tonyrenshaw268(at)gmail.c Guest
Posted: Sun Apr 06, 2014 4:30 pm Post subject: Parcel Shelf tray door access for fuses, CBS |
Gidday,
Whilst working on my panel I was wondering if anyone has buried their fuses in a hatch within the parcel shelf? Sure, it wouldn't be accessible, but, if you didn't plan on gaining access and built the aircraft accordingly, maybe within the parcel shelf floor might be a good little location?
Any thoughts?
Tony Renshaw
rparigoris
Posted: Sun Apr 06, 2014 5:02 pm Post subject: Parcel Shelf tray door access for fuses, CBS |
Hi Tony
You can have a look through my 3 pages of instrument module:
http://www.europaowners.org/main.php?g2_itemId=27305
I have a sub panel that has fuses.
Ron Parigoris [quote][b]
rowlandcarson(at)gmail.co Guest
Posted: Mon Apr 07, 2014 12:28 am Post subject: Parcel Shelf tray door access for fuses, CBS |
On 7 Apr 2014, at 01:26, Tony Renshaw wrote:
| Quote: | Whilst working on my panel I was wondering if anyone has buried their fuses in a hatch within the parcel shelf? Sure, it wouldn't be accessible, but, if you didn't plan on gaining access and built the aircraft accordingly, maybe within the parcel shelf floor might be a good little location?
Tony - yes, that's what I have done. See:
http://www.rowlandcarson.org.uk/aviation/europa_435/shelf_cut.php
for the hole I hacked in the parcel shelf, with the fuseblocks placed to show how they will fit.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
Posted: Mon Apr 07, 2014 1:17 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Tony & Rowland, I have a slightly different philosophical
approach to this question. A fuse may well go as part of
some in air failure just possibly accompanied by fire or
smoke. Time spent working out what is happening threatens
your safety. As with an engine failure serious distraction
and stress can lead to speed decay and a stall/spin
accident. So I prefer my fusing system to be out where it
is immediately obvious what has blown and for this reason
I recommend switchable circuit breakers, all labelled and
readily visible. They have the added benefit of readily
allowing switching off of circuits to deal with
emergencies such as regulator failure. Regards, David
Joyce, G-XSDJ
On Mon, 7 Apr 2014 09:27:30 +0100
Rowland Carson <rowlandcarson(at)gmail.com> wrote:
>location?
in friendship
Rowland
Carson
Admin.
2.93 MB |
13348 Time(s) |
brian.davies(at)clara.co. Guest
Posted: Mon Apr 07, 2014 2:04 am Post subject: Parcel Shelf tray door access for fuses, CBS |
David,
You make a very good point. The only electrical incident I have experienced on my aircraft was a generator overvolt trip just after coasting out over the Channel. After a careful check and a reset of the circuit breaker I was able to proceed without any drama. The alternative, with a fuse not readily accessible, would have been a turn back to the airfield/refiling flight plan, revised GAR arrival time etc. etc.
The safety aspects are even more important..
Brian
Posted: Mon Apr 07, 2014 3:04 am Post subject: Parcel Shelf tray door access for fuses, CBS |
On 7 Apr 2014, at 11:03, Brian Davies wrote:
| Quote: | You make a very good point. The only electrical incident I have experienced on my aircraft was a generator overvolt trip just after coasting out over the Channel. After a careful check and a reset of the circuit breaker I was able to proceed without any drama. The alternative, with a fuse not readily accessible, would have been a turn back to the airfield/refiling flight plan, revised GAR arrival time etc. etc.
[quote] --
Posted: Mon Apr 07, 2014 4:43 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Rowland, I don't dispute the electrical safety. It is just
the distraction of having to dig around to make a
diagnosis and alter any circuitry rather than having it
plain obvious, right under your nose. I am strongly of the
opinion that anything that increases the
workload/distraction factor in an emergency is a
thoroughly bad thing and leads to a lot of stall/spin
deaths.
Regards, David
On Mon, 7 Apr 2014 12:03:57 +0100
nigel_graham(at)m-tecque. Guest
Posted: Mon Apr 07, 2014 6:25 am Post subject: Parcel Shelf tray door access for fuses, CBS |
This is an interesting discussion.
If the aircraft wiring has been well designed and installed and if the
correctly rated breaker (or fuse) has been installed to protect the
desired equipment, then it is surely reasonable to suppose that the
only time the breaker would pop, or the fuse blow, is if something has
failed. No amount of in-flight fiddling is going to repair a shorted or
broken wire, nor replace a failed capacitor, resistor or semiconductor
(dare I mention Rotax/Ducati Regulator? ..... best not perhaps).
Re-setting a popped breaker without identifying why it popped is surely
asking for trouble. Do you wait for the first signs of smoke before
finally getting the message?
The only thing a pilot can do is recognise that a particular service has
gone down and, depending on flight criticality, divert or continue.
The only time to investigate the problem will be when you are safely
down as the cause will almost invariably be in an inaccessible place.
Popped breakers are easy to spot, but fuses are not immediately obvious
- unless you have chosen the ones that Rowland has used which
incorporate a "failure" LED.
This does of course require them to be mounted where you can see them
......which brings us back to the OP.
Nigel
On 07/04/2014 13:42, David Joyce wrote:
<davidjoyce(at)doctors.org.uk>
Rowland, I don't dispute the electrical safety. It is just the
distraction of having to dig around to make a diagnosis and alter any
circuitry rather than having it plain obvious, right under your nose.
I am strongly of the opinion that anything that increases the
workload/distraction factor in an emergency is a thoroughly bad thing
and leads to a lot of stall/spin deaths.
Regards, David
>> time etc. etc.
Fred Klein
Posted: Mon Apr 07, 2014 8:02 am Post subject: Parcel Shelf tray door access for fuses, CBS |
On Apr 7, 2014, at 4:03 AM, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
Rowland,
Thank you for the links to the Nuckolls articles which I haven’t read for a long time; they have been primary references for a guy like myself who’s knowledge, experience, and understanding of all things electric was close to zero when I began my project.
I’m very sympathetic to the Nuckolls philosophy(s) and have attempted to incorporate them at just about every turn, though some of his thinking may initially lead to component arrangements which seem counterintuitive.
You won’t find me re-setting CBs or fumbling around w/ replacement fuses while in flight.
FWIW, I’ve located two fuse blocks on the floor of the instrument panel module behind the COM sub panel; one buss is for engine critical circuits for my (totally electrically-dependent) MPEFI engine, and the other is for “endurance buss” circuits…both busses have a primary feed thru my EXP 2 Bus (w/ it’s multiple rocker switches controlling non-essential circuits) and an alternate feed direct from either battery.
At the first sign of in-flight electrical problems, my “Plan B” requires the flipping of one toggle to energize the alternate feeds for both my endurance buss and my engine buss; killing the master switch; and, with ample battery amp hours for the predetermined loads, proceeding to my destination without breaking a sweat…at least, that is the plan...
I offer these thoughts as simply describing how I’ve chosen to approach this issue, not as a challenge to other approaches or philosophies.
In fact, I relish these discussions and find enormous value in reading how much-respected and experienced builders have addressed these issues…more than once they’ve resulted in my reconsideration of previous solutions.
Fred
Posted: Mon Apr 07, 2014 8:52 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Thanks to everyone re input on fuses. I've got a bunch to think about.
Tony Renshaw
| Quote: | On 7 Apr 2014, at 2:16 am, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
Joyce, G-XSDJ
> in friendship
> Rowland
> Admin.
<IMG_0753.JPG>
dpark748(at)me.com Guest
Posted: Mon Apr 07, 2014 9:14 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Nigel,
Would i be correct, in the event of regulator failure, i am going to see?
1.over/under voltage on volt meter ?
2.main cb break?
3.Ameter indication - discharge?
Action - switch off alternator? And any unnecessary drain on battery.
Dave Park
[quote] On 7 Apr 2014, at 15:24, Nigel Graham <nigel_graham(at)m-tecque.co.uk> wrote:
If the aircraft wiring has been well designed and installed and if the correctly rated breaker (or fuse) has been installed to protect the desired equipment, then it is surely reasonable to suppose that the only time the breaker would pop, or the fuse blow, is if something has failed. No amount of in-flight fiddling is going to repair a shorted or broken wire, nor replace a failed capacitor, resistor or semiconductor (dare I mention Rotax/Ducati Regulator? ..... best not perhaps).
Re-setting a popped breaker without identifying why it popped is surely asking for trouble. Do you wait for the first signs of smoke before finally getting the message?
The only thing a pilot can do is recognise that a particular service has gone down and, depending on flight criticality, divert or continue.
The only time to investigate the problem will be when you are safely down as the cause will almost invariably be in an inaccessible place.
Popped breakers are easy to spot, but fuses are not immediately obvious - unless you have chosen the ones that Rowland has used which incorporate a "failure" LED.
This does of course require them to be mounted where you can see them .......which brings us back to the OP.
Nigel
> Rowland, I don't dispute the electrical safety. It is just the distraction of having to dig around to make a diagnosis and alter any circuitry rather than having it plain obvious, right under your nose. I am strongly of the opinion that anything that increases the workload/distraction factor in an emergency is a thoroughly bad thing and leads to a lot of stall/spin deaths.
> Regards, David
Posted: Mon Apr 07, 2014 10:02 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Hi Rowland
As an ex- CAA Licenced Avionic engineer I shudder at the use of Faston spade
terminals instead of ring tags and hate soldered joints and love crimps, but
many homebuilt aircraft have these features and fly quite safely.
Fuses vs circuit breakers is another one for the list. The joy of home
building is that we can make our own choices in this area, after carrying
out due diligence, and I respect your choice.
Beware- someone will now point out that fuses and circuit breakers are old
hat and we should all be using power control modules to monitor and protect
our aircraft electrics.
The subject of replacing fuses or resetting circuit breakers in flight is
also well covered in training manuals and flight manuals of certified
aircraft. Again, we can do our study and make our choices and be content
with our personal decisions.
Best regards
Brian
Posted: Mon Apr 07, 2014 10:57 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Dave,
The unit is a combination of rectifier and regulator. The issues you
experience will depend on which component in which part of the circuit
fails.
There are (as far as I can identify - though I'm sure better qualified
contributors will correct me if I'm wrong) three modes of failure.
If you are really lucky, it will fail open-circuit, in which case
everything continues to work fine but your battery discharges. The
ammeter will show a discharge.
If you're not so lucky, the regulator fails and sends unregulated DC to
your battery. This will eventually boil dry, get very hot and may
distort and if no over-voltage protection is fitted, take out your avionics.
If you're really unlucky and the rectifier section fails, this can
squirt unrectified AC into the main bus and kill just about everything
except your ignition.
Which CB breaks depends entirely on how your aircraft was wired up and
it is these failure modes that have caused such spirited debate when
discussing "the right way" to wire up a panel.
Nigel
On 07/04/2014 18:13, david park wrote:
Nigel,
2.main cb break?
Dave Park
> Nigel
>> Regards, David
Posted: Mon Apr 07, 2014 1:35 pm Post subject: Parcel Shelf tray door access for fuses, CBS |
Dave, For what it is worth when my standard Europa
supplied & wired rectifier failed, (over the Channel!),
the only thing that happened was that the ammeter showed
discharge directly related to how many bits of kit I left
switched on. Regards, David Joyce, G-XSDJ
On Mon, 07 Apr 2014 19:49:23 +0100
Dave,
The issues you experience will depend on which component
in which part of the circuit fails.
better qualified contributors will correct me if I'm
which case everything continues to work fine but your
battery discharges. The ammeter will show a discharge.
unregulated DC to your battery. This will eventually boil
dry, get very hot and may distort and if no over-voltage
fails, this can squirt unrectified AC into the main bus
and kill just about everything except your ignition.
was wired up and it is these failure modes that have
caused such spirited debate when discussing "the right
Nigel
><dpark748(at)me.com>
> Nigel,
>am going to see?
> 2.main cb break?
>drain on battery.
> Dave Park
> Sent from my iPhone
>> Nigel
>>>deaths.
>>> Regards, David
houlihan(at)blueyonder.co Guest
Posted: Mon Apr 07, 2014 2:15 pm Post subject: Parcel Shelf tray door access for fuses, CBS |
And thats exactly what happened when my regulator failed, The only unanswered question is why do these failures happen when there is 70 miles of sea to cross.
I have to thank the Europa club people who helped me when this happened, thanks guys
On 7 April 2014 22:35, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
[quote]--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Dave, For what it is worth when my standard Europa supplied & wired rectifier failed, (over the Channel!), the only thing that happened was that the ammeter showed discharge directly related to how many bits of kit I left switched on. Regards, David Joyce, G-XSDJ
Nigel Graham <nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)> wrote:
[quote] --> Europa-List message posted by: Nigel Graham <nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)>
Dave,
The unit is a combination of rectifier and regulator. The issues you experience will depend on which component in which part of the circuit fails.
There are (as far as I can identify - though I'm sure better qualified contributors will correct me if I'm wrong) three modes of failure.
If you are really lucky, it will fail open-circuit, in which case everything continues to work fine but your battery discharges. The ammeter will show a discharge.
If you're not so lucky, the regulator fails and sends unregulated DC to your battery. This will eventually boil dry, get very hot and may distort and if no over-voltage protection is fitted, take out your avionics.
If you're really unlucky and the rectifier section fails, this can squirt unrectified AC into the main bus and kill just about everything except your ignition.
Which CB breaks depends entirely on how your aircraft was wired up and it is these failure modes that have caused such spirited debate when discussing "the right way" to wire up a panel.
Nigel
[quote] --> Europa-List message posted by: david park <dpark748(at)me.com (dpark748(at)me.com)>
Nigel,
2.main cb break?
Dave Park
[quote] On 7 Apr 2014, at 15:24, Nigel Graham <nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk)> wrote:
This does of course require them to be mounted where you can see them ......which brings us back to the OP.
Nigel
Regards, David
Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> wrote:
[quote] --> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)>
Fred Klein
Posted: Tue Apr 08, 2014 8:27 am Post subject: Parcel Shelf tray door access for fuses, CBS |
Alfred…Exquisite…F.
On Apr 8, 2014, at 5:51 AM, A. Buess Aviatik <ykibuess(at)bluewin.ch> wrote:
| Quote: | Tony,
I followed also Bob N's philosophy and used circuit breakers only for the
regulators. Blown fuses need careful analysis which is only done after
landing. The attached picture shows the fuseholders of all three busses
underneath the picnic tray.
Regards, Alfred
Alfred Buess
CH-3700 Spiez, Switzerland
Europa XS HB-YKI, Ercoupe 415-E N94804
<IMG_0424.JPG>
europa471
Posted: Tue Apr 08, 2014 3:03 pm Post subject: Parcel Shelf tray door access for fuses, CBS |
Alfred
Great minds think alike. See attachment. I extended the front edge to
give the fuse blocks a little more headroom.
I´m still working on my wiring, also a disciple of Bob N, but no CB´s.
Using an overvoltage module which is resettable by switching off the power.
Lance Sandford in OZ
On 08/04/14 22:51, A. Buess Aviatik wrote:
| Quote: | Tony,
Regards, Alfred
Alfred Buess
59.69 KB |
13311 Time(s) |
51.92 KB |
13311 Time(s) |
64.16 KB |
13311 Time(s) |
