Elevator Limits
schmoboy
PostPosted: Wed Feb 26, 2014 7:50 pm    Post subject: Elevator Limits Reply with quote
I'm in the process of adjusting my pushrods and elevator stops for panel
clearance and travel limits. I've reviewed all the archived posts on
adding stops and other techniques for getting panel clearance. I think
I have a good handle on that.
What I was curious about is the travel limits of the elevator. In
particular the elevator up limits. I assume that because of the nose
heavy aspect of the RV-10 that one would want to make sure that the up
travel limit of the elevator is at the higher end of the limits? I'm
imagining that with the loading at the forward most CG you'd want max
throw there for landing flare?
I know I am going to have to add a stop to prevent panel interference,
but as that only effects the down travel, as long as I am at or above
the elevator down limit of 20 degrees I should be fine? I'm imagining
the down limit being important for stall recovery and with the
relatively easy stall recovery of the rv-10 that the lower limit of 20
degrees is ok?
So long story short, is it better to be at the higher side of the up
elevator limits and ok to be at the lower side of the down limits?
-Sean #40303 (light at the end of the tunnel phase)
davidsoutpost(at)comcast.
PostPosted: Wed Feb 26, 2014 8:19 pm    Post subject: Elevator Limits Reply with quote
Mine were adjusted per plans when I built. I am in Phase 1 testing and found last week when I was loaded up forward CG, I had trouble getting the nose up in the landing flair. I used full up elevator trim to help but still landed three point. Part of the reason is I have short legs and like the seat track pin in the third position aft of front. With the big rotary knob on the Crow seat belt harness, the stick grip hits that first and can not go to the full aft stop limit. I adjusted the control tube for more nose up authority in this position however I am going to come up with pedal extensions to get the seat further back.
Sent: Wednesday, February 26, 2014 10:49:11 PM
Subject: Elevator Limits
--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com>
degrees is ok?
jmjones2000(at)mindspring
PostPosted: Wed Feb 26, 2014 8:59 pm    Post subject: Elevator Limits Reply with quote
Has anyone looked at adding ballast back by the tail? or how about moving the battery further aft? Seems that this issue can also be remedied with a further aft CG. Even a LB or two ballast in the tail can make a HUGE difference! Obviously do the W&B calculations, but you may be able to add a negligible amount of weight to the airframe in the tail section and make it work for you. I am sure it has much more docile handling when the CG is further aft.
Safe flying!
On Feb 26, 2014, at 7:19 PM, David Clifford <davidsoutpost(at)comcast.net (davidsoutpost(at)comcast.net)> wrote:
[quote]Mine were adjusted per plans when I built. I am in Phase 1 testing and found last week when I was loaded up forward CG, I had trouble getting the nose up in the landing flair. I used full up elevator trim to help but still landed three point. Part of the reason is I have short legs and like the seat track pin in the third position aft of front. With the big rotary knob on the Crow seat belt harness, the stick grip hits that first and can not go to the full aft stop limit. I adjusted the control tube for more nose up authority in this position however I am going to come up with pedal extensions to get the seat further back.
From: "Sean Stephens" <sean(at)stephensville.com (sean(at)stephensville.com)>
degrees is ok?
charliewaffles
PostPosted: Wed Feb 26, 2014 9:14 pm    Post subject: Re: Elevator Limits Reply with quote
The mothership runs with ballast in the baggage compartment most of the time. I have a bag with 20lbs of Shot in there now. I started with 40lbs, for solo work, but since I have added a survival/maintenance bag that weight 20lbs, I reduced the shot. Definitely helps with the landing flare. Some people use water jugs as they can just be dumped out and refilled as needed if the scenario dictates a change at a remote location.
Dick Sipp
PostPosted: Wed Feb 26, 2014 9:35 pm    Post subject: Elevator Limits Reply with quote
An item that has not been mentioned so far is the flap position for landing.
With a forward cg (solo or two light front seat passengers) a half flap landing can be more comfortable, full up trim probably not required in this configuration.
I use full flaps on landing 95% of the time. I always have 15 lbs. or so in the back of the baggage compartment. This does require (in my airplane) full up trim and about 2-3 pounds aft stick pressure to hold 65-70 KIAS on final. Full aft stick on roll out to hold the nose off does not require unusual aft pressure.
I rigged the elevator as best I could to the factory spec limits. Standard 4 point harness, no crotch strap (control stop is limiting). I have always felt a concern for any airplane that had something limiting the controls other than the design stops (i.e. panel or other obstruction). All of the airplanes will be different to a degree based on empty CG.
Oh, on takeoff like Van says, I use half flap on all the RVs. It’s cool to get off the runway before anybody else accept the Alaska bush guys.[img]cid:2410D527097F4A709EB24B813889C330(at)DickPC[/img]
Dick Sipp
RV4 750 hours sold
RV12 50 hours built for friend
RV10 530 hours and counting
From: David Clifford (davidsoutpost(at)comcast.net)
Sent: Wednesday, February 26, 2014 11:19 PM
Subject: Re: Elevator Limits
degrees is ok?
 Filesize:  1.12 KB
 Viewed:  14735 Time(s)
PostPosted: Wed Feb 26, 2014 9:58 pm    Post subject: Elevator Limits Reply with quote
You bring up a good point on flap position. The less flaps one has in, the higher the angle of attack will be to produce the same amount of lift. The catch with this is runway length. I fly C-130s and on our no flap landings are fast and we have to be careful not to strike the tail on landing during the flare. The extra speed and higher angle of attack is required to produce enough lift. This being said, keep an eye on your runway length required if you intend on using low or no flap settings.
Remember that there are some cracks that Vans is tracking in the RV8 series horizontal stabilizers. Some owners are finding this but most are not. Be sure to take into account the stress that the stabilizer will see. It is an inverted wing and has stresses as such during all phases of flight.
I am building a bush caddy L164 for the bush in Alaska. Slow flying bird with huge amounts of lift. The takeoff run at a max gross of 2550 is just 200 feet! Light takeoffs are shorter.
On Feb 26, 2014, at 8:35 PM, Dick & Vicki Sipp <rsipp(at)earthlink.net (rsipp(at)earthlink.net)> wrote:
[quote] An item that has not been mentioned so far is the flap position for landing.
Oh, on takeoff like Van says, I use half flap on all the RVs. It’s cool to get off the runway before anybody else accept the Alaska bush guys.<wlEmoticon-smilewithtongueout[1].png>
Dick Sipp
RV4 750 hours sold
degrees is ok?
PostPosted: Wed Feb 26, 2014 10:17 pm    Post subject: Elevator Limits Reply with quote
No Kidding. This is phase one TESTING!
From: "Justin Jones" <jmjones2000(at)mindspring.com>
Sent: Wednesday, February 26, 2014 11:57:04 PM
Safe flying!
degrees is ok?
get="_blank" data-mce-href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
ta-mce-href="http://forums.matronics.com">http://forums.matronics.com
_blank" data-mce-href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
Bob Turner
PostPosted: Wed Feb 26, 2014 11:31 pm    Post subject: Re: Elevator Limits Reply with quote
I have the seat in the second from the front notch, and aft stick is limited by the control stop - not me or the seat belt. Anything limiting control throw is just not acceptable to me.
I carry 20 lbs of water in the baggage area when flying solo. Doubles as emergency supply, and easy to pour out if I take on rear seat passengers.
Always check c.g. at zero fuel. If you're at the limit at takeoff you'll be out of limits on landing. Vans just gives you an average moment arm for the front seats, but I calculate cg using the actual seat location.
BTW, not trimming full nose up will give you a bit more nose up elevator authority; of course, it will take more force on the stick.
Bob Turner
RV-10 QB
Mauledriver(at)nc.rr.com
PostPosted: Thu Feb 27, 2014 4:53 am    Post subject: Elevator Limits Reply with quote
Like so many others with custom panels, I had panel interference as
well. Why wouldn't the preferred approach be to modify the stick (or
panel) so that you have full stop to stop travel? (I know you aren't
asking this but had to say it).
Anyway, I've flown at both ends of the CG range. I have more pitch down
authority than I need in any maneuver I can imagine. With the CG at the
forward limit and full flaps, I can land, power off, with the stick at
the limit though the forces become so high that the moment I hit the
stop is hard to detect. When trimmed for final approach, pitch forces
in the flare go from light to very heavy in a nose heavy configuration.
A perfect setup in my estimation.
This was quite satisfying after flying my old Maule. In the Maule, when
forward loaded (nothing in back), it was easy to run out of pitch
authority in a power off flare. A bit of power was required to arrest a
slow and steep approach or else. Not a good situation - definitely a
dark spot in it's flying qualities. Not so in the '10. So I'd say you
need full pitch up authority.
panel clearance and travel limits. I've reviewed all the archived
posts on adding stops and other techniques for getting panel
clearance. I think I have a good handle on that.
degrees is ok?
flying-nut(at)cfl.rr.com
PostPosted: Thu Feb 27, 2014 5:27 am    Post subject: Elevator Limits Reply with quote
Since I'm still building my comment may not be -10 specific. I agree with Bill .... how many of us need full forward stick (panel or no panel)? I hope none of us will try an outside loop or fly inverted in an airplane that's not certified for aerobatics. Bending the stick so it can hit the forward stop instead of the panel has been discussed here before. But why do that??? Heavy nose is a reality so why not move that 'unusable down travel' to the up travel, keeping the full range of elevator travel? What, if any, downsides are there when doing that??? I have to admit to using all the available stick motion in my Pitts but I don't plan on flying my -10 like that!!!! Wink
Linn
On 2/27/2014 7:52 AM, Bill Watson wrote:
[quote]--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com> (Mauledriver(at)nc.rr.com)
Like so many others with custom panels, I had panel interference as well. Why wouldn't the preferred approach be to modify the stick (or panel) so that you have full stop to stop travel? (I know you aren't asking this but had to say it).
Anyway, I've flown at both ends of the CG range. I have more pitch down authority than I need in any maneuver I can imagine. With the CG at the forward limit and full flaps, I can land, power off, with the stick at the limit though the forces become so high that the moment I hit the stop is hard to detect. When trimmed for final approach, pitch forces in the flare go from light to very heavy in a nose heavy configuration. A perfect setup in my estimation.
This was quite satisfying after flying my old Maule. In the Maule, when forward loaded (nothing in back), it was easy to run out of pitch authority in a power off flare. A bit of power was required to arrest a slow and steep approach or else. Not a good situation - definitely a dark spot in it's flying qualities. Not so in the '10. So I'd say you need full pitch up authority.
--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com> (sean(at)stephensville.com)
I'm in the process of adjusting my pushrods and elevator stops for panel clearance and travel limits. I've reviewed all the archived posts on adding stops and other techniques for getting panel clearance. I think I have a good handle on that.
What I was curious about is the travel limits of the elevator. In particular the elevator up limits. I assume that because of the nose heavy aspect of the RV-10 that one would want to make sure that the up travel limit of the elevator is at the higher end of the limits? I'm imagining that with the loading at the forward most CG you'd want max throw there for landing flare?
I know I am going to have to add a stop to prevent panel interference, but as that only effects the down travel, as long as I am at or above the elevator down limit of 20 degrees I should be fine? I'm imagining the down limit being important for stall recovery and with the relatively easy stall recovery of the rv-10 that the lower limit of 20 degrees is ok?
So long story short, is it better to be at the higher side of the up elevator limits and ok to be at the lower side of the down limits?
Checked by AVG - www.avg.com
02/26/14
johngoodman
PostPosted: Thu Feb 27, 2014 6:21 am    Post subject: Re: Elevator Limits Reply with quote
The more ballast in the baggage compartment, the better mine flies; but there is a limit, of course. I have started using half flaps for landing and it is much better than full flaps - when it comes to trim & stick issues. More importantly, if you have to do a go-around, you're not frantically trimming like you would with full flaps.
But back to the original issue. I would not "bend" the stick. Make the panel clear the stick, first. Then do what you have to do with the elevator stop to make it so. You will never use the forward limit, but that panicky near-miss could find you pushing the stick under the panel; you don't want it caught.
PostPosted: Thu Feb 27, 2014 7:15 am    Post subject: Elevator Limits Reply with quote
Just to be clear, I am in favor of bending the stick or modifying the
panel so that the full down stop can be hit without any interference.
While I don't see a situation where that is needed, I'd prefer to have
the throw as specified in the design.
Bending the stick (which I did) is a simple solution to retaining full
throw, which I find very acceptable.
Panel modification, the root cause of this issue, is also an acceptable
solution.
Panel interference at the forward limit is unacceptable.
But all of that is just my thinking and not necessarily well informed
thinking.
schmoboy
PostPosted: Thu Feb 27, 2014 7:32 am    Post subject: Elevator Limits Reply with quote
Just to be clear. When I speak of adding stops I am not meaning adding
stops to throw it under the Vans min spec'd degrees.
As far as bending the sticks, I tried that and ended up with the sticks
too far in my and the co-pilots lap when full aft. That presented other
issues like hitting the trim hat switch with my stomach. Not a desired
event when in full flare for landing.
So, lets say I was able to achieve 30 degrees up and 20 degrees down on
the elevator. Both within specs. Up at max and down at min. Full
panel clearance. Sounds like that is ok for the way the -10 handles.
Bill Watson <mailto:Mauledriver(at)nc.rr.com>
February 27, 2014 at 9:15 AM
acceptable solution.
thinking.
PostPosted: Thu Feb 27, 2014 9:20 am    Post subject: Elevator Limits Reply with quote
Yep, I'd say so based on my 400 hours so far.
adding stops to throw it under the Vans min spec'd degrees.
sticks too far in my and the co-pilots lap when full aft. That
presented other issues like hitting the trim hat switch with my
stomach. Not a desired event when in full flare for landing.
on the elevator. Both within specs. Up at max and down at min. Full
> interference. While I don't see a situation where that is needed,
> I'd prefer to have the throw as specified in the design.
> full throw, which I find very acceptable.
> thinking.
PostPosted: Fri Feb 28, 2014 4:20 am    Post subject: Elevator Limits Reply with quote
Which causes me to wonder why we don't shift the full elevator movement
towards the up or aft limit instead of modifying everything ....
That seems so simple to me.
Linn
http://forums.matronics.com/viewtopic.php?p=419433#419433
