Engine out over KOCF
rnewman(at)tcwtech.com
PostPosted: Fri Apr 04, 2014 2:59 pm    Post subject: Engine out over KOCF Reply with quote
Fellow RV’s,
Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had
the opportunity to put all that engine-out training to work. The good news
first: This was the best case possible, no one hurt, no airplane damage,
flew the plane, declared emergency, landed on the paved runway, made the
first taxiway. Guardian angle working overtime!!
Now for the important details that I believe can have a positive effect on
others building or flying RV's.
Root cause of the engine failure was that the filtered airbox came off the
throttle body, wedged under the intake portion of the throttle body and
disrupted the airflow through the metering venturi. This caused the mixture
to go way out of wack as the engine went to an extreme rich condition, I saw
fuel flow rates pegged at >30 gph as soon as the event occurred.
My airplane is an RV-10 with a stock engine install and a stock cowling. I
have the Airflow Performance fuel injection system with a vertical mount
FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum
clamping doughnut to retain the filtered airbox assembly. This system does
not use safety-wired bolts on the filtered side of the airbox, just this
clamping doughnut. If the doughnut looses it's grip on the throttle body the
whole filtered airbox can slide downwards and fall off, in this case that is
exactly what happened. When we pulled the top cowling off, there in the
bottom sat the entire filtered airbox, clamping doughnut and all.
Now for the fix: The filtered airbox bolts are located right underneath the
mounting studs for the throttle body assembly. I simply replaced these bolts
with drilled head bolts and made some drilled coupling nuts to put on the
throttle body studs, there was plenty of extra threads exposed on these
studs so I didn't have to make any changes to the studs or the nuts that
hold the throttle body in place. Then just safety wire the whole thing
together. I used 0.040 wire to tie each filtered airbox bolt up to the
mounting studs. Below are pictures of the drilled nuts and the final
installation.
Obviously I would highly recommend that if you have an Airflow Performance
fuel injection system with a vertically mounted fuel servo you take a look
at your installation and consider adding some securing means to ensure this
thing can't come apart on your airplane. They key issue is that disrupting
the airflow inside the fuel servo can make the engine STOP RUNNING!
Lastly, I've collected the flight data out of my AFS EFIS system which I
just happened to have running at 2 second intervals. Its been very
instructive to see exactly how the whole event played out. I could see my
various attempts to get the engine to run properly by changing throttle
positions and the hopeless lack of actual power. You could see the excess
fuel just crater the EGTs, and now in hind sight I may have been able to get
some power back if I had the insight to try and close the mixture radically.
However, I can say with confidence my total focus after about 1 or so
minutes of trying to get power was on flying the plane to a safe landing....
mission accomplished.
Pictures attached are of the drilled retention nuts and the updated
installation.
Bob Newman
N541RV 200 hrs
 Filesize:  280.34 KB
 Viewed:  14715 Time(s)
 Filesize:  305.19 KB
 Filesize:  289.52 KB
dave.saylor.aircrafters(a
PostPosted: Fri Apr 04, 2014 3:49 pm    Post subject: Engine out over KOCF Reply with quote
Great work, Bob.  I'm happy to hear you did everything by the book--including PRACTICE.
And, I don't think that FAB is going anywhere any time soon!
Blue Skies,
Dave Saylor
831-750-0284 CL
On Fri, Apr 4, 2014 at 3:58 PM, Bob-tcw <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)> wrote:
[quote] Fellow RV’s,
Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!!
Now for the important details that I believe can have a positive effect on others building or flying RV's.
Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred.
My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all.
Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation.
Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING!
Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished.
Pictures attached are of the drilled retention nuts and the updated installation.
Bob Newman
N541RV 200 hrs
Bret Smith
PostPosted: Fri Apr 04, 2014 4:09 pm    Post subject: Engine out over KOCF Reply with quote
Bob, really, REALLY great to hear you made a safe landing! I have the AFS system on my IO-360 RV-9 but the setup is different. Have you called Don to discuss?
Bret Smith
N16BL
Bret Smith
RV-9A (Emp)
PostPosted: Fri Apr 04, 2014 4:39 pm    Post subject: Engine out over KOCF Reply with quote
I did contact Don at AFP. He said he hadn't heard of an airbox falling off and that the primary problem is that the vans cowling snout is too tight to the air box. He also suggested that some have come up with ways to secure the fab. That's about it.
Bret Smith
N16BL
Dick Sipp
PostPosted: Fri Apr 04, 2014 7:24 pm    Post subject: Engine out over KOCF Reply with quote
Great job Bob! Thanks for the report.
Dick Sipp
RV-10 535 hours
chasb(at)satx.rr.com
PostPosted: Sat Apr 05, 2014 7:08 am    Post subject: Engine out over KOCF Reply with quote
Great job and great report. No photos attached, however. Any chance of a url or a web site to show the photos?
Charlie Brame
RV-6A N11CB - with a vertical mount AFP fuel injection.
San Antonio
[quote]Time: 03:59:59 PM PST US
From: "Bob-tcw" <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)>
Subject: Engine out over KOCF
Fellow RVs,
installation.
installation.
Bob Newman
N541RV 200 hrs
PostPosted: Sat Apr 05, 2014 9:51 am    Post subject: Engine out over KOCF Reply with quote
The original listing had pictures when I posted it. Did anyone else see them?
Here’s a url to one of the pics I put on my google+ album.
https://lh3.googleusercontent.com/-36L4ELs0R10/Uz8rUckKBfI/AAAAAAAAUCE/Fu3xneaqtWQ/w769-h577-no/2014-04-03+13.22.23.jpg
Sent: Saturday, April 05, 2014 11:06 AM
To: List RV (Rv-list(at)matronics.com)
Charlie Brame
San Antonio
Fellow RVs,
installation.
installation.
Bob Newman
N541RV 200 hrs
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
bobbyhester(at)twc.com
PostPosted: Sat Apr 05, 2014 10:07 am    Post subject: Engine out over KOCF Reply with quote
Yes, they were there. All the way at the bottom.
Sent from my Verizon iPhone
On Apr 5, 2014, at 1:50 PM, "Bob-tcw" <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)> wrote:
[quote] The original listing had pictures when I posted it. Did anyone else see them?
Charlie Brame
San Antonio
Fellow RVs,
installation.
installation.
Bob Newman
N541RV 200 hrs
st"">http://www.matronics.com/Navigator?RV-List
//forums.matronics.com
TimRVator(at)comcast.net
PostPosted: Sun Apr 06, 2014 10:23 am    Post subject: Engine out over KOCF Reply with quote
An involuntary glider ride is no fun -- I'm glad you were able to land safely.  Thanks for sharing your experience (and the cause) with the group.
I'm confused by the safety wire shown in your photos (particularly the vertical runs of safety wire up to the coupling nuts).  Is your primary intent to safety the 4 drilled-head AN-3 bolts that penetrate down through the FAB aluminum cover?  If so, normal practice as I understand it would be to just safety wire those AN-3 bolts to each other in pairs (as shown in AC 43.13-1B, page 7-20, Figure 7-3, for example).
[img]cid:part1.00050504.09070001(at)comcast.net[/img]
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 500 hrs
Bob-tcw said the following on 4/4/2014 6:58 PM:
Fellow RV’s,
Bob Newman
N541RV 200 hrs
 Filesize:  111.83 KB
 Viewed:  14705 Time(s)
PostPosted: Sun Apr 06, 2014 11:15 am    Post subject: Engine out over KOCF Reply with quote
I second that, the vertical safeties are not needed and the wraps are not tight near the bolt heads. Refer to the drawings
On Apr 6, 2014, at 2:22 PM, Tim Lewis <TimRVator(at)comcast.net> wrote:
<iibijbca.png>
A&P
> Fellow RV’s,
> Bob Newman
> N541RV 200 hrs
ceengland7(at)gmail.com
PostPosted: Sun Apr 06, 2014 12:09 pm    Post subject: Engine out over KOCF Reply with quote
I've got no experience with that system, but I read the original post as
saying that the stock setup only uses a clamp around the inlet neck of
the throttle body to hold the airbox on the throttle body. I thought
that he was using the vertical runs of safety wire as a safety to keep
the airbox up if the clamp releases its grip (again).
> Bob,
> <iibijbca.png>
> Thanks,
> Tim
> A&P
>> Fellow RV’s,
>> Bob Newman
>> N541RV 200 hrs
PostPosted: Sun Apr 06, 2014 12:52 pm    Post subject: Engine out over KOCF Reply with quote
Charlie has it right. The whole point is to provide a safety means in the vertical direction. The clamping doughnut is below the filtered airbox plate and not visible in the picture. The four bolts that I safety wired to thread into the doughnut. I safety wired between the bolts to provide additional protection against them backing out. However, those four bolts could be removed and as long as the clamping doughnut remained tight the box can't come off. Lastly the vertical safety wire doesn't exactly need to be crazy tight as it would require about 3/4" of travel before the doughnut comes disengaged from the fuel servo.
Bob Newman.
On Apr 6, 2014, at 4:10 PM, Charlie England <ceengland7(at)gmail.com> wrote:
I've got no experience with that system, but I read the original post as saying that the stock setup only uses a clamp around the inlet neck of the throttle body to hold the airbox on the throttle body. I thought that he was using the vertical runs of safety wire as a safety to keep the airbox up if the clamp releases its grip (again).
>> Bob,
>> <iibijbca.png>
>> Thanks,
>> Tim
>> A&P
>>> Fellow RV’s,
>>> Bob Newman
>>> N541RV 200 hrs
