where to put OAT sensor?
Goto page 1, 2  Next
rowlandcarson(at)gmail.co
PostPosted: Sat Feb 22, 2014 2:44 pm    Post subject: where to put OAT sensor? Reply with quote
I'm wondering where to put my outside air temperature (OAT) sensor. Obviously it doesn't want to be in direct sunlight (although PA28s seem to think that's OK), and not anywhere on the belly downstream of the exhaust. Does anyone have a good suggestion for it? It's tiny, less than thumbnail size, so doesn't need much room, and the wires back to the panel can be as long as needed.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
klinefelter.kevin(at)gmai
PostPosted: Sat Feb 22, 2014 5:59 pm    Post subject: where to put OAT sensor? Reply with quote
I put mine in the stbd wing root area. Below the fuel elbow. So it's never exposed to the sun, outside the cockpit, opposite the exhaust. Oh, and not exactly sticking out in the breeze creating drag. The wires run under the passenger window to the panel.
Seems to work well...
Kevin
On Feb 22, 2014, at 2:44 PM, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
rlborger(at)mac.com
PostPosted: Sat Feb 22, 2014 6:56 pm    Post subject: where to put OAT sensor? Reply with quote
Rowland,
I used a small plastic P clip to connect it to the underside of the CD7 (CBM-XS 914 Installation Manual, page 4-6) with the wiring passing through the same grommet as the Wastegate Cable.
I will be working on the Europa tomorrow. With any luck Ill remember to take a picture for you.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Feb 22, 2014, at 4:44 PM, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
alanb(at)dpy01.co.uk
PostPosted: Sun Feb 23, 2014 12:30 am    Post subject: where to put OAT sensor? Reply with quote
In the air duct well forward of the radiators
Alan
On 23 Feb 2014, at 02:55, Robert Borger <rlborger(at)mac.com> wrote:
Rowland,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
in friendship
Rowland
kingsnjan(at)westnet.com.
PostPosted: Sun Feb 23, 2014 1:10 am    Post subject: where to put OAT sensor? Reply with quote
Rowland,
How about inside an airvent? Cessna have had them there for years.
Kingsley
grahamsingleton(at)btinte
PostPosted: Sun Feb 23, 2014 3:16 am    Post subject: where to put OAT sensor? Reply with quote
Makes sense Kingsley,
btw when are you coming to UK? You won't forget where we are will you? (even if you did camp indoors{{!Wink
Graham
Sent: Sunday, 23 February 2014, 9:09
Subject: Re: where to put OAT sensor?
--> Europa-List message posted by: "Kingsley Hurst" <kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)>
Rowland,
How about inside an airvent? ="http://www.matronics.com/Navigator?Europa-List" target="_blank">http: --> h &nbsphref="http://www.matronics.com/contribution" target="_blank">http://www=======================
davidjoyce(at)doctors.org
PostPosted: Sun Feb 23, 2014 4:04 am    Post subject: where to put OAT sensor? Reply with quote
Alan & rowland, problem with anywhere subject to ram air
pressurization is that it will give an appreciably higher
temp than true OAT.(Boyle & his law). I have an airbox
temp sensor in my air plenum and also an OAT sensor in the
wing root just in front of the flap control slot and the
two give significantly different temps once the plane is
flying, if I remember rightly by something like 8C.
Regards, David Joyce, G-XSDJ
On Sun, 23 Feb 2014 08:31:51 +0000
Alan
> Rowland,
> Bob Borger
>EXP
> 3705 Lynchburg Dr.
> Cel: 817-992-1117
> rlborger(at)mac.com
> in friendship
> Rowland
>Carson
Un/Subscription,
Forums!
Admin.
PostPosted: Sun Feb 23, 2014 8:36 am    Post subject: where to put OAT sensor? Reply with quote
Mine's in the air duct before the radiators.
Not sure if there is as much pressurisation as in the carb air intake.
If the airfield ever dries out I'll be in a position of being able to get off the ground and find out:-(
Alan
On 23 Feb 2014, at 12:04, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
Alan & rowland, problem with anywhere subject to ram air pressurization is that it will give an appreciably higher temp than true OAT.(Boyle & his law). I have an airbox temp sensor in my air plenum and also an OAT sensor in the wing root just in front of the flap control slot and the two give significantly different temps once the plane is flying, if I remember rightly by something like 8C. Regards, David Joyce, G-XSDJ
> Alan
>> Rowland,
>> I used a small plastic “P” clip to connect it to the underside of the CD7 (CBM-XS 914 Installation Manual, page 4-6) with the wiring passing through the same grommet as the Wastegate Cable.
>> I will be working on the Europa tomorrow. With any luck I’ll remember to take a picture for you.
>> Bob Borger
>> 3705 Lynchburg Dr.
>> Cel: 817-992-1117
>> rlborger(at)mac.com
>> in friendship
>> Rowland
> Un/Subscription,
> Forums!
> Admin.
nigel_graham(at)m-tecque.
PostPosted: Sun Feb 23, 2014 3:30 pm    Post subject: where to put OAT sensor? Reply with quote
If I remember correctly, isn't 'DJ powered by a 914? If so, the plenum
will be fed with heat sinked (sunk?) air fresh from a blisteringly hot
turbo. Once Mr. Boyle has added his two cents, I'm surprised that the
difference between plenum and OAT is only 8c!
Nigel
ptag.dev(at)talktalk.net
PostPosted: Sun Feb 23, 2014 3:44 pm    Post subject: where to put OAT sensor? Reply with quote
Unless it has an intercooler which it hasn't !
Bob H G-PTAG
rparigoris
PostPosted: Sun Feb 23, 2014 4:11 pm    Post subject: Re: where to put OAT sensor? Reply with quote
Hi Group
I put mine between the port stabilator and fuse:
http://www.europaowners.org/main.php?g2_itemId=78342
Ron Parigoris
Remi Guerner
PostPosted: Mon Feb 24, 2014 12:07 am    Post subject: where to put OAT sensor? Reply with quote
Rowland
I put it inside the intake of the Rotax cylinder cooling baffle. It works fine in flight but not on the ground where it is greatly influenced by the engine temperature.
BTW this shows that the Rotax cooling baffle is not effective at all for cylinder cooling while on the ground.
Remi
PostPosted: Mon Feb 24, 2014 1:16 am    Post subject: where to put OAT sensor? Reply with quote
Nigel, Yes I have a 914' but I am talking about the space
fed directly from a NACA inlet which gathers the air
before it enters the turbo. Like all the cowling inlets it
will be pressurised by the slipstream/propwash No doubt
post turbo the temperature will be higher still - which is
why 914s don't need carb icing protection.
Regards, David
On Sun, 23 Feb 2014 23:29:44 +0000
"nigel_graham(at)m-tecque.co.uk"
so, the plenum will be fed with heat sinked (sunk?) air
fresh from a blisteringly hot turbo. Once Mr. Boyle has
added his two cents, I'm surprised that the difference
Nigel
Un/Subscription,
Forums!
Admin.
PostPosted: Mon Feb 24, 2014 3:44 am    Post subject: where to put OAT sensor? Reply with quote
Ahh! wrong plenum. That makes more sense as I would expect induction air
downstream of the turbo to be in the high 70's C.
Thanks for the clarification.
Nigel
Nigel, Yes I have a 914' but I am talking about the space fed
directly from a NACA inlet which gathers the air before it enters the
turbo. Like all the cowling inlets it will be pressurised by the
slipstream/propwash No doubt post turbo the temperature will be higher
still - which is why 914s don't need carb icing protection.
Regards, David
> plenum will be fed with heat sinked (sunk?) air fresh from a
> blisteringly hot turbo. Once Mr. Boyle has added his two cents, I'm
> surprised that the difference between plenum and OAT is only 8c!
> Nigel
> Un/Subscription,
> Forums!
> Admin.
budyerly(at)msn.com
PostPosted: Tue Feb 25, 2014 12:08 pm    Post subject: where to put OAT sensor? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Some notes on my mistakes:
OAT probe in either the 914 or radiator metal duct work needs an insulator as the ducts warm up and on the second flight and is really terrible until at altitude. If insulated, it is down right tollerable in the duct shortly after engine start.
I have put them in the back of the wing fillet gap by the flap, seen them in the gap between the stab and fuselage, in the tail cone trim hole, sticking out the belly (Dynon probe style stuck out of the bottom of the aircraft clear of exhausted air), even the 912 fiberglass plenum, and they all worked.
Some magnatometers require wire to the OAT to be installed (Dynon type) so plan your magnatometer and OAT sensor positions to prevent 20 feet of wire running. With the magnetometer behind the baggage bulkhead, one was put in the hole behind the flap bracket (no cover). Do plan for flap movement. Another mag was put under the seat, and the probe put under the right cheek of the passenger. It worked provided your passenger does not have an iron bottom.
If you put your Dynon magnetometer in the overhead, consider an overhead vent with the OAT in it. If in a cold climate, when the duct is shut off, you get cockpit temp, so plan accordingly.
Just my two cents.
Bud
trevord
PostPosted: Thu May 13, 2021 6:53 pm    Post subject: Re: where to put OAT sensor? Reply with quote
Has anyone considered the wheel well ?
This space is out of the sun, there is lots of room and the wall I have inserted to stop mud going into the lower fuselage is flat on my aircraft, so perfect for mounting things to it by simply drilling a hole.
I have to install several OAT senders due to installing two uAvionix AV30s which each require a separate OAT sender. Plus there is a third OAT sender for the Kanardia Airspeed indicator to give TAS.
Would stray exhaust really be a problem here ?
Trevor
Trevor
Griffo
PostPosted: Thu May 13, 2021 11:09 pm    Post subject: Re: where to put OAT sensor? Reply with quote
I am with Kingsley - subject to you having a large/deep enough vent
brian.davies44(at)gmail.c
PostPosted: Fri May 14, 2021 12:40 am    Post subject: where to put OAT sensor? Reply with quote
I tried that location and the temperature went up significantly when I ran
the engine. I switched to the side air vent and that was perfect.
Brian Davies
budyerly@msn.com
PostPosted: Fri May 14, 2021 6:47 pm    Post subject: where to put OAT sensor? Reply with quote
Trevor,
My opinion is don't install it on the cowl itself as it is just another thing to slow down cowl removal. Keep it out of direct sunlight if you can.
As for the wheel well:
In the event of a tire failure or God Forbid a gear up landing, damage is done in the well.
I tend to stay away from directly behind the XS cowl exit. Just avoiding the cowl exit air.
The wheel well is a nasty hole for dirt and debris. In my opinion it will be slightly warmer than true outside air. (Disclaimer: I have no experience with the actual temperatures in the wheel well.)
I've assisted clients in putting the OAT in several places.
1. My favorite is the inlet for the turbo duct. Radiator duct is a little too warm unless right up front.
The inlet duct for the Turbo on the 914 metal shelf isn't bad. (Use caution and note on the ground it gets pretty warm. Works fine in flight provided it is on the outer most part of the duct and suspended in the stream.)
I have 12AY's OAT in the 914 inlet suspended on a short bolt/spacer held by an Adel Clamp from the metal air dam. Works fine. (GRT and Blue Mtn.)
2. 912S located in the inlet attached to the airbox. (GRT) (Always make sure you mount it for an easy airbox removal or engine removal to facilitate maintenance.)
3. Cockpit inlet ducts of course if there is room as folks have said. Nice and close to the panel normally, so a short run. Dependent on inlet design. (Both Dynon's)
4. In the starboard wing root back before the flap tube just forward of the flap and behind the aft socket was popular for a while. We mounted it carefully to allow for the aux tank. (Dynon and GRT)
5. In the closeout for the Stabilator. (Caution not to impact the stab of course.) (Dynon)
6. Stuck out in the slipstream under the starboard seat was expedient for one client who insisted on it in the cockpit. He only had NACA inlets to the cockpit. Hard to wash the belly without hitting it though. (Dynon)
7. One guy has a ventilation tube plumbed from a NACA in the fin and piped into the overhead. He had his in the tube there just as the NACA entered the fin. (GRT)
8. Another was in the area below the starboard baggage bay inside but just aft of the flap tube where I didn't think it would work well, but air came in the flap slot and it actually worked OK. (GRT)
It is an experimental. If it doesn't work, plug the hole and move it. The only way to tell is take separate temperatures. Use a handheld thermometer when in flight placed in your cockpit inlet to check your OAT placement for accuracy.
Best Regards,
Bud Yerly
Griffo
PostPosted: Fri May 14, 2021 8:03 pm    Post subject: Re: where to put OAT sensor? Reply with quote
To check your OAT location/reading; try obtaining one of those self contained digital indoor/outdoor thermometers or a fridge one.
They usually come with a long lead for the outdoor thermocouple.
Use a bit of double sided tape, to mount the "head/readout end in the cockpit. Gap or 100 mph tape to temporarily secure the external lead and thermocouple in the desired position.
Works a treat - have even used one to check carburettor inlet temperatures.
Goto page 1, 2  Next
Page 1 of 2
