CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow
dbotich
PostPosted: Sat May 03, 2014 11:29 am    Post subject: CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow Reply with quote
I need a socket tool for the propeller shaft nut on my CJ. From the IPC: PN G1-K02, Tool, propeller front taper nut spanner, Vol 2 page 133, fig 8-8, item 3.
Doug is out of stock for the next 60 days and I am getting ready to start my engine. I would like to buy one if I can or borrow/rent one for a day.
samira.h(at)shaw.ca
PostPosted: Sat May 03, 2014 2:52 pm    Post subject: CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow Reply with quote
samira.h(at)shaw.ca
PostPosted: Sat May 03, 2014 3:00 pm    Post subject: CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow Reply with quote
Is that the tool you are looking for
(please see attached pictures)?
If yes, I am asking $130 - plus
shipping - plus PayPal. If interested,
please contact me off list.
cheers
Elmar
 Filesize:  882.15 KB
 Viewed:  8494 Time(s)
 Filesize:  660.47 KB
 Filesize:  630.09 KB
Dale
PostPosted: Sat May 03, 2014 4:58 pm    Post subject: Re: CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow Reply with quote
Cheap socket from Northern tool. I machined down in my lathe.
 Filesize:  924.21 KB
 Viewed:  8486 Time(s)
keithmckinley
PostPosted: Mon May 05, 2014 10:11 am    Post subject: Re: CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow Reply with quote
I have one, I'd be happy to let you use contact me off list.
keith(at)mckinley.us
dbotich
PostPosted: Fri May 09, 2014 3:18 pm    Post subject: Re: CJ HELP Need A Prop Nut Socket to Buy, Rent, Borrow Reply with quote
Thank you all. I found a setup that will work.
