Linking 2 coax cables
trigo(at)mail.telepac.pt
PostPosted: Sun Apr 27, 2014 3:38 am    Post subject: Linking 2 coax cables Reply with quote
Guys
I had to cut and throw away some 2 feet of a Comm antenna cable which I
found that had a burnt spot.
I don't want to replace all the coax cable, which would be a PIA to do.
I also know that I can use a male and a female BNC connectors to make a 2
feet extension, but
Is there an elegant and efficient way to connect 2 coax cables to each
other, without using a male and a female connectors?
Carlos
Este email está livre de vírus e malware porque a proteção avast! Antivirus está ativa.
http://www.avast.com
PostPosted: Sun Apr 27, 2014 5:43 am    Post subject: Linking 2 coax cables Reply with quote
At 06:37 AM 4/27/2014, you wrote:
<trigo(at)mail.telepac.pt>
Guys
feet extension, but
Yeah, sort of but it's pretty process sensitive.
I'd vote for the connectors.
Eric M. Jones
PostPosted: Sun Apr 27, 2014 3:03 pm    Post subject: Re: Linking 2 coax cables Reply with quote
Install a new cable or connectors. No other reasonable solution exists. Read my article attached.
Dabbling with Electricity.pdf
Download
 Filename:  Dabbling with Electricity.pdf
 Filesize:  248.25 KB
 Downloaded:  331 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
