jrevens
Posted: Wed Apr 30, 2014 8:45 am Post subject: Battery and master contactor - ok to mount horizontally? |
Mounting position is definitely a consideration with some contactors. There are units that are designed for horizontal mounting,
or are position insensitive, but there are others that are not. The Series 70 White-Rogers units, that have been very commonly
used in aircraft for decades are position sensitive. Here is a link to some info:
http://www.emersonclimate.com/Documents/White-Rodgers/sell_sheets/R-4003web.pdf
This literature recommends dome, or cap, down. Depending on whether the unit is used as a master or start "solenoid", some
recommend mounting dome up These solenoid/contactors will seem to work OK either way, but there is more potential wear
and possibility of binding or improper operation if they are operated horizontally.
John [img]cid:part2.03020806.01000602(at)comcast.net[/img]
347.06 KB |
1451 Time(s) |
_________________ John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying) |
