rvdave
Posted: Mon Mar 24, 2014 5:50 am Post subject: Lightspeed crank and ignition wire routing |
Finishing up baffling and looking to route Lightspeed crank sensor cable and lower spark plug wire through baffling. First is whether to go above or below engine with crank sensor and where to penetrate firewall? I have dual so wondering about running them together.
Next how to get lower plug wire to bottom plug from coil on top of engine--maybe silicone grommet thru baffling?
_________________ Dave Ford
Cadillac, MI |
Posted: Mon Mar 24, 2014 6:59 am Post subject: Lightspeed crank and ignition wire routing |
Mount the coils for the bottom plugs behind the engine baffle on the engine
mount via adle clamps, not on top of the engine. Mount the top plug coils
on top of the engine. This simplifies the coil to plug wiring.
Carl
rvdave
Posted: Mon Mar 24, 2014 10:56 am Post subject: Re: Lightspeed crank and ignition wire routing |
That may be the best way--will have to get longer HV leads if I do that though.
How about the crank sensor leads--cross over under the engine then run parallel to firewall?
Cadillac, MI |
hotwheels
Posted: Mon Mar 24, 2014 11:40 am Post subject: Re: Lightspeed crank and ignition wire routing |
Photos attached. I have dual LSE. RG400 coming out of top portion of firewall are high tension coil wires. The bottom coils are attached to the engine mount. The top coils are attached to the engine case. Crank sensor wires route across the co-pilot side beneath the oil returns. I used both adel clamps and RTV where required. The most important thing is to run the RG400 coil wires separate from the sensor wires.
Jay
433RV - flying
27.86 KB |
18187 Time(s) |
28.08 KB |
18187 Time(s) |
25.48 KB |
18187 Time(s) |
26.62 KB |
18187 Time(s) |
rvdave
Posted: Mon Mar 24, 2014 4:03 pm Post subject: Re: Lightspeed crank and ignition wire routing |
Looks good, one other thing--how about exiting the flywheel, how specifically do you route and mount the sensor wires to get the clearance from rotating flywheel? Do you mount an adel clamp to the sensor circuit board also?
Cadillac, MI |
Dick Sipp
Posted: Mon Mar 24, 2014 5:12 pm Post subject: Lightspeed crank and ignition wire routing |
The area where the sensor wires exit behind the flywheel has always bothered
me. I think I laced them together and clamped them as close to the bottom
seam of the case as possible and then back under the cyls. in a bundle with
some other engine sensor wiring. No problems at 550 hours.
An unrelated observation is that the advance at cruise power is always
within a degree or two of 25 same as the mag. That is unless I get to power
settings below about 60% such as above 10,000 or lower than normal manifold
pressures. I would really like to have two PMAGS if they would ever finish
work on them.
Dick
RV-10, RV-4, RV-12
hotwheels
Posted: Tue Mar 25, 2014 6:30 am Post subject: Re: Lightspeed crank and ignition wire routing |
Just tie them together and route under along the case using clamps and/or RTV. It's very secure. The part that me pucker was drilling holes in the case behind the flywheel to mount the LSE sensor. YMMV with newer LSE sensors.
Jay
23.09 KB |
18151 Time(s) |
rv10flyer
Posted: Thu Mar 27, 2014 4:11 am Post subject: Re: Lightspeed crank and ignition wire routing |
Dick,
"An unrelated observation is that the advance at cruise power is always
within a degree or two of 25 same as the mag."
What are the advantages/disadvantages compared to my stock Slicks? With your hours it would be almost time to ovhl mags if you had them. Any problems so far with LS? Thank you or anyone else for feedback.
Wayne 128 hrs.
10.5 gph 155-160 kt cruise
_________________ Wayne G. |
rvdave
Posted: Thu Mar 27, 2014 8:40 am Post subject: Re: Lightspeed crank and ignition wire routing |
I'm at the beginning of learning curve re lightspeed but according to what I read in the manual, with mp connected timing should be around 40* and with mp disconnected should be about 25*. Is this true for cruise configuration or will it continually be changing with altitude, rpm, throttle, etc?
Cadillac, MI |
Kelly McMullen
Posted: Thu Mar 27, 2014 3:10 pm Post subject: Lightspeed crank and ignition wire routing |
Obviously timing has to be inversely proportional to manifold pressure. The higher the MP the closer timing must be to the nominal 25 degrees.
On Thu, Mar 27, 2014 at 9:40 AM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=421148#421148
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Dick Sipp
Posted: Thu Mar 27, 2014 5:51 pm Post subject: Lightspeed crank and ignition wire routing |
I believe the advantage is somewhat improved economy at lower power
settings, perhaps easier starts, (I start on the LS which fires at TDC
during start).
I've had no issues with the LS. I'll have to check the manual again, I
think the 40 degrees with the manifold pressure disconnected must only be
set point, I never see anywhere near that in operation.
Dick
Kelly McMullen
Posted: Thu Mar 27, 2014 7:12 pm Post subject: Lightspeed crank and ignition wire routing |
How much advance you see will depend on your power setting. If you reduce power to say 50 percent while in descent, you might see 40 degrees.
On Thu, Mar 27, 2014 at 6:50 PM, Dick & Vicki Sipp <rsipp(at)earthlink.net (rsipp(at)earthlink.net)> wrote:
[quote] --> RV10-List message posted by: "Dick & Vicki Sipp" <rsipp(at)earthlink.net (rsipp(at)earthlink.net)>
I believe the advantage is somewhat improved economy at lower power settings, perhaps easier starts, (I start on the LS which fires at TDC during start).
I've had no issues with the LS. I'll have to check the manual again, I think the 40 degrees with the manifold pressure disconnected must only be set point, I never see anywhere near that in operation.
Dick
KCHD |
Dick Sipp
Posted: Thu Mar 27, 2014 7:32 pm Post subject: Lightspeed crank and ignition wire routing |
Thanks Kelly, I am going to pay more attention to the advance settings which I can read in the cockpit; you have peaked my interest. My experience in cruise does not indicate significant advance increases. That’s probably a good thing.
Dick
Sent: Thursday, March 27, 2014 11:11 PM
Subject: Re: Re: Lightspeed crank and ignition wire routing
Dick
rvdave
Posted: Fri Mar 28, 2014 3:50 am Post subject: Re: Lightspeed crank and ignition wire routing |
Dick how are you reading the timing advance, do you have the Lightspeed display?
Cadillac, MI |
rvdave
Posted: Fri Mar 28, 2014 3:56 am Post subject: Re: Lightspeed crank and ignition wire routing |
Cadillac, MI |
Dick Sipp
Posted: Fri Mar 28, 2014 6:01 pm Post subject: Lightspeed crank and ignition wire routing |
Yes, the Lightspeed display module.
