dany88
Posted: Sat Jan 25, 2014 8:38 am Post subject: problem firestar |
It is normal that the left wing of this movement?
the right wing makes him slightly.
I can fly like that?
Today I made ​​my second flight and fly the beautiful state kolb firestar,
just to close the wings I noticed this movement.
watch the video
http://www.youtube.com/watch?v=eVMA3QHOf8E&feature=youtu.be
778.17 KB |
26756 Time(s) |
tombaisley
Posted: Sat Jan 25, 2014 10:38 am Post subject: Re: problem firestar |
Do not fly that airplane.
You need to look up inside the wing to determine why that is loose.
beauford173(at)tampabay.r Guest
Posted: Sat Jan 25, 2014 11:22 am Post subject: problem firestar |
Dany:
NO.... Definitely NOT normal..... Possibly very dangerous.
I would NOT fly it until the wing covering is opened and the inside structure is inspected.... BOTH wings.
There can be no movement in this structure. Very important.
Beauford
FF-076
Brandon FL
Posted: Sat Jan 25, 2014 6:20 pm Post subject: problem firestar |
At 08:38 AM 1/25/2014 -0800, you wrote:
watch the video
The clevis swivel and pivot bolt looked good. Could not see if the wing
link to the knuckle was moving in and out of the wing. Fold the wing and
rest the leading edge (front corner) on the floor. Remove the vertical bolt
that passes through the swivel clevis and the knuckle. Move the top of the
wing at the swivel away from the knuckle. With your hand grasp the joint
protruding from the wing and give it a good shake. From this you should be
able to determine if the movement is from inside the wing.
It may be that the compression strut is loose inside the alignment tube that
is welded to the inner most steel rib. A small hole cut into the bottom of
the wing will expose this area.
As a safety issue, turn the swivel over so the bolt head through the knuckle
is up and the nut is down.
Jack B. Hart FF004
Winchester, IN
dany88
Posted: Sun Jan 26, 2014 3:26 am Post subject: Re: problem firestar |
Here are two videos I made ... the first show faulty movement the second shows that the structure and ok. So according to me and only to firmly attach the bolts of the structure, perhaps through the years were slightly loose. since I disassembled everything, replace the main bolt with a self-locking so I'm sure you do not loose any more.
What do you think?
http://youtu.be/MHIv3fZPi1o
http://youtu.be/jMeoG_fxIXA
byoungplumbing(at)gmail.c Guest
Posted: Sun Jan 26, 2014 8:22 am Post subject: problem firestar |
dany88
if the movement is between the rear wing attach fitting and the tube it goes
into, in the wing... the first thing I would is to prime the bare metal...
then apply enough coats of paint till is is a tight fit. then I would take
a small bit of silicone rubber and with a stick or q tip , put a thin film
on the inside of the wing tube, and also on the outside of the steel
fitting, slide the steel fitting in and bolt in place.
on the swivel fitting that fits on the airframe. also prime and paint,
then install a washer and castle nut with a cotter pin. it should be tight
enough so there is no excess movement, but loose enough to allow it to turn
when you fold the wing. check the cotter pin every time you fly.
the drag strut inside the wing should be solid with no movement.
boyd
"dany88" <danielecafaro(at)alice.it>
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
Posted: Sun Jan 26, 2014 1:26 pm Post subject: problem firestar |
I had a similar problem with excessive clearances in the swivel joints on my
FireFly.
You can see how I fixed it at: http://jackbhart.com/firefly/firefly128.html
To remove the excessive clearance between the part in the wing and the socket,
I would coat inside of the socket and the outside of the swivel end with J-B
Weld. Then slide it into place and line up the bolt hole and put the bolt
into place. J-B Weld is an iron particle filled epoxy that is very strong.
When it sets up there should be no play between the swivel end and the socket.
Information about J-B Weld can be found at: http://www.jbweld.com/product/j-b-weld/
Jack B Hart FF004
Winchester, IN
At 03:26 AM 1/26/2014 -0800, you wrote:
dany88
Posted: Mon Jan 27, 2014 2:53 am Post subject: Re: problem firestar |
do not understand how to go about the main bolt.
The bushings are brass?
dany88
Posted: Mon Jan 27, 2014 11:47 am Post subject: Re: problem firestar |
Do you have any idea how I can remove this motion from the hole of the fork to the main pivot?
247.06 KB |
26630 Time(s) |
Posted: Mon Jan 27, 2014 11:52 am Post subject: problem firestar |
It's the hole too big? On Jan 27, 2014 12:49 PM, "dany88" <danielecafaro(at)alice.it (danielecafaro(at)alice.it)> wrote:[quote] --> Kolb-List message posted by: "dany88" <danielecafaro(at)alice.it (danielecafaro(at)alice.it)>
http://forums.matronics.com/viewtopic.php?p=417693#417693
http://forums.matronics.com//files/foto_cel5_024_115.jpg
le, List Admin.
dany88
Posted: Mon Jan 27, 2014 12:49 pm Post subject: Re: problem firestar |
the hole is slightly larger, in practice if witcher well the bolt movement disappears, but I'm afraid that by folding the wings and rub the two walls over time can cause damage
Posted: Mon Jan 27, 2014 2:19 pm Post subject: problem firestar |
Been thinking,,, over here we have plastic 1 gallon milk bottles .... If you cut some o of the very thin plastic from a milk bottle, or a thin plastic Pepsi or coke bottle and put between the universal joint and the frame,,, and under the washer on the inside of the universal,,,, then when it turns when you fold the wings. It should cause no wear.
Boyd On Jan 27, 2014 1:52 PM, "dany88" <danielecafaro(at)alice.it (danielecafaro(at)alice.it)> wrote:[quote] --> Kolb-List message posted by: "dany88" <danielecafaro(at)alice.it (danielecafaro(at)alice.it)>
http://forums.matronics.com/viewtopic.php?p=417697#417697
le, List Admin.
Posted: Mon Jan 27, 2014 4:29 pm Post subject: problem firestar |
Yes, I used very thin brass shim stock. This will not remove all of the
wear because the bolt and hole both wear. It is never good for steel to
wear on steel. In this case there is wear on the bolt too. The shim stock
can remove the wear from the hole but can not remove the wear from the
bolt.
That is why I proposed the second method to fix the problem. By tapering
the hole through the clevis and compressing and neoprene "O" ring, one can
compress into the wear on the bolt. In doing so the bolt and the clevis
hole do not touch and there is no further wear. The taper can easily be
formed by using a small grinding wheel mounted in a Dremel tool. See
http://www.dremel.com/en-us/tools/Pages/CategoryProducts.aspx?catid 13
If you are concerned about wear on the back side of the clevis place a thin
brass shim stock washer between the clevis and the flange on the fuselage
cage. Do not over tighten and use some thick grease lubricant on the "O"
ring and the washer.
Jack B. Hart FF004
Winchester, IN
At 02:53 AM 1/27/2014 -0800, you wrote:
Posted: Wed Jan 29, 2014 5:44 am Post subject: problem firestar |
Boyd,
Checked out possibilities at McMaster Carr. (http://www.mcmaster.com)
Looked at Teflon washers. Part number 95630A505, Low-Friction PTFE Flat
Washer, 1/2" Screw Size, 1.5" OD, .017"-.023" Thick Packages of 10 for
$15.71
And sheets. One side is etched for bonding with adhesive. The other side
has a smooth finish. Part number 8711K91, Sheets Made with Teflon® PTFE,
Adhesive Ready, .015" Thick, 6" x 6" $7.81 per sheet
Jack B. Hart FF004
Winchester, IN
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Date: Mon, 27 Jan 2014 15:19:26 -0700
Posted: Wed Jan 29, 2014 7:55 am Post subject: problem Firestar |
Kolbers:
I don't think Homer Kolb intended anything between the universal and the
airframe, especially paint, plastic washers, and "o" rings, especially
paint. The end of the universal should be clean as well as the contact
point on the airframe, with a light coat of grease to prevent rust and
assist in rotation during wing fold.
Normally during welding the universal joints, the flat end piece warps a
bit. When I had a problem with a loose joint on an early Kolb I built, I
discovered the paint and primer had worn off after my initial adjustment and
installation, and the end of the universal was slightly domed/convex. I
removed it, got the appropriate tools, whacked it a couple times creating a
slightly concave end piece. Now I had two pieces that mated on flat
surfaces. Next I used a combination of thick (1/16") and thin (1/32") AN
washers to adjust out the slop that I got when the castellated nut was lined
up for the cotter pin. You know how that works. One slot is too tight and
the next is too loose. I have a lot of hours, compared to most Kolbs, on my
MKIII, and I have snug rear attach points on my wings that will rotate
without causing any damage to wing or airframe. A lot of force can be
applied to these parts when rotating the wing if the connection is too
tight.
I personally would not use plastic or rubber to snug up these connections.
My personal opinion only. Don't recommend anyone else doing it the way I
did, but my way has proven to work well over many hours and many years.
_________________ John Hauck
Titus, Alabama |
Posted: Wed Jan 29, 2014 8:27 am Post subject: problem Firestar |
Kolbers:
My previous post reminded me of another problem I encountered about 20 years
ago with my MKIII and my first 912 installation on that aircraft. As usual,
I painted the engine mount angle aluminum with plenty primer and paint to
make it look good. The mistake I made was not to mask off the small area
where the mounts contacted the bosses on the engine case. Didn't take long
for vibration to erode the paint and primer causing the four engine mount
bolts to loosen up.
When I swapped the 912ul for a 912uls I alodined the aluminum angle engine
mounts. No more problems.
Titus, Alabama |
dany88
Posted: Wed Jan 29, 2014 9:56 am Post subject: Re: problem firestar |
Here is a brass plate cutout thin now.
Some photos of the work done for painting
50.7 KB |
26539 Time(s) |
83.1 KB |
26539 Time(s) |
51.25 KB |
26539 Time(s) |
54.05 KB |
26539 Time(s) |
78.49 KB |
26539 Time(s) |
Posted: Wed Jan 29, 2014 11:37 am Post subject: problem Firestar |
John,
I do not believe Homer Kolb intended one to tighten the wing universal
assembly bolts after one unfolds the wing prior to flying as you do.
At 200+ hours mine were very loose and worn. I repaired them so that I can
fold the wing as Homer intended without using a wrench to untighten bolts.
Jack B. Hart FF004
Winchester, IN
At 09:55 AM 1/29/2014 -0600, you wrote:
Kolbers:
| Quote: | I personally would not use plastic or rubber to snug up these connections.
dany88
Posted: Thu Jan 30, 2014 6:24 am Post subject: Re: problem firestar |
Work performed perfectly, the joint is not more movement, as you can see from this video http://youtu.be/AHbFpa_Q9NQ
I am attaching a few pictures
64.28 KB |
26502 Time(s) |
47.7 KB |
26502 Time(s) |
65.7 KB |
26502 Time(s) |
dany88
Posted: Thu Jan 30, 2014 6:36 am Post subject: Re: problem firestar |
How do I replace the main landing gear?
I unscrewed the bolt near the hub and the bolt inside the fuselage, but not sfilla the bar of aluminum.
Why?
how can I do?
I enclose a photo
92.9 KB |
26492 Time(s) |
103.93 KB |
26492 Time(s) |
