frans(at)privatepilots.nl Guest
Posted: Fri Mar 14, 2014 2:15 am Post subject: oil |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi,
It is time for an oil change again. However, the oil I always used is
no longer available.
The oil I used was Shell Advance VSX 4T. This was a Rotax approved
oil, suitable for leaded and unleaded fuel. There is a replacement for
this oil, the Shell Advance AX7, but I'm not sure whether this is just
a name change or a formula change.
So, what kind of oil are the rest of us using? Any recommendations?
Anyone who kan tell me whether the Advance AX7 is just a name change?
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=UXv/
-----END PGP SIGNATURE-----
Ivor Phillips
Posted: Fri Mar 14, 2014 3:55 am Post subject: oil |
Hi Frans
Like you I use the VSX 4 T but now use the shell AX7. It the same oil with slight improvements supposedly ,
BTW are you going to the Rotax meet at Wels this June ?
Ivor
| Quote: | On 14 Mar 2014, at 10:10, Frans Veldman <frans(at)privatepilots.nl> wrote:
Hash: SHA1
Hi,
Frans
=UXv/
budyerly(at)msn.com Guest
Posted: Fri Mar 14, 2014 5:19 am Post subject: oil |
Guys,
Aeroshell Sport plus 4 is the Rotax approved oil we use in the States, which is a semi-synthetic for use with AV gas. I get it from Lockwood for less than $10 a quart. It is quite good at suspending the lead. However, can you get it over there?
For unleaded fuel I still prefer Mobile One MX4T or now called Racing T. My turbo responds well with it.
Bud
| Quote: | Subject: Re: oil
Date: Fri, 14 Mar 2014 11:53:53 +0000
--> Europa-List message posted by: Ivor Phillips <ivor.phillips(at)ntlworld.com>
Hi Frans
Ivor
> --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl>
> Hash: SHA1
> Hi,
> Frans
> =UXv/
Posted: Fri Mar 14, 2014 12:03 pm Post subject: oil |
Hash: SHA1
On 03/14/2014 12:53 PM, Ivor Phillips wrote:
Hi Frans Like you I use the VSX 4 T but now use the shell AX7.
It is a bit confusing. I have seen the AX7 advertised as being fully
synthetic, whereas the VSX was half synthetic. Full synthetic oils
have difficulties with the lead content of AVGAS and are therefore
unsuitable for my purpose. My supplier sent me Advance Ultra which is
supposed to be superior (and much more expensive) but in the Rotax
service bulletin it was indicated as unsuitable for use with AVGAS fuel.
So, this is why I'm concerned about the successor AX7 oil. If you can
confirm that it is indeed basically the same as the predecessor VSX
and still half synthetic I'm happy to use it.
| Quote: | BTW are you going to the Rotax meet at Wels this June ?
That is unlikely. I even didn't know about this meeting but I have
quite a busy schedule this saison.
I will probably see you at one of the other events.
BTW the place you recommended to go to was Scilly was it?
Best regards,
Frans
| Quote: | Regards Ivor
Hi,
is no longer available. The oil I used was Shell Advance VSX 4T.
This was a Rotax approved oil, suitable for leaded and unleaded
fuel. There is a replacement for this oil, the Shell Advance AX7,
but I'm not sure whether this is just a name change or a formula
change. So, what kind of oil are the rest of us using? Any
recommendations? Anyone who kan tell me whether the Advance AX7 is
just a name change?
Frans
iQIcBAEBAgAGBQJTI19qAAoJEC+zXxqs0ZzVt+gQAMbxwwEEVa5YWfStQaiTjeA/
sEkduMu7QkGFLuVI59I6aSSHETpKEku1xFQgeMCmVWnenvgqTVDBfNcgSBjD/3Wz
QwdsoMxC3krpoO2RzQxfsNFMwtkkjfHIRsv/gbhzjaLjcBN/xY2dcVPtagK8n1RX
SbK3bwZjjyft6Io1KkLc1TpGeWI2gpDyOznWTAL1+R+lPRSKZjaTlTmVgAjvtBUe
CvYBzbZDPRSW0W6KkeljUoNBrOaeduOWexVhzzBq6c+Jk8AMb+AMoKzy87MwecS8
M6kS1x3HIvjOR5RoMOu3KjcE+iaPRL/0iOINX7s0zOtM75Toi7wUyEFuxsav+ElY
fQokqlconLjX6H0GZVqv4ABFh8XgslnMvyrgT7es80qx5zbxXzykzubgY7YxtCaq
x2RZcoWPL6v+FgO7qJMx+lREudMQCXWP4pCDnP0fQVaq5Vupz+LCMjOEaIu86IpJ
CanbHJTPMW6WlspPWi9fVNC3PX7S1fEMsDe7F+O4NvskdBVHWMsaVp1rFKhLNdk1
uyQBpAVb+Hwo+7FHlv37YrPWOqV3JLqstzeBlqvJeoC/7mwzG4srO9koly1nYbdj
uf7AR8yEzsC1l+32X8Qz016Vt6YJmA9veu9e3TilgiUdMv+HS0smsXub/4f4whje
+d5AMaipofoPgjH8xYRJ
=TS+2
Ivor Phillips
Posted: Fri Mar 14, 2014 1:28 pm Post subject: oil |
Hi Frans
As you can see from the labels it a semi synthetic oil and it's previous name was vsx 4
Yes the Scillies Isle is a great place to visit, St Mary's is the main island with a interesting approach, you will need PPR and the airfield is shut on Sunday,
bob and me flew into helgoland last year on your recommendation and really had a good time
Will try for a revisit some time soon,
Ivor
| Quote: | On 14 Mar 2014, at 19:58, Frans Veldman <frans(at)privatepilots.nl> wrote:
Hash: SHA1
Best regards,
Frans
> Regards Ivor
> Sent from my iPad
> Hi,
> just a name change?
> Frans
=TS+2
2.3 MB |
5214 Time(s) |
1.97 MB |
5214 Time(s) |
kingsnjan(at)westnet.com. Guest
Posted: Fri Mar 14, 2014 5:59 pm Post subject: oil |
| Quote: | For unleaded fuel I still prefer Mobile One MX4T or now called Racing T. My turbo responds well with it.
Bud,
Could you kindly let me know what you mean by 'turbo responding well with it' please. ie, the Mobil oil as opposed to the Shell Sport Plus 4 that I am using.
Cheers
Kingsley in Oz
