration goes away
Rick Girard
On Sun, Jun 15, 2014 at 8:51 PM, GARY JINDRA <gajindra(at)sbcglobal.net (gajindra(at)sbcglobal.net)> wrote:
| Quote: | check torque on prop bolts
Gary Jindra
mark 3 912 ul
On Sunday, June 15, 2014 8:10 PM, Kolb List <kolber3(at)atcyber.net (kolber3(at)atcyber.net)> wrote:
Gary
| Quote: | | -= the many List utilities such as List h[url=http://forums.matronics.com/][/url] |
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
colin.scott.hudson(at)gma Guest
Posted: Mon Jun 16, 2014 11:54 am Post subject: 582 Engine Vibration on Mark III |
Check for play in the gear drive by trying to move the prop up and down. Also, even though the prop visually looks ok one of the blades could have come out of adjustment assuming it’s a ground adjustable prop. Engine mounts are the #1 culprit but it sounds like you should check all of them.
Scott Hudson
On Jun 15, 2014, at 7:06 PM, "Kolb List" <kolber3(at)atcyber.net (kolber3(at)atcyber.net)> wrote:
[quote] <![endif]--> <![endif]-->
Gary
List"">http://www.matronics.com/Navigator?Kolb-List
Posted: Tue Jun 17, 2014 7:13 pm Post subject: 582 Engine Vibration on Mark III |
Update: Thanks to all who have responded with suggestions on things to inspect. Additional inspection/troubleshooting has still not identified a smoking gun, so I’ve made an appointment with a nearby Rotax service center later this week to trailer in the whole airplane to their facility and have them take a look at the engine and its installation. Hopefully, this effort will identify the problem.
Original Message:
Gary
