Wing Tank Fuel Senders?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
mjb777
PostPosted: Wed Feb 12, 2014 10:43 am    Post subject: Wing Tank Fuel Senders? Reply with quote
Hi all,
Anyone wish to share their 2 cents worth on any issues had with wing tank fuel level senders?
I am looking at installing VDO 10-180 Ohm senders in the end plates but wonder if they may be prone to fuel leakage through the connector terminal stud or anywhere else in the actual sender assembly?
Also I imagine with the senders mounted right at the root of the tank, you wouldn't get any other indication other than full until quite a bit of fuel had been used?
Matt.
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer.
lwheat2083
PostPosted: Wed Feb 12, 2014 1:25 pm    Post subject: Wing Tank Fuel Senders? Reply with quote
Yup! Your exactly right. I have 2 (one in each tank) electronic senders for fuel level. At 6 gallons I show full tanks on the EFIS. What I did is to put that level in the yellow (approx 3 hrs flight time) and made a dipstick that registers 10 to 13 gallons for checking fuel at the fill cap. Not too much to do other than that. It works out well for me-not perfect but gives plenty of warning. Hope this helps. Cheers, Larry Pulsar III N852LW
On Feb 12, 2014, at 10:43 AM, mjb777 <mattbrock777(at)gmail.com> wrote:
Hi all,
Matt.
Pulsar 1 TD Kit.
Captain B777.
http://forums.matronics.com/viewtopic.php?p=418620#418620
briana(at)xtra.co.nz
PostPosted: Wed Feb 12, 2014 2:09 pm    Post subject: Wing Tank Fuel Senders? Reply with quote
Matt,
Kits from about 1996 came out with capacitance fuel level senders mounted on the end plates. Some people have had a problem with intermittent readings with the earlier versions of these senders. I had to replace mine a couple of years ago. The new models seem fine. With the capacitance tube extending into the tank, and angled up to the top skin it is possible to get good readings up to about 28 litres. No problems with leakage if installed carefully with good sealant.
Brian
On 13/02/2014, at 7:43 am, mjb777 <mattbrock777(at)gmail.com> wrote:
Hi all,
Matt.
Pulsar 1 TD Kit.
Captain B777.
mjb777
PostPosted: Wed Feb 12, 2014 3:36 pm    Post subject: Re: Wing Tank Fuel Senders? Reply with quote
Thanks Guys,
Larry, i assume that is 6 gallons per side and you get full indications?
Is anyone using automotive/ marine style resistance with float type senders, and can share their experience with those?
Matt.
Pulsar 1 TD Kit.
Captain B777.
kdpalmer(at)mweb.co.za
PostPosted: Wed Feb 12, 2014 7:04 pm    Post subject: Wing Tank Fuel Senders? Reply with quote
Matt,
Why don't you put in a flow meter it records how much you are
consuming how much you have used and on the flow rate how much is left, best
thing with a dihedral wing, you could have a steam gauge to remind you that
it is physically nearly empty, best thing since bubble gum.
Keith
barry(at)connisbeare.com
PostPosted: Thu Feb 13, 2014 4:56 am    Post subject: Wing Tank Fuel Senders? Reply with quote
Hi Matt,
I installed some resistance style senders that I think I got from AS&S many years ago. I reduced the arm length to make better use of the entire resistance track so that I get ‘full’ and ‘empty’ on the fuel gauge. Of course, they don’t read the top couple of gallons in the tank, but I’m not concerned that that fraction, it’s the last gallon or two that I am worried about! Mine read accurately all the way down to the last half gallon. Photo attached. These have worked well for the last 18 years or so.
Barry
G-XPXP Taildragger UK
Sent: Wednesday, February 12, 2014 11:36 PM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: Wing Tank Fuel Senders?
--> Pulsar-List message posted by: "mjb777" <mattbrock777(at)gmail.com>
Thanks Guys,
Matt.
Pulsar 1 TD Kit.
Captain B777.
http://forums.matronics.com/viewtopic.php?p=418634#418634
 Filesize:  641.92 KB
 Viewed:  9102 Time(s)
bernard.wilder2(at)gmail.
PostPosted: Thu Feb 13, 2014 7:06 am    Post subject: Wing Tank Fuel Senders? Reply with quote
I don't trust any fuel gauge,,, even the ones in our FBO's Cessnas.
I known how much fuel I burn per hour. I fill my tanks before every
flight. I have a panel mounted clock. I switch tanks every half hour.
My bladder limits my flight time to three or three and a half hours,
at which time I have at least five gallons reserve.
Works for me.
Bernie Wilder
On Thu, Feb 13, 2014 at 7:44 AM, Barry J Edwards <barry(at)connisbeare.com> wrote:
Hi Matt,
resistance track so that I get 'full' and 'empty' on the fuel gauge. Of
course, they don't read the top couple of gallons in the tank, but I'm not
concerned that that fraction, it's the last gallon or two that I am worried
Barry
Thanks Guys,
Matt.
Pulsar 1 TD Kit.
Captain B777.
lwheat2083
PostPosted: Thu Feb 13, 2014 8:36 am    Post subject: Wing Tank Fuel Senders? Reply with quote
Correct. I rely on the time of flight vs the known fuel load which I check every flight. Cheers, Larry N852LW
On Feb 12, 2014, at 3:36 PM, mjb777 <mattbrock777(at)gmail.com> wrote:
Thanks Guys,
Matt.
Pulsar 1 TD Kit.
Captain B777.
PostPosted: Thu Feb 13, 2014 9:23 pm    Post subject: Wing Tank Fuel Senders? Reply with quote
Do you stop the clock when you stop for a pee ? as time marches on.
mjb777
PostPosted: Thu Feb 13, 2014 9:29 pm    Post subject: Wing Tank Fuel Senders? Reply with quote
The physiological aspects of fuel use and bladder capacity is an angle I haven't put much time into yet.......
Otherwise.........anyone had other types of leaks.....with automotive fuel senders in the end panels?.............
Matt Brock.
+971507052665.
  Original Message
Sent: Friday, 14 February 2014 13:25
Reply To: pulsar-list(at)matronics.com
Subject: RE: Re: Wing Tank Fuel Senders?
Pulsar 1 TD Kit.
Captain B777.
PostPosted: Fri Feb 14, 2014 7:02 am    Post subject: Wing Tank Fuel Senders? Reply with quote
Yes - -- - - - -
Pee time is not chargeable to the Hobbs.
Bernie Wilder
On Fri, Feb 14, 2014 at 12:22 AM, Keith Palmer <kdpalmer(at)mweb.co.za> wrote:
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
