Nose gear failure
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
gregsmi
PostPosted: Sat May 03, 2014 5:43 am    Post subject: Nose gear failure Reply with quote
Clarke Coulter just reported his nose gear failed on take off. His landing was uneventful but the plane did sustain damage. His nose gear is the Aerodesigns gear with the spindle shaft welded inside a collar. Since the failure is occurring inside the collar, there is no way to inspect.
If you have one of these nose gears you should look on the forum to see what modifications others have done to make this area stronger and easy to inspect. It could save you from having to rebuild your aircraft.
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
