here's a new one
Goto page 1, 2  Next
teamgrumman(at)yahoo.com
PostPosted: Tue Feb 18, 2014 11:28 am    Post subject: here's a new one Reply with quote
I had just finished setting the mixture on a FWF restoration I'm doing on N28819. You can see a lot of pics of it on the AuCountry Aviation Facebook page.
When I pulled out the mixture to check one last time to make sure the mixture went to cutoff, the cable broke. That has never happened before.
 Filesize:  1.08 MB
 Viewed:  13938 Time(s)
 Filesize:  2.09 MB
JHOSLER(at)epri.com
PostPosted: Tue Feb 18, 2014 11:49 am    Post subject: here's a new one Reply with quote
Not good. How often should these be replaced?
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary L Vogt
Sent: Tuesday, February 18, 2014 2:27 PM
To: Teamgrumman List
Subject: here's a new one
Discover
PostPosted: Tue Feb 18, 2014 12:08 pm    Post subject: here's a new one Reply with quote
Gary,
That happened to me once. Fortunately, it happened at the end of a flight with the last pull of the mixture cable to kill the engine. It just kept coming out. Glad it didn't happen during flight....
I did have a throttle cable disconnect during another flight. Glad the mixture didn't break that day....
Ned
BARRY CHECK 6
PostPosted: Tue Feb 18, 2014 12:50 pm    Post subject: here's a new one Reply with quote
I guess that is why the AD on the cables.  Why hasn't the AD covered the AA5x series?
Better on the ground that in the air and consider how difficult the FAA would have made your life if there was an accident!
Barry
On Tuesday, February 18, 2014, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote] I had just finished setting the mixture on a FWF restoration I'm doing on N28819.  You can see a lot of pics of it on the AuCountry Aviation Facebook page.
PostPosted: Tue Feb 18, 2014 1:11 pm    Post subject: here's a new one Reply with quote
This is the first cable failure I've seen. I've seen problems with the throttle brackets on the AG5B but nothing on an AA5B.
On Tuesday, February 18, 2014 12:14 PM, 923TE <923te(at)att.net> wrote:
--> TeamGrumman-List message posted by: 923TE <923te(at)att.net (923te(at)att.net)>
Gary,
What AD is that?
On Tuesday, February 18, 2014 12:56 PM, FLYaDIVE <flyadive(at)gmail.com> wrote:
BarryOn Tuesday, February 18, 2014, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:[quote] I had just finished setting the mixture on a FWF restoration I'm doing on N28819. You can see a lot of pics of it on the AuCountry Aviation Facebook page.
http://www.matronics.com/Navigatoe="rect" target="_blank" href="http://forums.matronics.com/">http://ff="http://www.matronics.com/contribution">http://www.matronics.com/contri===============
n76lima(at)mindspring.com
PostPosted: Tue Feb 18, 2014 1:28 pm    Post subject: here's a new one Reply with quote
I had just finished setting the mixture on a FWF restoration I'm doing on N28819. You can see a lot of pics of >it on the AuCountry Aviation Facebook page.
When I pulled out the mixture to check one last time to make sure the mixture went to cutoff, the cable broke. >That has never happened before.
Looks just like the mixture cable failure on the AA-1/A/B that has the 500 hour replacement.
Haven't seen it on a 4-place, but have seen and replaced several on 2-place.
Beech had a problem with them on the Skipper, too.
--Bob Steward
Birmingham, AL
PostPosted: Tue Feb 18, 2014 1:50 pm    Post subject: here's a new one Reply with quote
What AD is that?
75-09-07 04/25/1975 Mixture Control Wires
Affects all AA-1, AA-1A, and AA-1B. AA-1C were exempt, because Grumman claimed they "re-routed" the mixture cable.
--Bob Steward
garnerrice(at)hotmail.com
PostPosted: Tue Feb 18, 2014 2:06 pm    Post subject: here's a new one Reply with quote
Apparently that was not the lifetime warranty cable.  From the looks of the faded knob, I may have been in there for lets say, 36 years?
G
Date: Tue, 18 Feb 2014 11:27:15 -0800
PostPosted: Tue Feb 18, 2014 11:47 pm    Post subject: here's a new one Reply with quote
What's an AA1?
Gary
On Feb 18, 2014, at 1:50 PM, <n76lima(at)mindspring.com> wrote:
What AD is that?
--Bob Steward
david(at)newlangsyne.com
PostPosted: Wed Feb 19, 2014 4:31 am    Post subject: here's a new one Reply with quote
I saw this happen to a prop cable. Came right out while the pilot was cycling the prop before takeoff. It was a vernier cable, and
the pilots flying that plane had a habit of screwing it in before landing, rather than pushing it in. They'd screw it all the way
in and then some, kinking the cable.
On the AA-1 series, the recurring AD can be eliminated by replacing the cable with a vernier control. Oh, well ...
BARRY CHECK 6
PostPosted: Wed Feb 19, 2014 4:46 am    Post subject: here's a new one Reply with quote
David:
Screwing the cable in, or Pushing the cable in makes no difference.  If anything, pushing it in would put more flexing force than screwing it in.  The 'CABLE' does not turn when being screwed in, it is only shaft portion right behind the the knob that turns; Full In is Full In.  No matter how it is achieved. There is also a 'slippage' to the screwing action, so you could twist all day long without ever increasing any force on the cable.  Why did the cable break?  Only the cable knows for sure.
Barry
On Wed, Feb 19, 2014 at 5:08 AM, David Feinstein <david(at)newlangsyne.com (david(at)newlangsyne.com)> wrote:
[quote]--> TeamGrumman-List message posted by: "David Feinstein" <david(at)newlangsyne.com (david(at)newlangsyne.com)>
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
le, List Admin.
boxereighty(at)AOL.COM
PostPosted: Thu Feb 20, 2014 8:10 am    Post subject: here's a new one Reply with quote
John:
Here is a link to the AD:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/650EF5216513544186256A38005DF83B?OpenDocument
Here is the AD info:
Amendment 39-2180; AD 75-09-07
Barry
On Tue, Feb 18, 2014 at 4:11 PM, Hosler, John<JHOSLER(at)epri.com> (JHOSLER(at)epri.com) wrote:
  What is the AD on the cables?
*From:*owner-teamgrumman-list-server(at)matronics.com [mailto:
owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com)] *On Behalf Of *FLYaDIVE
*Sent:* Tuesday, February 18, 2014 3:51 PM
*To:*teamgrumman-list(at)matronics.com
*Subject:* Re: here's a new one
AA5x series?
Barry
On Tuesday, February 18, 2014, Gary L Vogt<teamgrumman(at)yahoo.com> (teamgrumman(at)yahoo.com)  wrote:
page.
============== TeamGrumman-List Email Forum - :p> /o:p> >gator?TeamGrumman-List">
http://www.matronics.com/Navigator?TeamGrumman-List ==============   -
MATRONICS WEB FORUMS - /o:p>http://forums.matronics.com ============== - List Contribution Web Site -pre>   -Matt Dralle, List Admin.ribution">
http://www.matronics.com/contribution =============
The same thing happened to me at the end of a flight in my AA1C. My A&P (new to me at the time) said there was an AD on it but that was secondary, the mixture control obviously had to be replaced since it was broken, AD or not so I didn't research the point. At the time the plane had in the vicinity of 1000hrs TT ±. So I think the rumors of an improved bracket on 1C models negating the AD might be overstated. The AD (from the above link) was published and amended in 1975 which was two years before the C model came to market. Maybe the cable really was improved so was never added to the AD, I'm not going to research it now, but quite obviously based on my experience the cable was still susceptible to breakage after very low time in service. Even on an AA1C. I put a vernier mixture control on the Lynx and never had another problem in the next 10 years until I sold it.
Brent Smith
N28386/1N1
JHOSLER(at)epri.com
PostPosted: Thu Feb 20, 2014 9:41 am    Post subject: here's a new one Reply with quote
Thanks, I used to have a mechanic that checked the cable every annual as a matter of course (and we did change the cable once –not sure why.  The bending of the end of the cable at the attachment always seemed to me to be the weak point.
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of boxereighty(at)AOL.COM
Sent: Thursday, February 20, 2014 11:10 AM
Subject: TeamGrumman-List: here's a new one
John:
Barry
*Subject:* Re: TeamGrumman-List: here's a new one
AA5x series?
Barry
page.
Brent Smith
N28386/1N1
  _-============================================================_-=          - The TeamGrumman-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,_-= Photoshare, and much much more:_-=_-=   --> http://www.matronics.com/Navigator?TeamGrumman-List
BARRY CHECK 6
PostPosted: Fri Feb 21, 2014 5:07 am    Post subject: here's a new one Reply with quote
John & Team:
Here is an unusual thing... Ever notice how a pilot handles the Throttle Control? Usually it is very gently - Nice smooth actions, in and out. BUT! Then watch the way the same pilot handles the Mixture Control. Sure they adjust the Mixture nice and smooth. BUT! Watch them Pull, Yank and Slam the Mixture Control OUT when they shut off the Engine/Mixture. WHY! Why not slowly and gently pull it out?  And watch the Tach at the same time... You should see a 50 RPM increase just before the engine dies. Doing it this way you do not abuse the cable and the 50 RPM increase is one of the indications you have the Carb Adjusted correctly. Some things you do fast and some things you do slow and gentle. It's like making love.
Barry
On Thu, Feb 20, 2014 at 12:40 PM, Hosler, John <JHOSLER(at)epri.com (JHOSLER(at)epri.com)> wrote:
Thanks, I used to have a mechanic that checked the cable every annual as a matter of course (and we did change the cable once &ndash;not sure why. The bending of the end of the cable at the attachment always seemed to me to be the weak point.
From: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com)] On Behalf Of boxereighty(at)AOL.COM (boxereighty(at)AOL.COM)
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
John:
Barry
*From:*owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:
*To:*teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
AA5x series?
Barry
page.
Brent Smith
N28386/1N1
==============[/b]
eamGrumman-List Email Forum -[/b][/quote] [/u][/b][/quote] u>[/u][/b][/quote] >[/b][/quote] tor?TeamGrumman-List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] u>[/u][/b][/quote] rget="_blank">http://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] /pre> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution" target="_blank">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [/quote]
JHOSLER(at)epri.com
PostPosted: Fri Feb 21, 2014 7:33 am    Post subject: here's a new one Reply with quote
Got it!
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: Friday, February 21, 2014 8:07 AM
Subject: Re: here's a new one
John & Team:
Barry
John:
Barry
AA5x series?
Barry
page.
Brent Smith
N28386/1N1
u>
u>
==============[/b][/quote] TeamGrumman-List Email Forum -[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] >[/b][/quote] gator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List[/b][/quote] ==============[/b][/quote] - MATRONICS WEB FORUMS -[/b][/quote] /o:p>[/b][/quote] http://forums.matronics.com[/b][/quote] ==============[/b][/quote] - List Contribution Web Site -[/b][/quote] pre>   -Matt Dralle, List Admin.[/b][/quote] ribution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
PostPosted: Fri Feb 21, 2014 7:27 pm    Post subject: here's a new one Reply with quote
Good point, Barry. I'll have to see just how I pull the mixture to IDLE cutoff. I don't know off hand.
On Friday, February 21, 2014 7:39 AM, "Hosler, John" <JHOSLER(at)epri.com> wrote:
Got it!
Subject: Re: TeamGrumman-List: here's a new one
John & Team:
Barry
John:
Barry
AA5x series?
Barry
page.
Brent Smith
N28386/1N1
u>
u>
============== TeamGrumman-List Email Forum - :p> /o:p> > gator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List ============== - MATRONICS WEB FORUMS - /o:p> http://forums.matronics.com ============== - List Contribution Web Site - pre>   -Matt Dralle, List Admin. ribution">http://www.matronics.com/contribution ==============
http://www.matro====================
n32romeo(at)AOL.COM
PostPosted: Sat Feb 22, 2014 7:02 pm    Post subject: here's a new one Reply with quote
A vernier mixture cable is the way to go. The cable is much thicker, and is an alternate means of compliance on the AA-1 500 hour replacement AD. I like the fine tuning adjustment it provides, and on shutdown, I screw it out till the engine quits and watch for the tach rise.
Rich
BARRY CHECK 6
PostPosted: Sun Feb 23, 2014 2:48 am    Post subject: here's a new one Reply with quote
Rich:
You said something that is very interesting to me: "The cable is much thicker, and is an alternate means of compliance on the AA-1 500 hour replacement AD." I have used other sources as proving that the ALCOR cable is approved for the replacement- Have you found the statement AMOC (Other Means Of Compliance) for the cable? It would make writing up the 337 a lot easier and easier to prove.
Barry
On Sat, Feb 22, 2014 at 10:01 PM, <n32romeo(at)aol.com (n32romeo(at)aol.com)> wrote:
[quote] A vernier mixture cable is the way to go. The cable is much thicker, and is an alternate means of compliance on the AA-1 500 hour replacement AD. I like the fine tuning adjustment it provides, and on shutdown, I screw it out till the engine quits and watch for the tach rise.
Rich
PostPosted: Sun Feb 23, 2014 7:20 am    Post subject: here's a new one Reply with quote
The Alcor cable is PMA for all the Grumman singles (plus all other carburetor equipped singles), so no 337 is required.
The 500 hour replacement requirement of the AD is part number specific, so not applicable to the Alcor cable.
Had the AD said "replace mixture cable every 500 hours", then it would not matter what cable was installed.
--Bob Steward
Goto page 1, 2  Next
Page 1 of 2
