Europa glider tug
flyingphil2
PostPosted: Wed Mar 05, 2014 2:51 am    Post subject: Europa glider tug Reply with quote
Further to an earlier posting, does anyone have any information or photos of the Europa being used as a glider tug in Germany?
It struck me at the last LAA rally that pretty much anything with wings and a 912S was being promoted as a glider tug and trying to tap into the Eurofox success.
I'm guessing that cooling could be a big issue on the Europa though?
Phil
paul.the.aviator(at)gmail
PostPosted: Wed Mar 05, 2014 5:35 am    Post subject: Europa glider tug Reply with quote
Phil
I believe that Erich Trombley visited with Walter Binder in Germany a couple of years back.  He might have some pictures.
Paul
erichdtrombley(at)juno.co
PostPosted: Sun Mar 09, 2014 6:00 pm    Post subject: Europa glider tug Reply with quote
Phill, pictures attached. I hope you find them to be of value.
Erich
N288ET Classic mono 914
____________________________________________________________
How to Stay Asleep All Night
Try this one weird trick to put your sleep troubles to rest.
peaklife.com
 Filesize:  178.81 KB
 Viewed:  5970 Time(s)
flyingphil2
PostPosted: Mon Mar 10, 2014 7:48 am    Post subject: Re: Europa glider tug Reply with quote
Hi Erich,
Many thanks for posting the images. Very useful.
Phil
PostPosted: Thu Mar 13, 2014 12:16 pm    Post subject: Europa glider tug Reply with quote
Hi Bruno,
Would you happen to know how Walter Binder achieved putting fuel tanks in the wings ?  In particular did he substitute the Blue for something impervious to fuel ?
Paul
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTREITH
Sent: Thursday, March 6, 2014 6:09 AM
Subject: AW: Europa glider tug
Hi Phil,
Walter Binders plane D-EPWB is a Classic Monowheel Kit 149 with Wing Fuel Tanks, elect. Retractable Outrigger Legs and a Tail Wheel with a mounting plate on top for the tow clutch. I am not quite sure if this was from an old Cessna Taildragger or a Husky.
He is using his own landing strip for towing the smaller glider he is manufacturing.
He also manufactures the EB 28 /29. Some years ago he had to use a parachute by test flying.
Binder Motorenbau GmbH
Alter Frickenhäuser Weg 15
D-97645 Ostheim v. d. Rhön
Vertreten durch die Geschäftsführer Walter & Oliver Binder
Tel.: +49(0)9777 - 92 00
Fax: +49(0)9777 - 92 01
www.binder-flugmotorenbau.de
097779200(at)t-online.de (097779200(at)t-online.de)
I am sure that he can help you with some information.
Best Regards,
Bruno Reith /EA-Germany Partner
grahamsingleton(at)btinte
PostPosted: Thu Mar 13, 2014 3:11 pm    Post subject: Europa glider tug Reply with quote
Paul, Bruno
There's another German builder whose name I forget, lives just North of Hamburg and recently did his first flight.
He copied Walter Binder's wing design wrt the outriggers. He probably knows how Walter did the tanks
I visited him once years ago with Norbert Hoffmann, (Norbert has died sadly)
Graham
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Sent: Thursday, 13 March 2014, 20:15
Subject: RE: Europa glider tug
Hi Bruno,
Paul
Hi Phil,
Best Regards,
[quote] ank" href="http://www.matronics.com/Navigator?Europa-List">http://www.mat"nofollow" target="_blank" href="http://forums.matronics.com/">http://f==========
