tonyrenshaw268(at)gmail.c Guest
Posted: Sun Mar 02, 2014 6:31 pm Post subject: Rudder Pedal Step Stretching |
Gidday,
Ive heard it mentioned that to extend this step back a bit might make things more comfortable. Can I get an input on what dimension is recommended? Ive heard about 75 mm would do it, and I will probably build it into my floor mat mod that I want to do.
Thanks.
Tony Renshaw
Sydney Aussie
spcialeffects
Posted: Mon Mar 03, 2014 3:41 am Post subject: Rudder Pedal Step Stretching |
Hi Craig and co.
I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5 9 or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea???
TR
On 3 Mar 2014, at 10:00 pm, craig <craigb(at)onthenet.com.au> wrote:
[quote] Yes tony, you can take about 75mm off, I worked out where the mounts were
going to be then cut it back
To leave about 15mm past the end of the rearmost mounts
gholland(at)content-strea Guest
Posted: Mon Mar 03, 2014 3:51 am Post subject: Rudder Pedal Step Stretching |
Tony
I made some heel rests without all that work. When I get home tonight I'll see if I can find photos.
Used aluminium 'rice' plate. Very light and bendable.
Gerry
[quote] On 3 Mar 2014, at 11:40, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Hi Craig and co.
I want to put 75 mm onto the shelf, bringing it aft into the footwell, to give me a place for my heels. Is that a dumb idea because only being 5β 9β or 175 cm, I think my legs will easily fit, and I imagine because of the upright nature of the pedals at neutral, that it might be nice to build a heel support. Bad idea???
TR
Posted: Mon Mar 03, 2014 3:55 am Post subject: Rudder Pedal Step Stretching |
hi Gerry,I have no clue what aluminium rice plate is. Look forward to the photos.
Thanks.
TR
On 3 Mar 2014, at 10:50 pm, Gerry Holland <gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)> wrote:
[quote]--> Europa-List message posted by: Gerry Holland <gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)>
Tony
Gerry
[quote]On 3 Mar 2014, at 11:40, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Hi Craig and co.
TR
[quote]On 3 Mar 2014, at 10:00 pm, craig <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)> wrote:
ptag.dev(at)talktalk.net Guest
Posted: Mon Mar 03, 2014 4:09 am Post subject: Rudder Pedal Step Stretching |
IMHO Bad idea . I just put a piece of 1.5" "I" section aluminium across the
footwell step and it works for me and I'm 5'9" and on a long flight you will
need to practice "walking" with as much room as you can have to prevent the
onset of cramp in the legs.
Also keep your knee from being near the draught vent more cause for cramp!
After a 4hour 30 minute flight to Krems Vienna My choice was to pretend
walking like hell or choose landing along or across vineyard wires on fields
as for as the eye could see, with tears streaming down my face. Also dose up
on a good layer of Quinine tablets !
Bob H G-PTAG
Posted: Mon Mar 03, 2014 4:19 am Post subject: Rudder Pedal Step Stretching |
Hi Bob,
I know what an "I" section is, but I just can't imagine what you mean. If you said "L" shape, to protect the Trailing edge of the rudder pedal attachment shelf, I would have been with you, but I'm a tad lost.
Tony R
[quote] On 3 Mar 2014, at 11:09 pm, "Bob Harrison" <ptag.dev(at)talktalk.net> wrote:
Bob H G-PTAG
Posted: Mon Mar 03, 2014 4:40 am Post subject: Rudder Pedal Step Stretching |
Tony .......if you imagine the web of the "I" section being used to bolt
about 9" of the section on to aft side of the step you have about an inch
flange laying on top of the step and an inch flange protruding into the foot
well space. Against which you can push all your weight to lever yourself up
the seat back to get out by standing then on the seat without stressing the
floor or anywhere else. Sorry I can't get to the plane to submit a photo at
present.
Bob Harrison G-PTAG
Posted: Mon Mar 03, 2014 6:31 am Post subject: Rudder Pedal Step Stretching |
Tony ..........I'm sorry I have had a brain storm I meant "T" section .
Probably that will help you get your mind round what I am saying ! I may
get a photo put up to you direct by this evening
Regards and sorry ..
Bob Harrison G-PTAG
kevinmarie(at)blueyonder. Guest
Posted: Mon Mar 03, 2014 8:31 am Post subject: Rudder Pedal Step Stretching |
TR
I am 5'8" (short) and have the standard rudder pedals setup. I have never found it uncomfortable.
Kevin Challis
Hi Craig and co.
TR
