'Ford' Voltage regulator
peter(at)sportingaero.com
PostPosted: Wed May 14, 2014 11:57 am    Post subject: 'Ford' Voltage regulator Reply with quote
Guys,
Does anyone have a part number for a generic 'Ford' voltage regulator?
I know they are readily available in the US, but in the UK the first
question is always,
"What car does it come from...?"
When you can't provide a model & year, or a part number most parts store
guys give up.
They must be available if only we could figure out what to ask for!
Thanks in advance.
Peter
jdubner
PostPosted: Wed May 14, 2014 1:31 pm    Post subject: 'Ford' Voltage regulator Reply with quote
Peter, I used a "VR166" voltage regulator with my 40A B&C alternator and bought
it from Amazon.com. Assuming this link is available in the UK, you can see it here:
http://www.amazon.com/Standard-Motor-Products-VR166-Regulator/dp/B000C805SW
Best,
Joe
Independence, OR
Peter Pengilly wrote, On 5/14/2014 12:52:
<peter(at)sportingaero.com>
Guys,
question is always,
guys give up.
Thanks in advance.
Peter
Independence, OR
skywagon
PostPosted: Wed May 14, 2014 1:53 pm    Post subject: 'Ford' Voltage regulator Reply with quote
Peter,
Are you looking for the old "mechanical" type or the newer solid state
model. . .??
If it is the newer integrated circuit type, here is my suggestion.
Take your old unit into a marine or truck type parts house. Show them the
unit ( remove any Cessna stickers off it ) and tell them that it is off a
boat. There is no parts references really for boats. A smart parts guy
will know the exact unit to pick. They usually also have a heavy duty unit.
I would op for that model as it will only be a few dollars more.
Last time I did this, it was a truck store. I started in with a mechanical
type reg. Asked for the newer style unit that was a direct plug
replacement. The parts guy knew what would work. He even offered to run
the new regulator on his shop equipment and check the control voltage.
Being a solid state unit, it is very easy to adjust this with the internal
pot.
David
_______________________________________________________________________-
PostPosted: Wed May 14, 2014 2:03 pm    Post subject: 'Ford' Voltage regulator Reply with quote
At 02:52 PM 5/14/2014, you wrote:
--> AeroElectric-List message posted by: Peter Pengilly <peter(at)sportingaero.com>
Guys,
I know they are readily available in the US, but in the UK the first question is always,
When you can't provide a model & year, or a part number most parts store guys give up.
Yup . . . airplane parts business suffers
from the same malady . . . no part number
no part . . . assuming it's even in the system.
That's one regulator that has a 99% chance
of being 'correct' by simply observing it's
shape. If it looks like this
[img]cid:.0[/img]
It's going to work.
Here's an array of options from a local US
supplier. Used 1980 Ford Fairmont as baseline
but if you look at other models over 1975-1990
model years, you find a similar array.
http://tinyurl.com/m7ke8p2
other examples:
http://tinyurl.com/od994zl
http://tinyurl.com/l6qm8js
http://tinyurl.com/m83q5q8
http://tinyurl.com/lro7dlh
Poke around on the 'net long enough and you'll
find this part offered on a dozen or more part numbers.
You should be able to pick one up for about $20-30 . . .
perhaps less.
 Filesize:  127.2 KB
 Viewed:  4271 Time(s)
PostPosted: Wed May 14, 2014 2:16 pm    Post subject: 'Ford' Voltage regulator Reply with quote
At 04:47 PM 5/14/2014, you wrote:
Peter,
state model. . .??
them the unit ( remove any Cessna stickers off it ) and tell them
that it is off a boat. There is no parts references really for
boats. A smart parts guy will know the exact unit to pick. They
usually also have a heavy duty unit. I would op for that model as it
mechanical type reg. Asked for the newer style unit that was a
direct plug replacement. The parts guy knew what would work. He
even offered to run the new regulator on his shop equipment and
check the control voltage. Being a solid state unit, it is very easy
to adjust this with the internal pot.
Good data . . . with one caveat . . . not ALL
solid state replacements are not 'drop in'
replacements for the manner in which Cessna
used the "S" terminal and the o.v. module.
http://tinyurl.com/7g7mn6l
Tried the substitution on of our rental fleet
a/c at Benton and had an uncontrolled runaway
under some switch positions. Don't recall details
right now but do the substitution in a Cessna
with caution.
PostPosted: Thu May 15, 2014 2:31 pm    Post subject: 'Ford' Voltage regulator Reply with quote
Thanks all for your suggestions - I'm looking for a solid state device
so will try this tack.
From Bob's links there is an ACDelco part that fits 2630 Fords, so that
may be worth a try!
Regards, Peter
On 14/05/2014 22:47, David Lloyd wrote:
<skywagon(at)charter.net>
Peter,
model. . .??
the unit ( remove any Cessna stickers off it ) and tell them that it
is off a boat. There is no parts references really for boats. A
smart parts guy will know the exact unit to pick. They usually also
have a heavy duty unit. I would op for that model as it will only be a
few dollars more.
mechanical type reg. Asked for the newer style unit that was a direct
plug replacement. The parts guy knew what would work. He even
offered to run the new regulator on his shop equipment and check the
control voltage. Being a solid state unit, it is very easy to adjust
David
