jrlark
Posted: Fri May 23, 2014 7:23 am Post subject: FirePenetrations |
Hi all, wondering if anyone has recommendations on any better locations for the throttle, prop, mixture and alternate air penetrations?
I’m just about to bolt my engine mount on for the last time and I haven’t drilled any holes for those 4 items yet. I`m wondering if the throttle and alternate air holes could be below the other 2, or if it makes any difference at all?
Thx, Rick
#40956
Southampton. Ont
jeff(at)westcottpress.com Guest
Posted: Fri May 23, 2014 8:21 am Post subject: FirePenetrations |
If you change the hole locations you will likely change your cable lengths and it is no easy trick to figure what those lengths need to be (ask me how I know).
Jeff Carpenter
40304
just about ready for paint.
On May 23, 2014, at 8:22 AM, Sandra & Rick Lark wrote:
| Quote: | Hi all, wondering if anyone has recommendations on any better locations for the throttle, prop, mixture and alternate air penetrations?
Thx, Rick
#40956
Southampton. Ont
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
philperry9
I used the normal holes and was really disappointed. Â So I'm getting ready to plug them with bolts and cut new holes in the recess. Â I'll be using the Eyeball Penetrations to get the cables to pass through the firewall at the appropriate angle.
If I had it to do again, I never would have drilled the factory holes. Â I would have just plugged them with rivets and cut new holes.
Phil
On Fri, May 23, 2014 at 10:22 AM, Sandra & Rick Lark <jrlark(at)bmts.com (jrlark(at)bmts.com)> wrote:
Â
Thx, Rick
#40956
Southampton. Ont
rleffler
Posted: Fri May 23, 2014 8:39 am Post subject: FirePenetrations |
If you are not using the method in the plans to penetrate the firewall (i.e. something other than a bushing), then the holes in the plans will most likely be too close together.
Mine are in the same general vicinity, but just spread out a little wider.
bob
_________________ Bob Leffler
N410BL - Phase I
philperry9
Posted: Fri May 23, 2014 8:52 am Post subject: FirePenetrations |
Yeah, I drilled to size and put the bushings in place. Â I found out that they were too close together even with the bushings. Â There just wasn't enough metal between the holes to support all the cables. Â The thin areas between the holes have twisted and mangled pretty badly. Â So I'm punting on that option while it's still easy to do.
Phil
On Fri, May 23, 2014 at 11:18 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
Â
Â
bob
Posted: Fri May 23, 2014 9:21 am Post subject: FirePenetrations |
Rick,
I did not like the alt air location, but I did like the standard Throttle, Prop and Mixture placement. I made a new bracket out of .050 aluminum and spread out the three controls just a little. The Oil Cooler air control (black knob) and Alt Engine Air control (red knob) are located on the left side of the apron. The two cabin heat controls (black knobs) are on the right (didn’t want the passenger to pull the alt air by mistake. Photo attached. Cable firewall holes are generally in line with the control mounting. If I was to do it over I would move the two cabin heat controls a little further to the right.
I also added a single .063” piece of angle connected to the bottom apron near the engine controls and the firewall. I was concerned there was too much flex in the middle of the panel. Might be overkill.
I did find the throttle cable Van’s recommends (47.5”) to be too short. I sent it back to Van’s and got the one he lists for IO-360 (50.5”). This is about an inch too long, but easily routed to make up the difference. The stock cable was tight against the bottom of the engine (IO-540 from Van’s).
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sandra & Rick Lark
Sent: Friday, May 23, 2014 11:23 AM
Subject: FirePenetrations
Thx, Rick
#40956
Southampton. Ont | Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com | 012345
136.67 KB |
9266 Time(s) |
larkrv10(at)gmail.com Guest
Posted: Fri May 23, 2014 10:26 am Post subject: FirePenetrations |
Thx Carl. I am presently fabricating stainless steel penetrations for my F/W and thought about ganging the throttle, prop and mixture together on a piece of 3"x4"x1/16" SS plate, basically in the same location as the pilot holes are.
I think I will wait to drill the alt air.
Nice looking panel, quite similar to what mine will look like (except it's a G3X touch).
Is the panel powder coated satin black or?
Thx again, Rick
On Fri, May 23, 2014 at 1:20 PM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
Rick,
Â
Â
Â
Carl
Â
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Sandra & Rick Lark
Â
Â
Thx, Rick
#40956
Southampton. Ont 0123 45
Bob Turner
Posted: Fri May 23, 2014 10:43 am Post subject: Re: FirePenetrations |
Even with following the plans exactly, my cables were too short to follow the routing in the plans. And I know I am not the only one with this issue. But not sure why.
_________________ Bob Turner
RV-10 QB |
Posted: Fri May 23, 2014 11:27 am Post subject: FirePenetrations |
I lot of people ask me where I got the panel powder coated – but it is just PPG single stage paint. Dark gray for the panel and engine plenum, light gray for the rest of the interior.
The is the second panel. As with my RV-8A I find there is always something to change on the panel every few years or so. Using the stock Van’s panel with paint make panel mods relatively simple.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark
Sent: Friday, May 23, 2014 2:25 PM
Subject: Re: FirePenetrations
Thx again, Rick
Rick,
Carl
Thx, Rick
#40956
Southampton. Ont
01234567890123
Kellym
Posted: Fri May 23, 2014 12:44 pm Post subject: FirePenetrations |
Rather than attempting to plug 5/8" or bigger holes with bolts, suggest
you get a piece of SS sheet metal, same thickness as firewall and rivet
it over the holes. Lighter, cleaner, more professional.
On 5/23/2014 9:21 AM, Phillip Perry wrote:
| Quote: | I used the normal holes and was really disappointed. So I'm getting
ready to plug them with bolts and cut new holes in the recess. I'll
Phil
penetrations?
Thx, Rick
#40956
Southampton. Ont
KCHD |
Kellym
Posted: Fri May 23, 2014 12:49 pm Post subject: FirePenetrations |
Has anyone attempted to engineer an automatic alternate air?? My fuel
injected Mooney has such, with a round disk attached to a hole cut so
that there is a metal cross with 4 openings rather than open hole. The
disk covers that, is held in place with a single bolt with a spring on
it pressing the disk in closed position. 3-4 lb force lifts the disk
enough for air to bypass the filter from inside cowling. Only downside
is you don't really know whether it has opened or not. I've seen 2 place
RVs that had similar arrangement with hinged rectangular door that was
spring loaded.
On 5/23/2014 9:20 AM, Jeff Carpenter wrote:
| Quote: | If you change the hole locations you will likely change your cable
Jeff Carpenter
40304
> Thx, Rick
> #40956
> Southampton. Ont
KCHD |
