EFIS/EMS
Goto page 1, 2  Next
Albert Gardner
PostPosted: Wed Jun 21, 2006 9:37 pm    Post subject: EFIS/EMS Reply with quote
I see that Advanced Flight Systems now offers a EFIS/EMS combo (AF3500 & AF
3400) that is slightly larger than Dynon's D100/D120 combo. Anybody far
enough along to be considering either one of these units?
Albert Gardner
40-422
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Dave(at)AirCraftersLLC.co
PostPosted: Wed Jun 21, 2006 10:16 pm    Post subject: EFIS/EMS Reply with quote
Here is my current proposed panel w/ AF3400 et al. We just finished
modifying the forward bulkhead to accept these stacks.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
www.AirCraftersLLC.com
wayne.e(at)grandecom.net
PostPosted: Thu Jun 22, 2006 3:40 am    Post subject: EFIS/EMS Reply with quote
Albert,
I bought the AF3400 at Sun-N-Fun and I'm still waiting for it. I've attached a photo of where we've placed it in my panel. I originally had their AF2500 unit on order before Sun-N-Fun. I hope I'm following the correct protocol for posting a picture.
Wayne Edgerton #40336
Hopefully soon mounting the engine
Attachment: http://www.matronics.com/enclosures/c4506245b0e8aeb73192162e5fed55bd43e2ad8a.jpg
pcasson(at)sasktel.net
I went with the D100/D120 combo mostly based on already having a D10 in my
Glastar and being satisfied with it and the few complaints I did have were
addressed in the D100.
My original layout was not possible due to rib interference:
http://casson.2y.net/yappa-ng/index.php?album=%2FRV-10%2F&image=20051222_082
So I after some sitting in the cockpit checking to be sure all buttons
remain accessible and visibility was still good I went the D100 on the
centerline of the pilot and the D120 on the centerline of the co-pilot and
with the screen swapping features between the d100/d120 the plane should be
nicely flyable from either seat.
http://casson.2y.net/yappa-ng/index.php?album=%2FRV-10%2F&image=20060524__00
For a VFR aircraft like I'm building, I think along with a Garmin 396 and 2
axis autopilot should make for a nice enough panel without dropping the
extra $30K+ to go glass IFR.
Perry Casson
jim(at)CombsFive.Com
PostPosted: Thu Jun 22, 2006 6:14 am    Post subject: EFIS/EMS Reply with quote
I am planning on the AFS-3500EE route.
I was planning on using the Dynon D100 EFIS and D120 engine monitor. After adding up all the "optional" stuff that was required, the cost was equal to the AFS system. The AFS appears to have more function too.
I would like to see what they are going to do for the CDI / HSI display.
Jim Combs
N312F
40192
Fuseleage / Finishing
Albert Gardner
40-422
Yuma, AZ
PostPosted: Thu Jun 22, 2006 6:54 am    Post subject: EFIS/EMS Reply with quote
Darn auto-line break messed with the urls in my 1st post. Hopefully these work:
Plan A:
http://casson.2y.net/yappa-ng/index.php?album=%2FRV-10%2F&image=20051222_082751.JPG
As built:
http://casson.2y.net/yappa-ng/index.php?album=%2FRV-10%2F&image=20060524__002.jpg
Perry
randy(at)romeolima.com
PostPosted: Thu Jun 22, 2006 7:39 am    Post subject: EFIS/EMS Reply with quote
Thought you 10 guys might get a kick out of seeing the AFS-3500 in my RV-3
panel...
http://www.romeolima.com/RV3works/Panel/DSC_0938.jpg
This is a GREAT solution for this plane. I'll combine it with a TruTrak
DigiFlight IIVS slaved to a Garmin 296 and voila, everything I need.
Randy Lervold
www.rv-3.com
CJohnston(at)popsound.com
PostPosted: Thu Jun 22, 2006 9:26 am    Post subject: EFIS/EMS Reply with quote
I ordered the 3500 efis/engine monitor for my aircraft as a backup to
the dual chelton setup. I saw the 3500 at sun-n-fun and was really
impressed. Funnily enough, in this era of everybody coming out with
their own efis, I was most impressed by the graphical weight and balance
page. It was intuitive, and very easy to use. Hopefully it'll make
loading a breeze. Also, I'm trying to get away from having a bunch of
little doodads in the panel that are necessary but annoying. I really
like the trim and flaps indicator built into the 3500. I've also looked
into having my own custom annunciator panel built so that all the flight
critical warnings show up in the same place. All alarms, low fuel (fuel
guardian), efis warnings, etc. I'm going for a super clean panel
look/feel. Also, I ordered the 3500 with the internal battery backup.
AFS says it should keep the unit lit for a couple hours if the
electrical system goes poo. With all the talk on other forums about
efis systems quitting due to electrical snafu, it seemed like cheap
insurance.
cj
#40410
fuse
armywrights(at)adelphia.n
PostPosted: Thu Jun 22, 2006 7:19 pm    Post subject: EFIS/EMS Reply with quote
Albert,
I'm planning the 3500; awaiting some more documentation on the website (next
three weeks I'm told). If you go with the full system you also need to plan
to stray from Van's recommended fuel routing in the tunnel. Call 'em up and
ask for Rob's insight on this until they get the info on the website.
Rob Wright
#392 Wings
Albert Gardner
PostPosted: Thu Jun 22, 2006 11:29 pm    Post subject: EFIS/EMS Reply with quote
Oh no! I have the tunnel all plumbed except for the feed lines from the
wings to the selector valve. Wouldn't you know it-Murphy's Law. I'll call
tomorrow.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
rvbuilder(at)sausen.net
PostPosted: Fri Jun 23, 2006 2:32 am    Post subject: EFIS/EMS Reply with quote
Albert,
Don't sweat the location too much. Rob and most of the guys that use
a Floscan type of transducer recommend that you put it in the engine
compartment between the engine pump and distribution servo to get the
most accurate reading. Airflow Performance also recommends this
location. Van's is worried that it is too harsh of an environment so
they recommend you put it in the tunnel but nobody that I have talked to
have had a problem with it in the engine compartment. Bottom line is it
works just fine in the tunnel if you want to leave it there.
Michael Sausen
RV-10 #352 Working on Fuselage
Tim(at)MyRV10.com
PostPosted: Fri Jun 23, 2006 3:26 am    Post subject: EFIS/EMS Reply with quote
I can verify that tunnel mounting isn't a problem. Once I set my
calibration factor for the flow transducer, I can typically fly
a few hundred miles and fill the tanks and will fill within .1
or at most about .2 gallons difference, and if I wanted to work
the calibration up even closer I may even be able to perfect
on that.
RV Builder (Michael Sausen) wrote:
Albert,
Michael Sausen
jesse(at)itecusa.org
PostPosted: Fri Jun 23, 2006 4:21 am    Post subject: EFIS/EMS Reply with quote
Putting the transducer between the engine's pump and the fuel servo seems to
me to be a bad idea (replying to whoever mentioned it). In N256H, when we
kick on the boost pump, the fuel flow goes up a fair bit, which means that
it is possible that some fuel is being pumped overboard via the overflow on
the engine-mounted fuel pump. If this were the case, you would never know
about it if the transducer was mounted beyond this engine-mounted pump. Is
my thinking way off here?
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
KBelue(at)drs-tem.com
PostPosted: Fri Jun 23, 2006 4:43 am    Post subject: EFIS/EMS Reply with quote
I've seen the fuel flow go up by several gph on my RV-6A when I turn on the
boost pump, but there is no overflow when I look at the overflow tube (on
the ground, of course). I think the pulsation of the boost pump causes the
fuel flow sensor to read higher than normal.
Kevin D. Belue
RV-6A Flying
RV-10 working on doors
[quote] --
flysrv10(at)gmail.com
PostPosted: Fri Jun 23, 2006 5:00 am    Post subject: EFIS/EMS Reply with quote
I have also been told that the Flowscan may not share ground wiith the
fuel pump or be grounded to aircraft structure. This was given to me
as the reason for high fuel count when fuel pump is on.
Rob.
Kevin D. Belue
RV-6A Flying
PostPosted: Fri Jun 23, 2006 6:12 am    Post subject: EFIS/EMS Reply with quote
Hmm, I don't know but I don't think it should be pumping overboard for
any reason. But you are correct, the farther upstream the sender is the
less likely you will see a leak or from the tank side. I went with an
optical low fuel lever sensor in addition to the fuel gauges for leak
detection. The main reason they recommend the sensor to be put after
the pumps is because you really don't want any restrictions if at all
possible on the suction side of the pump as it can cause vapor lock or
pump cavitations because of the sudden drop in pressure/volume.
Michael Sausen
Rick S.
PostPosted: Fri Jun 23, 2006 6:28 am    Post subject: EFIS/EMS Reply with quote
I ordered the 3500 system, Rob sold me the tranducer right (very impressed by the workmanship but not a Floscan) away so I could complete the plumbing and wiring. For those planning on this system, it does NOT mount in the floscan hole configuration. The mountng holes are on the right side of the unit inline with the datum, not 45 degrees from each other. So, if you used Van's mount for the floscan you will need to drill it off the floor and modify it for the ACS transducer. No big deal though took about an hour and a half to remove, modify and reattach.
Rick S.
40185
Rick S.
RV-10
40185
Albert Gardner
PostPosted: Fri Jun 23, 2006 8:26 am    Post subject: EFIS/EMS Reply with quote
Can the 3500 use the Floscan transducer or do you need a different one?
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Rick S.
PostPosted: Fri Jun 23, 2006 8:51 am    Post subject: EFIS/EMS Reply with quote
Not sure Al,
I'd give Rob a call especially if you already have the Floscan onhand. Day ain't cheap, neither of them.
I just figured I would use ACS's since it's their system, I'd use their transducer.
Rick S.
40185
Rick S.
RV-10
40185
LarryRosen
PostPosted: Fri Jun 23, 2006 10:40 am    Post subject: EFIS/EMS Reply with quote
When I was considering the 3500 I asked rob if the Floscan transducer
would work, since it was already installed, and he said it was
compatible with his all his units.
Larry Rosen
#356
Albert Gardner
Yuma, AZ
Larry Rosen
#40356
N205EN (reserved)
<http>
Goto page 1, 2  Next
Page 1 of 2
