schmoboy
Posted: Sat May 10, 2014 2:36 pm Post subject: 43o Card Edge Connector |
I'm looking for help on what orientation the card edge connector used
for shield termination on the back of a Garmin 430 should be inserted.
It's a Garmin 336-00029-00 or AMP 583853-4 card edge connector. It has a
"spring" side and a "barb" side. Not sure what to actually call them
and that's the best I can do.
Should the "barb" side face in, up, out or down in relation to the
termination block when inserting on the back of the 430?
-Sean
tim2542(at)sbcglobal.net Guest
Posted: Sat May 10, 2014 4:28 pm Post subject: 43o Card Edge Connector |
Can't answer your question, but FWIW, I don't use it. I really like Bob's avionics ground bus, I use one mounted close to the back of the radio stack.
| Quote: | On May 10, 2014, at 3:35 PM, Sean Stephens <sean(at)stephensville.com> wrote:
I'm looking for help on what orientation the card edge connector used for shield termination on the back of a Garmin 430 should be inserted.
It's a Garmin 336-00029-00 or AMP 583853-4 card edge connector. It has a "spring" side and a "barb" side. Not sure what to actually call them and that's the best I can do.
Should the "barb" side face in, up, out or down in relation to the termination block when inserting on the back of the 430?
-Sean
schmoboy
Posted: Mon May 12, 2014 9:27 am Post subject: 43o Card Edge Connector |
For those interested, I found the answer.
The "spring" side of the connector is oriented on the inside of the
termination block so it contacts the "card edge".
| Quote: | Tim Andres <mailto:tim2542(at)sbcglobal.net>
May 10, 2014 at 7:26 PM
<tim2542(at)sbcglobal.net>
radio stack.
