Flap Closeout Closeout
tonyrenshaw268(at)gmail.c
PostPosted: Wed Feb 19, 2014 1:28 am    Post subject: Flap Closeout Closeout Reply with quote
Gidday,
Like others I am considering whether I will close off the end of my flaps. I have found a tube that is tapered down to the OD of the flap cross tube, my vacuum cleaner wand, and I have created a couple of tubes that I intend on placing over the flap cross tube and re-rigging the wings, then filling the gap ideally with expand foam or something similar, shaping it, and then glassing over it, with flox corners and 2 plies of BID. Has anyone used expand foam to shape things as it is a deep closeout now with the flap extensions on them, and to make up foam inserts would be a bit of a disaster. I tried some expanding foam today, upside down as instructed, and disaster. It managed to exude around the base of the wand, not down it into my dummy setup, the inside of a tissue box. So, I have a puddle of expanding cell foam on my bench that I can now see if it is sandable and shapeable, or not.
There must be an easier way, but I don’t know what it is. It seems wise to fill it rather than have a chamber of air, requiring venting if I just create a wall at the end of the closeout, somehow. Any tips??
Tony R.
Sydney Aussie.
 Filesize:  106.63 KB
 Viewed:  8024 Time(s)
pete(at)lawless.info
PostPosted: Wed Feb 19, 2014 2:07 am    Post subject: Flap Closeout Closeout Reply with quote
Hi Tony
From past experience of expanding foam in house building projects I
would guess it is not suitable. Tends to have quite large voids left in
it after it has gone off. It also tends to keep expanding so very
difficult to judge how much to put in.
Be interested to know if any one has found a way of using it, I have
been meaning to fill my flap extensions for the last 12 years.
Pete
Classic 912 #109
On 19/02/14 09:27, Tony Renshaw wrote:
Gidday,
Tony R.
Sydney Aussie.
jimca(at)ozemail.com.au
PostPosted: Wed Feb 19, 2014 2:55 am    Post subject: Flap Closeout Closeout Reply with quote
Tony, Jim here.
I did it years ago now and it wasn't anywhere as difficult as you anticipate.
Also made some cones and glued them in first. I then took a suitable bit of leftover foam and pushed it onto the flap end, which made a perfect line to cut. My foam was only 1/2 inch thick, so I blocked it outweigh scraps, glued it in the end, filled the gaps and 2 layers of BID - Bobs your uncle.
Jim McAvoy
Perth
On 19 Feb 2014, at 6:06 pm, Pete Lawless <pete(at)lawless.info> wrote:
Hi Tony
From past experience of expanding foam in house building projects I would guess it is not suitable. Tends to have quite large voids left in it after it has gone off. It also tends to keep expanding so very difficult to judge how much to put in.
Be interested to know if any one has found a way of using it, I have been meaning to fill my flap extensions for the last 12 years.
Pete
Classic 912 #109
> Gidday,
> Tony R.
> Sydney Aussie.
grahamsingleton(at)btinte
PostPosted: Wed Feb 19, 2014 3:02 am    Post subject: Flap Closeout Closeout Reply with quote
Tony
that's the way I would do it. Trouble with spray can Urethane is it never really stabilises.
Graham
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Wednesday, 19 February 2014, 10:55
Subject: Re: Flap Closeout Closeout
--> Europa-List message posted by: Jim McAvoy <jimca(at)ozemail.com.au (jimca(at)ozemail.com.au)>
Tony, Jim here.
Jim McAvoy
Perth
On 19 Feb 2014, at 6:06 pm, Pete Lawless <pete(at)lawless.info (pete(at)lawless.info)> wrote:
--> Europa-List message posted by: Pete Lawless <pete(at)lawless.info (pete(at)lawless.info)>
Hi Tony
Pete
Classic 912 #109
> Gidday,
> Tony R.
> Sydney Aussie.
http://www.mat; ronics.com/contribution" target="_blank">http://www.matronics.com/contrib===============
rparigoris
PostPosted: Wed Feb 19, 2014 3:06 am    Post subject: Re: Flap Closeout Closeout Reply with quote
Hi Tony
It's hard to tell from your picture, but it looks like you have "tripple" expanding foam.
I have fooled a bit, especially with Foam Radio Controlled models and low expanding foam is the secret. Once cured it trims up very nice with a razor blade or knife.
I used the low expanding foam to support my fuel tank after the cockpit module was installed.
See "Say NO to crack":
http://www.europaowners.org/main.php?g2_itemId=86925
Remember that the flap cross tube articulates as the flap is raised and lowered, in other words the angle it meets up with the flap drive pin changes. You need to take this into account. I have a drawing in my build manual, I think it came about from England, perhaps I downloaded from the Europa club, but it called for building up the OD of the outboard flap tube, perhaps it was somewhere between 1/8" and 1/4" (I'm not exactly sure), then the tapered guide fit reasonably close to that built up OD that would allow you to get the pin engaged, then when you sent it home (pushed the flap all the way on the pin) the tapered guide went away so you now have clearance between the tapered guide and the now normal OD flap drive cross tube.
So many words, my thoughts are now probably clear as mud!:
See Useful Mod 10303:
http://www.theeuropaclub.org/for-builders/europa-mods-sbs/laa-all-of-type/
I don't know if I'm going to install a ramp/guide or close the flaps out. If I do I have some of the shaped bluefoam that I used to make the close out. Off the cuff perhaps shape some blue foam somewhat close to the shape you want and fill voids with expanding foam? It will not cure unless a little moisture can get as it. If you shoot lets say under a close fitting block, may take a "LONG" time to cure and would be expanding and oozing half of forever. Thus fool on a test making some holes in the blue foam. You could light mist a side of the foam too if you are in a dry area. Or make a outboard rib out of Balsa and light cover with thin glass, drill a small water drain out on bottom?
Ron Parigoris
PostPosted: Wed Feb 19, 2014 3:29 am    Post subject: Flap Closeout Closeout Reply with quote
Hi Graham,Not stabilising doesn’t sound good. Seems like using good old blue foam might be the better way to go, and bog it in with micro. It is a frustration that you can’t poor in a liquid that sets. I could always use plaster Wink
Tony R.
On 19 Feb 2014, at 10:01 pm, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
Tony
Graham
From: Jim McAvoy <jimca(at)ozemail.com.au (jimca(at)ozemail.com.au)>
To: "europa-list(at)matronics.com (europa-list(at)matronics.com)" <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Tony, Jim here.
Jim McAvoy
Perth
Hi Tony
Pete
Classic 912 #109
> Gidday,
> Tony R.
> Sydney Aussie.
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
PostPosted: Wed Feb 19, 2014 3:33 am    Post subject: Flap Closeout Closeout Reply with quote
Tony
Forgot to mention, I also turned up some extended flap drive pointy pins. They extend about 2 inches longer than the original ones so you can locate them into the cross tube before pushing the wings close to the fuse, works fine.
Jim
On 19 Feb 2014, at 5:27 pm, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Gidday,
Tony R.
Sydney Aussie.
<photo.JPG>
PostPosted: Wed Feb 19, 2014 4:27 am    Post subject: Flap Closeout Closeout Reply with quote
Blu foam and micro is the way to go! Use plenty of microballoons so stiff micro and be careful you don't get an exotherm
which you will if there's a big volume of micro.
Graham
Sent: Wednesday, 19 February 2014, 11:28
Tony R.
[quote]Tony
Graham
Tony, Jim here.
Jim McAvoy
Perth
Hi Tony
Pete
Classic 912 #109
> Gidday,
> Tony R.
> Sydney Aussie.
href="http://www.matronics.com/Navigator?Europa-List">http://www.matroniclow" target="_blank" href="http://forums.matronics.com/">http://forums.= -->
Fred Klein
PostPosted: Wed Feb 19, 2014 8:27 am    Post subject: Flap Closeout Closeout Reply with quote
On Feb 19, 2014, at 1:27 AM, Tony Renshaw wrote:
Gidday,Has anyone used expand foam to shape things as it is a deep closeout now with the flap extensions on them,
Tony...yes, I have. I tried and tested many different kinds. I got my best results from "non-expanding" foam...I also found a 3 oz. paper cup to be an easy way to form a tapered guide for the flap pin into the flap cross tube...Fred
 Filesize:  54.44 KB
 Viewed:  8005 Time(s)
 Filesize:  30.52 KB
ptag.dev(at)talktalk.net
PostPosted: Wed Feb 19, 2014 10:16 am    Post subject: Flap Closeout Closeout Reply with quote
Hi! All,
I just noticed some chat about the Europa Flap Drive slot needing covering
and Flaps Inboard close outs . But I missed the initial reason for the
commencement of the thread. My contribution is to suggest a visit to Bob
Harrison's Europa G-PTAG at:-
http://www.users.waitrose.com/~jcliff/BobH/BobH.htm (with much thanks to
John Cliff of Waitrose for allowing it to remain in place) where my scheme
can be seen .
It is however a somewhat sobering thought that it was mostly taken from the
Jabiru 3300 power pack days!!
I recall that the use of blue foam was employed and the tapered holes for
receiving the flap drive shaft during one man rigging was moulded round the
"nylon purple rail chair under bolt head tapered packers" off a railway
track !!!! ( No it wasn't me that made the train crash either !) but
apologies for the "Floor brush for the seeping of" description!
To all Bob Harrison G-PTAG
gregoryf.flyboy(at)comcas
PostPosted: Wed Feb 19, 2014 11:21 am    Post subject: Flap Closeout Closeout Reply with quote
Fred,
Neat and helpful. Assuming all cups are not created equal, where'd you get
the cup from? Smile
Tony,
I used expanding foam on my temporary seat modification Jig, that created a
shape for the carbon-fiber plies to form on. It was of the type that needs
two parts mixed together, and would expand like crazy once mixed. Unlike
from the can, the mix is fairly homogeneous as far as not leaving air voids.
I did notice that some of the cured 'bubbles' were larger in some areas than
others though. There is a lot of power there. As long as the exit hole is
properly sized to let out the pressure during the expanding process, it
seemed to do pretty well in fitting the (closed) form that I created for it
to expand to. It's probably a good idea to let it sit for a few days to be
sure the chemical reaction is halted.
Greg
