Posted: Tue Mar 18, 2014 2:08 pm Post subject: Picking the Matronics List's brain. |
On 3/17/2014 7:56 PM, Steven DeFord wrote:
| Quote: | I realize that it's a bit early for me to be making some of these decisions, since I'm still only about halfway through the Emp kit, but I was wondering how people had done some of the following:
1) Oxygen: With the lovely ceiling (and good IFR performance), I'd like to mount some sort of oxygen system. Assuming I want to keep the bottle portable, and not have to get oxygen service by a truck through the side of the aircraft, where have people mounted the bottle so as to be reasonably accessible?
| I fabricated a fiberglass center console that fully encloses an Aerox tank and fittings. The tank can be removed in 2 minutes or the whole console, with or without the tank, even faster. The best part is the console supplies a mounting point for a RAM iPad mount. See it all here:
Kitlog Entry for O2 Console
2) Fuel: Unless running LOP (not sure how I'll be doing it), 60 gallons is a bit shy for my purposes (would like 5h range + 1h reserve). I've considered adding a bit of fuel tubing in the tunnel to be able to hook up a ferry tank to sit in the back seat, since the 15 gal wingtip slide-in tanks don't carry quite enough, and I'm afraid to put significantly more weight in the wings that they weren't designed for (vs. the cabin). Other solutions?
| I plan for 5 hours including reserves with the stock setup. That's over 600NM not including a 1 hour reserve. Plan to run LOP. The tuning is cheap (high ROI) and easy with Airflow's restrictors and anyone's engine monitor.
3) Aileron trim: The -10 comes with pitch trim, and it's probably adequate to just use an adjustable bungee for rudder trim, but do people put in aileron trim, and if so, have they used it much? It seems like the general consensus on the websites is "Don't bother."
| I have aileron trim, barely use it but recommend it. Easy to put in during the build. More of a pain post construction. I don't have rudder trim, didn't miss it, but as my time in the rudder-centric Maule falls by the way side, I'm beginning to like the idea of some kind of rudder trim.
Bill "it flies really really well the way it was designed" Watson
Bob Turner
Posted: Tue Mar 18, 2014 5:01 pm Post subject: Re: Picking the Matronics List's brain. |
Keep in mind that a tank behind the bulkhead may limit baggage at full loads due to aft cg.
_________________ Bob Turner
RV-10 QB |
Jim Berry
Posted: Tue Mar 18, 2014 6:38 pm Post subject: Re: Picking the Matronics List's brain. |
| Bob Turner wrote: | | Keep in mind that a tank behind the bulkhead may limit baggage at full loads due to aft cg. |
I have the carbon fiber MH bottle. While I have never calculated its impact on CG, I suspect it is much less than the tools, parts and survival gear I routinely carry. But you have a valid point.
