CHT reading failure
rickofudall
PostPosted: Wed Apr 09, 2014 10:55 am    Post subject: CHT reading failure Reply with quote
The 912S sat out the winter months while we worked through the gig list from the aircraft's annual. The only change to the engine was replacing an O-ring on the coolant inlet of the number 4 head.On startup last Sunday, the engine started and ran fine however the MGL EFIS would not show CHT readings. I've verified that the wires from the senders to the RDAX unit are connected, but the day closed out before I could get any further. It seems unlikely that both senders would fail at once but I would still like to verify that they're working properly. Does anyone have or know of a resistance chart for Rotax CHT senders?
Rick Girard
  - Groucho Marx
Roger Lee
PostPosted: Wed Apr 09, 2014 11:44 am    Post subject: Re: CHT reading failure Reply with quote
Hi rick,
I can almost guarantee it isn't the two separate CHT senders that went bad at the same time and these senders are fairly bullet proof and tend to last many years. Somewhere there is a bad connection. Most Rotax fixes are simple and people always want to start looking for exotic problems. Start simple first.
A bad connection.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
h&jeuropa
PostPosted: Thu Apr 10, 2014 3:42 am    Post subject: Re: CHT reading failure Reply with quote
Rick,
Here is a VDO chart of temp sensors.
Jim Butcher
TemperatureResistanceChart.pdf
 Filename:  TemperatureResistanceChart.pdf
 Filesize:  26.9 KB
 Downloaded:  815 Time(s)
rickofudall
PostPosted: Fri Apr 11, 2014 6:16 pm    Post subject: CHT reading failure Reply with quote
Thanks, Jimdo not archive
On Thu, Apr 10, 2014 at 6:42 AM, h&amp;jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> RotaxEngines-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Rick,
Jim Butcher
http://forums.matronics.com/viewtopic.php?p=421867#421867
http://forums.matronics.com//files/temperatureresistancechart_124.pdf
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
