VP-200 Noise on Softkey Push
schmoboy
PostPosted: Tue Apr 08, 2014 8:42 am    Post subject: VP-200 Noise on Softkey Push Reply with quote
For those with the VP-200 in their bird...
I am getting a small burst of static over the intercom when I press one
of the four soft keys on the display. I do NOT get the same static when
I press the far right knob.
All audio tones generated by the VP-200 are coming across fine and I
have no other devices causing static.
Has anyone else come across this?
-Sean #40303
rv10flyer(at)live.com
PostPosted: Tue Apr 08, 2014 8:57 am    Post subject: VP-200 Noise on Softkey Push Reply with quote
No static from the VP when pressing buttons. It has started to not always
move to the next mode of flight (when it should), with no changes from me
however. May be a call to Chad (at) VP is in order.
Pascal
jesse(at)saintaviation.co
PostPosted: Tue Apr 08, 2014 9:14 am    Post subject: VP-200 Noise on Softkey Push Reply with quote
I think I remember seeing that in the early days. They came out with a little chip that went inline with the audio circuit, if I'm not mistaken, that helped or took care of that. I'd call VP.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Apr 8, 2014, at 12:34 PM, Sean Stephens <sean(at)stephensville.com> wrote:
I am getting a small burst of static over the intercom when I press one of the four soft keys on the display. I do NOT get the same static when I press the far right knob.
All audio tones generated by the VP-200 are coming across fine and I have no other devices causing static.
-Sean #40303
Site Admin
PostPosted: Tue Apr 08, 2014 10:16 am    Post subject: VP-200 Noise on Softkey Push Reply with quote
-Sean #40303
My VP-200's make a "kkrrsssh" sound whenever I press any of the 5 chicklette buttons. That's by design. I told Marc it should be a "click", but he preferred "kkrrssh". Whatevs... Smile
Matt
Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
schmoboy
PostPosted: Tue Apr 08, 2014 10:38 am    Post subject: VP-200 Noise on Softkey Push Reply with quote
I had a feeling that it might be intended. The "kkrrssh" sure sounds
like a static "pop", which lead me to believe I messed up the audio
wiring somehow.
I wonder if that sound is just a sound file somewhere on the system and
it could be replaced?
-Sean
Matt Dralle <mailto:dralle(at)matronics.com>
April 8, 2014 at 1:15 PM
Matt
Flyer Mode
dmaib@me.com
PostPosted: Tue Apr 08, 2014 10:50 am    Post subject: VP-200 Noise on Softkey Push Reply with quote
Mine has always done that.
On Apr 8, 2014, at 11:34 AM, Sean Stephens <sean(at)stephensville.com> wrote:
-Sean #40303
David Maib
RV-10 #40559
New Smyrna Beach, FL
johngoodman
PostPosted: Tue Apr 15, 2014 9:32 am    Post subject: Re: VP-200 Noise on Softkey Push Reply with quote
Mine has always done it, as well. I just assumed it was something Marc did.
