Instrument panel bolts
Fred Klein
PostPosted: Sun Mar 23, 2014 10:24 pm    Post subject: Instrument panel bolts Reply with quote
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Gidday,
I’m stuck and was hoping someone could resurrect my momentum. I need to know how long to make my instrument panel studs to accommodate a washer, possibly conical, and probably only on the cockpit side, as the other side should use either metal or phenolic washers. This means I am having permanent studs out the back of the panel, going through the firewall, and being secured on the engine compartment side of the firewall.
Tony…to get the benefit of vibration isolation, the SS 1/4” dia. McMaster-Carr vibration damping sandwich mounts do the trick…much better IMO than any kind of a thru bolt...see cat. pg.:
http://www.mcmaster.com/#vibration-damping-sandwich-mounts/=r882gh
...photo below shows the male threaded stud each side, and there is also a male / female style, 3 of which I used on the picnic tray STBD side along w/ SS machine screws and finish washers.
I found the 1/2” long studs to be just long enough to penetrate the firewall and to have room for a washer and stiff nut. Although a stickler will notice that I lack the requisite visible threads beyond the face of the nut, I do not consider that to be critical in this instance.
Fred
[img]cid:27B51E29-A9CE-43FB-B5F4-14D977691866[/img]
[img]cid:B812DA72-EF2B-4BD4-BC88-4A4A9C6ED6F1[/img]
[img]cid:4EAA7EC2-EDA9-4F8F-B4E0-3EC44DAE7FC2[/img]
[img]cid:E24D7FE9-60F4-4C46-887A-BA67F8B3A11A[/img]
 Filesize:  55.36 KB
 Viewed:  1742 Time(s)
 Filesize:  63.9 KB
 Filesize:  84.96 KB
 Filesize:  62.87 KB
richard collings
PostPosted: Mon Mar 24, 2014 12:41 pm    Post subject: Instrument panel bolts Reply with quote
Hi
I used metallastic rubber bushes to mount the whole unit onto the fire wall having first made an internal mounting flange on the instrument panel module. I reduced the original outer flange to about 10mm and once mounted in place the thickness of the rubber of the metalastic bush gave me an air gap for ventilation . To reduce the modules movement I added one bush as a support from the top of the wheel tunnel just in front of the throttle quadrant.
best of luck
Richard
Sent: Monday, March 24, 2014 6:22 AM
Subject: Instrument panel bolts
Gidday,
Fred
[img]cid:D39B14AE35AF4270B6A915BF086E9DAE(at)RichardHP[/img]
[img]cid:BED47A1F04064E65A81F8D04198781E2(at)RichardHP[/img]
[img]cid:18040187CF854003A190DFE9B949F7FA(at)RichardHP[/img]
[img]cid:0758E86A25C54507836CBBCDBDE8E74E(at)RichardHP[/img]
Checked by AVG - www.avg.com
Version: 2014.0.4336 / Virus Database: 3722/7237 - Release Date: 03/23/14
 Filesize:  55.36 KB
 Viewed:  1713 Time(s)
 Filesize:  63.9 KB
 Filesize:  84.96 KB
 Filesize:  62.87 KB
