Motorglider wings
Goto page 1, 2  Next
alan.twigg775(at)gmail.co
PostPosted: Thu Feb 06, 2014 10:03 am    Post subject: Motorglider wings Reply with quote
Making great progress after a delay over Christmas. Drag pin spacers fitted and glassed; Lift and Drag fittings going on in next two days then off to the paintshop.
Having a gliding instructor job, I have so much spare time with all this wind and rain in the UK, I must be one of the few with anything positive to come out of it.
The poor souls in Somerset are flooded out, the South Coast rail line to Cornwall is washed away and still it comes. No sign of help from the military.
iancook_1(at)hotmail.com
PostPosted: Thu Feb 06, 2014 2:00 pm    Post subject: Motorglider wings Reply with quote
Alan,
For Info
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Alan Twigg
Sent: 06 February 2014 18:03
To: Europa list
Subject: Motorglider wings
CBHI_LETTER_050214.pdf
 Filename:  CBHI_LETTER_050214.pdf
 Filesize:  85.21 KB
 Downloaded:  805 Time(s)
davidjoyce(at)doctors.org
PostPosted: Thu Feb 06, 2014 2:23 pm    Post subject: Motorglider wings Reply with quote
Ian, I wonder whether a SmartASS would possibly be
considered as an acceptable stall warner. It is in my
experience a considerably more effective tool than the
Europa stall warner, (having flown with both now for a
couple of years), and much easier to fit. It has in
addition a wheels up warning which sounds if you slow to
approach speed without putting gear down. It is currently
out of production (at Smart Avionics) but Mark Burton is
hoping to launch a new improved version in the next few
months.
Regards, David Joyce, G-XSDJ
On Thu, 6 Feb 2014 21:59:02 +0000
Ian Cook <iancook_1(at)hotmail.com> wrote:
Alan,
For Info
To: Europa list
pin spacers fitted
days then off to
the paintshop.
time with all this
come out of it.
Coast rail line to
help from the
military.
rparigoris
PostPosted: Thu Feb 06, 2014 2:29 pm    Post subject: Motorglider wings Reply with quote
Hi Ian
Curiosity question, in the PDF you sent it mentions undercarriage bungee tension. If this refers to a Mono bungee tension, why exactly would there be a different need between long and short wings?
Thx. Ron Parigoris
grahamsingleton(at)btinte
PostPosted: Thu Feb 06, 2014 2:38 pm    Post subject: Motorglider wings Reply with quote
David,
Not sure how SmartASS is installed, is it tee'd into the ASI?
Trouble with the ASI is it tells you what has happened anything up to 20 seconds after
the cause of the event (loss of speed) occured.
The stall warner gives you an instant warning of change of AoA, and that's what matters.
By the time the ASI has told you you're stalling, you already have.
AoA tells you it's going to happen if you don't do something quickly, (get the nose down).
Graham
Sent: Thursday, 6 February 2014, 22:22
Subject: Re: Motorglider wings
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Ian, I wonder whether a SmartASS would possibly be considered as an acceptable stall warner. It is in my experience a considerably more effective tool than the Europa stall warner, (having flown with both now for a couple of years), and much easier to fit. It has in addition a wheels up warning which sounds if you slow to approach speed without putting gear down. It is currently out of production (at Smart Avionics) but Mark Burton is hoping to launch a new improved version in the next few months.
Ian Cook <iancook_1(at)hotmail.com (iancook_1(at)hotmail.com)> wrote:
Alan,
For Info
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)
[mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Alan Twigg
To: Europa list
the paintshop.
come out of it.
military.
&g========================http://forums.matronics &nbsptronics.com/contribution" target="_blank">http://www.matronics.com/contri================
PostPosted: Thu Feb 06, 2014 3:19 pm    Post subject: Motorglider wings Reply with quote
Graham, It is teed into the pitot and static airlines but
calculates speed electronically and has built in
accelerometers so that it compensates for g and
effectively gives Angle of Attack related warnings. It has
two modes with a female voice through your headset:
firstly it/she will just tell you your airspeed at
intervals (I rarely use that mode) but more importantly it
acts as a speed director in approach or take off mode.
Once settled on your approach you press a button for a
couple of seconds and she says Chosen speed is 60kts (or
whatever). Then if you stay within a few percent of that
she says 'Speed good' in a calm voice at intervals. As you
slow down she has three messages in progressively less
calm voice: 'Speed slow', 'Speed very slow'; and Speed
very slow preceded by a loud gong. Quite impossible to
ignore. Speeding up going away from the circuit she goes
to sleep but wakes up automatically when you get within a
few percent of your previously chosen approach speed,
which remains set unless you change it. It is a brilliant
piece of kit, designed as a life saving tool for
emergencies like EFATOs when the most experienced pilots
will still sometimes find themselves ignoring speed
control and falling out of the sky. But quite
coincidentally it is very much more effective than any
stall warner I have flown with. My Europa one doesn't make
much noise - a problem for a deaf old fart with expensive
modern headset, and on top of that it sounds for an
appreciable part of take off and landing runs, so I am
'trained' to ignore it!
Regards, David
On Thu, 6 Feb 2014 22:34:48 +0000 (GMT)
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
David,
ASI?
already have.
Graham
<davidjoyce(at)doctors.org.uk>
months.
> Alan,
>    For  Info
> To: Europa list
>pin spacers fitted
>days then off to
> the paintshop.
>time with all this
> come out of it.
>Coast rail line to
> Cornwall is washed away and still it c==============
PostPosted: Thu Feb 06, 2014 4:44 pm    Post subject: Motorglider wings Reply with quote
David
certainly sounds very cleverly designed. I agree with your point about stall warner being too
ready to cry wolf. My preference would be proper AoA display with voice warning. Then you have no time delay
between event (AoA change) and warning.
Graham
Sent: Thursday, 6 February 2014, 23:19
. But quite coincidentally it is very much more effective than any stall warner I have flown with. My Europa one doesn't make much noise - a problem for a deaf old fart with expensive modern headset, and on top of that it sounds for an appreciable part of take off and landing runs, so I am 'trained' to ignore it!
Regards, David
churchy
PostPosted: Thu Feb 06, 2014 11:40 pm    Post subject: Motorglider wings Reply with quote
Ian
Thanks for sharing this update. Noting the shortfall on the minimum sink rate during Ivan Shaw's test flight - is CBHI fitted with a feathering prop and was that used for the flight test?
Rgds
Richard
[quote] On 6 Feb 2014, at 21:59, Ian Cook <iancook_1(at)hotmail.com> wrote:
Alan,
For Info
To: Europa list
PostPosted: Fri Feb 07, 2014 12:06 am    Post subject: Motorglider wings Reply with quote
Thanks Ian, moats interesting.
I have fitted the Europa supplied Stall Warner.
I have fitted an undercarriage up Warner but was thinking of including an air switch but since the Duo simply has a horn if at brakes are open with undercarriage up, I will do the same on the Europa.
I have installed a pulley under the Airbrake torque tube to clear the Rudder Cable.
I intend to put wheels in the wing tips but need to establish Aileron movement to fit wheels large enough to clear the full deflection case.
Thanks for the update.
Alan
Alan,
For Info
To: Europa list
PostPosted: Fri Feb 07, 2014 2:12 am    Post subject: Motorglider wings Reply with quote
Graham, It isn't clear to me that a digital ASI would have
the same delays as a mechanical one, butin any case the
beauty of the SmartASS is that it starts to warn you that
your speed is decaying way before you are anywhere mear
falling out of the sky, and effectively keeps you very
close to whatever you have chosen as your safe speed for
that phase of flight. It is no more possible to ignore the
escalating warnings, than it would be to ignore your wife
had she caught youin some serious sin of ommission or
worse! Regards, David
On Fri, 7 Feb 2014 00:43:45 +0000 (GMT)
David
Graham
Regards, David
PostPosted: Fri Feb 07, 2014 2:38 am    Post subject: Motorglider wings Reply with quote
Pity I didn't have one back in March 2000!
Graham
Sent: Friday, 7 February 2014, 10:12
Graham, It isn't clear to me that a digital ASI would have the same delays as a mechanical one, butin any case the beauty of the SmartASS is that it starts to warn you that your speed is decaying way before you are anywhere mear falling out of the sky, and effectively keeps you very close to whatever you have chosen as your safe speed for that phase of flight. It is no more possible to ignore the escalating warnings, than it would be to ignore your wife had she caught youin some serious sin of ommission or worse! Regards, David
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
David
certainly sounds very cleverly designed. I agree with your point about stall warner being too ready to cry wolf. My preference would be proper AoA display with voice warning. Then you have no time delay
Graham
From: David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com) Sent: Thursday, 6 February 2014, 23:19
Regards, David
On Thu, 6========================http://www.matronics.com/Navigator?EurSame great content also available nbsp; -Matt Dralle,tribution" target="_blank">http://www.matronics.com/contribution
_-===================================
PostPosted: Fri Feb 07, 2014 4:46 am    Post subject: Motorglider wings Reply with quote
It is fitted with a feathering AirMaster prop but no gliding measurements have ever been done on my aircraft.
Regard
Ian
[quote] On 7 Feb 2014, at 07:40, Sky Mail <richard.churchill-coleman(at)sky.com> wrote:
Ian
Rgds
Richard
> Alan,
> For Info
> To: Europa list
churchy
PostPosted: Fri Feb 07, 2014 5:48 am    Post subject: Motorglider wings Reply with quote
Ian
Thanks - my reading of para71 of CS-22 is that the relevant sink measurement is to be performed in 'power off' mode which I assume provides for the prop to be feathered, if available as an option. That means that there may well be scope to decrease drag, decrease sink rate and achieve SLMG certification under CS-22. But from the LAA notes is seems that you are happy not to add that complication to your certification and happy to live with a "long wing" SEA classification. My aim is to be able to maintain SLMG and SEA ratings on the same aircraft, so I may have to be the first to cross that bridge once the aircraft is complete, by demonstrating CS-22 compliance with a feathered prop (if it is achievable)?
Richard
On 7 Feb 2014, at 12:45, Iancook <iancook_1(at)hotmail.com (iancook_1(at)hotmail.com)> wrote:
Regard
Ian
peterz(at)zutrasoft.com
PostPosted: Fri Feb 07, 2014 6:06 am    Post subject: Motorglider wings Reply with quote
On Fri, Feb 7, 2014 at 8:47 AM, Sky Mail <richard.churchill-coleman(at)sky.com (richard.churchill-coleman(at)sky.com)> wrote:
I'm curious as to what the min perf numbers are to meet CS-22,
Cheers and thx,
Pete
churchy
PostPosted: Fri Feb 07, 2014 6:29 am    Post subject: Motorglider wings Reply with quote
1.20 m/s sink for two seat aircraft and 1.0 m/s for a single seat aircraft.
Richard
On 7 Feb 2014, at 14:04, Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
Cheers and thx,
Pete
PostPosted: Fri Feb 07, 2014 6:48 am    Post subject: Motorglider wings Reply with quote
On Fri, Feb 7, 2014 at 9:29 AM, Sky Mail <richard.churchill-coleman(at)sky.com (richard.churchill-coleman(at)sky.com)> wrote:
1.20 m/s
hmmm..... pretty sure I saw less that 236ft/min during my Florida demo ship ride with the prop feathered (w/914, two up, 1/2 fuel, clear day).  What are MG flyers typically seeing?
Cheers & thx,
Pete
PostPosted: Fri Feb 07, 2014 12:40 pm    Post subject: Motorglider wings Reply with quote
Richard,
            My aim is to get it flying and then address the issues one by one. I do not think anybody has done comprehensive performance measurements as a glider. The weight increase is my most important issue.
Ian
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Sky Mail
Sent: 07 February 2014 13:48
Ian
Richard
Regard
Ian
h&jeuropa
PostPosted: Sat Feb 08, 2014 6:41 am    Post subject: Re: Motorglider wings Reply with quote
It might be useful, as you work with LAA, to have a US FAA approved example of how to handle the issue of Motorglider or Airplane.
Our Airworthiness Certificate states "Amateur Built Aircraft/Motor Glider" and our Operating Limitations reference our program letter in which we stated that
"This aircraft is designed to be operated in two configurations as follows:
Aircraft Configuration, 27 ft wing span with flaps
Motor Glider Configuration, 47.5 ft wing span with air brakes
The pilot in command of this aircraft shall comply with the applicable sections of FAR Part 61 prior to operating the aircraft in any of the above referenced configurations."
We appreciate seeing the letter from Francis Donaldson addressing concerns about switching wings - good things to think about as we proceed with our glider wings. Can anyone tell us what item 17 is about? One issue not mentioned is that the flap actuation rod on a monowheel interferes with the Mod 78 enhanced spar, maybe no one in the UK with a mono is retrofitting glider wings yet?
Jim & Heather Butcher
N241BW
PostPosted: Sat Feb 08, 2014 1:23 pm    Post subject: Motorglider wings Reply with quote
Hi Jim,
Mine is a mono with retro fit MG wings but not aware of foul you
describe. Still trying to find the details behind 17 myself.
Ian
 Filesize:  2.49 MB
 Viewed:  13503 Time(s)
rparigoris
PostPosted: Sat Feb 08, 2014 2:50 pm    Post subject: Re: Motorglider wings Reply with quote
Hi Ian
"Mine is a mono with retro fit MG wings but not aware of foul you
describe."
The flap push-rod will not work with post mod 78 spars on a XS Mono.
I never looked close at a Classic Mono, but off the cuff think problem will be the same as XS.
You can't modify the push-rod to clear post Mod 78 spar, air-brake cable and pitch cross tube in both gear down and gear up positions.
Options:
Install an electric flap motor, you could have flaps chase gear electrically.
Install a push-pull cable which was my choice.
Of course you can choose to not fly with short wings and remove flap push-rod.
Ron Parigoris
Goto page 1, 2  Next
Page 1 of 2
