chasb(at)satx.rr.com Guest
Posted: Mon May 19, 2014 6:02 am Post subject: Strobe Switch - New evidence |
Bob, et. al.,
Once again my strobes quit working. Suspecting another Carling switch failure, that's what I checked first. To my surprise, the switch and its connections were pristine. However, the other end of the power line, a Molex connector at the Whelen Strobe Power Pack, was the problem. The power pin had overheated to the point where the Molex connector was blackened and melted around the pin. The other pin on the connector, a ground wire, was not affected. Replaced the Molex and the system is back in operation. The mystery deepens.
Charlie Brame
RV-6A N11CB
San Antonio
RnJCurtis(at)charter.net Guest
Posted: Mon May 19, 2014 6:35 am Post subject: Strobe Switch - New evidence |
Did you check the old connector to see if (1) there
were any broken strands on the connector going into
either side? (2) Were the wires on the pins
stripped properly and a nice gas tight crimped
connection? (3) Did there appear to be any corrosion
on the pins? Sometimes it is difficult to see these things
after the connection is burned up, but it is worth a look.
Roger
sprocket(at)vx-aviation.c Guest
Posted: Mon May 19, 2014 6:50 am Post subject: Strobe Switch - New evidence |
Not a mystery at all. The strobe power pack is a constant-power device, which means that as the input voltage drops, the load current increases. If you have a resistive switch or connection, you'll get what's called 'thermal runaway'.
This leads to burnt or charred switches, contacts or connectors.
When I first discovered the problem about 7 years ago, It was the Carling switch rivets that were the root cause, but any deteriorating contact can cause it.
Make it an annual inspection item for the strobe connectors and switches. Check your landing and taxi light circuits as well.
Vern
Sent from my iThing. It is responsible for all gramma and typo terrors.
| Quote: | On May 19, 2014, at 7:01 AM, Charles Brame <chasb(at)satx.rr.com> wrote:
Bob, et. al.,
Charlie Brame
RV-6A N11CB
San Antonio
Posted: Mon May 19, 2014 11:03 am Post subject: Strobe Switch - New evidence |
Not sure what strobe power supply you are using but I changed from one
that many homebuilders were using (Plane Power?) to a Nova Electronics
XPAK604X unit. It looks and mounts just like my old unit but it
separates the switch from the power circuit with what I assume is an
internal relay.
I burned out a switch terminal on my original installation. I didn't
fully understand the reasons but I swapped the original out for the Nova
unit. It significantly shortened the power leads from over 10 feet to
<2' (RV10).
Just a thought.
On 5/19/2014 10:01 AM, Charles Brame wrote:
Bob, et. al.,
Charlie Brame
RV-6A N11CB
San Antonio
Checked by AVG - www.avg.com
