Main air valve
gill.g(at)gpimail.com
PostPosted: Thu Apr 10, 2014 2:42 pm    Post subject: Main air valve Reply with quote
This valve has 1/8” npt fittings which are the same as the stock Chinese valve, no adaptor is required. I use a different valve for the emergency air which bleeds emergency system and eliminates sticking shuttle valve issues.
Gill
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Dee Conger
Sent: Thursday, March 27, 2014 2:38 PM
To: yak-list
Subject: Re: Main air valve
Hi - don't have that handy, but I used 1/4" valves in all my Yaks - the lines in the yak are 6mm, so easiest way to adapt is to buy swagelok 6mm to 1/4" union adapters, and then splice in a short run of 1/4" tubing. I use these valves on the main and also emergency valves - WAY better than the russian valves and never leak.
On Thu, Mar 27, 2014 at 9:50 AM, rmhou(at)yahoo.com (rmhou(at)yahoo.com) <rmhou(at)yahoo.com (rmhou(at)yahoo.com)> wrote:
Hi Dee,
Can you share the part number of the compatible Swagelok valve?
Robin
Sent from Yahoo Mail on Android
From: Dee Conger <dee(at)innoviveinc.com (dee(at)innoviveinc.com)>;
To: yak-list <yak-list(at)matronics.com (yak-list(at)matronics.com)>;
Sent: Thu, Mar 27, 2014 4:24:54 AM
Why would you possibly want to install those shitty russian valves? Do yourself a favor and retrofit to Swagelok (or similar) 1/4 turn valve - a very simple retrofit, but a huge improvement.
On Wed, Mar 26, 2014 at 9:02 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:
--> Yak-List message posted by: Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)>
Kregg: I'll take two if you have them to spare...contact me off list.
On Mar 26, 2014, at 10:48 PM, Kregg Victory <kregg(at)balancemyprop.com (kregg(at)balancemyprop.com)> wrote:
--> Yak-List message posted by: Kregg Victory <kregg(at)balancem
How many do you need? I have a few.
Kregg Victory
> On Mar 26, 2014, at 8:38 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:
> Folks: looking for a main air valve. Anyone have an idea where one can be found? I've tried Doug and Jill.
> Sent from my iPad
> <image.jpeg>
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
http://www======================
et="_blank">http://www.matronics.com/Navigator?Yak-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
 Filesize:  23.13 KB
 Viewed:  2425 Time(s)
Dawg
PostPosted: Thu Apr 10, 2014 10:56 pm    Post subject: Main air valve Reply with quote
Can we see pix of these great ideas? Thank you
On Apr 11, 2014, at 7:41, "Gill Gutierrez" <gill.g(at)gpimail.com (gill.g(at)gpimail.com)> wrote:
[quote]v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
This valve has 1/8� npt fittings which are the same as the stock Chinese valve, no adaptor is required. I use a different valve for the emergency air which bleeds emergency system and eliminates sticking shuttle valve issues.
Gill
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Dee Conger
To: yak-list
Hi Dee,
Robin
Kregg Victory
> Sent from my iPad
> <image.jpeg>
le, List Admin.
<Swagelok Valve.JPG>
Dawg
rmhou(at)yahoo.com
PostPosted: Fri Apr 11, 2014 11:12 am    Post subject: Main air valve Reply with quote
Hi Gill and Dee,
Thank you both. I called their L.A. office and the price is only $88 with no min quantity requirement. This is cheaper than the Chinese valve.
Gill, can you provide more information on your emergency valve mod? What is the Swagelok part no. and which shuttle valve did you eliminate?
Thanks in advance.
Robin
To: yak-list(at)matronics.com
Sent: Thursday, April 10, 2014 3:41 PM
Subject: RE: Main air valve
Gill
To: yak-list
Hi Dee,
Robin
Subject: Re: Yak-List: Main air valve
Kregg Victory
> Sent from my iPad
> <image.jpeg>
le, List Admin.
