Van's SBs
gengrumpy
PostPosted: Thu Feb 20, 2014 9:01 am    Post subject: Van's SBs Reply with quote
Anyone on the net aware of the extent of horizontal stab spar and elevator attachment points cracks?
Not exactly looking forward to doing those SBs if the incidence rate has been really low…..
grumpy
geezer02(at)windstream.ne
PostPosted: Thu Feb 20, 2014 9:27 am    Post subject: Van's SBs Reply with quote
I have completed the inspection and didn't find any cracks. Be aware that SB 14-02-03 was superseded by SB 14-02-05. recommended that it not be done as a preventative maintenance.
Louis RV-8 N18LD
grumpy
alan(at)airweigh.com.au
PostPosted: Thu Feb 20, 2014 1:27 pm    Post subject: Van's SBs Reply with quote
Hi Ya Grumpy,
All you have to do is remove the fairing at the tailplane to inspect the stab main spar area. The elevators/rudder inspection does not require removal of anything.
If no cracks are found then you must do nothing except inspect each year. If cracks are found then the rectification must be made.
Be sure to check the Jam Nuts on the rod ends. ( seems that loose jam nuts can cause the problem)
Cheers .... Alan. RV8 Flying in Australia.
grumpy
gengrumpy
PostPosted: Fri Feb 21, 2014 1:50 pm    Post subject: Van's SBs Reply with quote
Thanks, Louis.
Got 05 downloaded today after I got back home.
grumpy
Louis RV-8 N18LD
> grumpy
gengrumpy
PostPosted: Fri Feb 21, 2014 2:20 pm    Post subject: Van's SBs Reply with quote
Thanks, Alan.
I was wondering how many planes have turned up with cracks is either place.
grumpy
On Feb 20, 2014, at 3:26 PM, Alan Searle <alan(at)airweigh.com.au> wrote:
Hi Ya Grumpy,
> grumpy
edwclg
PostPosted: Fri Feb 21, 2014 2:23 pm    Post subject: Van's SBs Reply with quote
I just finished doing both insp's on the elevator and horz stab and found nothing wrong.
I look at the back end carefully every year as I had a Swift that was known for cracks back there.
It would be nice to have an account of how many a/c have been insp vs how many have found cracks and what type of operating environment they have been in.
Any thoughts how we could do that?
Ed Clegg
On Fri, Feb 21, 2014 at 4:49 PM, Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)> wrote:
[quote]--> RV8-List message posted by: Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)>
Thanks, Louis.
grumpy
On Feb 20, 2014, at 11:27 AM, geezer02(at)windstream.net (geezer02(at)windstream.net) wrote:
> --> RV8-List message posted by: <geezer02(at)windstream.net (geezer02(at)windstream.net)>
> Louis RV-8 N18LD
>> Not exactly looking forward to doing those SBs if the incidence rate has been really low&hellip;..
>> grumpy
target="_blank">http://www.matronics.com/Navigator?RV8-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Site Admin
PostPosted: Mon Feb 24, 2014 7:17 pm    Post subject: Van's SBs Reply with quote
Just inspected my circa 1994 RV-6 for both the stab spar and elevator spar cracks per the respective SB's and found nothing questionable. Whew.
Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Site Admin
gengrumpy
PostPosted: Tue Feb 25, 2014 5:34 pm    Post subject: Van's SBs Reply with quote
Any idea how many planes with cracks have been found to date?
grumpy
PostPosted: Tue Feb 25, 2014 6:44 pm    Post subject: Van's SBs Reply with quote
Roughly 10% of those reporting their inspection.
AKS
grumpy
> Matt Dralle
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
gengrumpy
PostPosted: Tue Feb 25, 2014 6:48 pm    Post subject: Van's SBs Reply with quote
Are the numbers being reported to Van’s and will Van’s report the numbers found?
JM
AKS
> grumpy
>> Matt Dralle
Site Admin
PostPosted: Tue Feb 25, 2014 8:07 pm    Post subject: Van's SBs Reply with quote
But that's probably a pretty high percentage of "cracks found" because its more likely that someone finding a crack would report it to Van's than someone not finding a crack. 10% seems crazy high especially considering that it took this long to "discover".
Seems like everyone should report their findings to Van's good or bad so that their stats are realistic.
Just send them to "support(at)vansaircraft". Included my N number and Serial number.
AKS
> grumpy
>> Matt Dralle
Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550
Site Admin
AKS
> grumpy
>> Matt Dralle
