gregoryf.flyboy(at)comcas Guest
Posted: Sat Jan 25, 2014 1:54 pm Post subject: Cowl mods for front belt driven alternator |
>Perhaps in the situation above, it would be prudent for a 914 builder (914 can draw 11 amps on its own with both pumps running) to consider a belt driven ??
>alternator of 40 amps, and simply redo the cowl front and keep the Rotax as a backup in case of belt failure.
Bud, or those that know,
At some point, or future avionics upgrade, my ship will likely need the extra Watts.
Would you care to supply a 'teaser' on the making of the cowl mod? I am still waiting for my FF package, so don't yet have a handle on how it integrates with the prop flange, but does the front of the cowl terminate just behind the prop flange, on the smaller-radius drive tube? Are the belt-driven alternator components in front of the cowl then, requiring the cowl front face to be opened up and added to? Is this considered an extensive change?
Greg
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bud Yerly
Sent: Thursday, January 23, 2014 9:13 PM
To: europa-list
Subject: RE: Re: Ducati rectifier/regulators
If you are an amp zealot, but still want an aux fuel pump, pitot heat, 100 watt landing light, strobes, heavy draw radio (Garmin 430 type), Aux Radio, Mode S transponder continuously working, autopilot, stereo high quality music system, external power plugs for our phones, I-pads and inflight video system, the Rotax charging system is not going to hack it.
Perhaps in the situation above, it would be prudent for a 914 builder (914 can draw 11 amps on its own with both pumps running) to consider a belt driven alternator of 40 amps, and simply redo the cowl front and keep the Rotax as a backup in case of belt failure.
If you build a 912S airplane with all LED lighting, Garmin 255 or Becker Com, Simple digital Transponder, Aux Boost, and maybe an autopilot for cruise only and a paper map, then the Rotax / Ducati should be fine. The GR6 or SH may be better and longer lasting to boot. In my opinion the Rotax system can't put out much more than 15 amps or so and as the current increases, the voltage output starts to diminish (at least it does in my poor old airplane) .
Just my thoughts.
Bud
> Date: Mon, 20 Jan 2014 16:40:25 +0100
| Quote: | From: jan_de_jong(at)casema.nl
Subject: Re: Re: Ducati rectifier/regulators
--> Europa-List message posted by: Jan de Jong <jan_de_jong(at)casema.nl>
Re two-phase bridge rectifier/regulator.
The 2 thyristors in the rectifier bridge do not short the AC input or
"dump" anything.
On the contrary, they disconnect the DC output from the AC input when
the output voltage threatens to exceed the set voltage.
All output current passes through one branch of one diode and one
thyristor in series half the time and through the other identical branch
also half the time.
Heat development is proportional to the output current and the voltage
drop across a branch.
Voltage drops increase somewhat with current, so heat development
increases more than linearly with output current.
In the Ducati device the diode is reportedly a MR2510 pill (typically
0.75V at 10A, 0.8V at 20A), the thyristor can be a 2N6504 (typically
1.1V at 10A, 1.3V at 20A).
So at 10A the two branches of the bridge are each expected to generate
0.5 x (7.5 + 11) = 9.25W (total 18.5W) of heat.
And at 20A the two branches of the bridge are each expected to generate
0.5 x (16 + 26) = 21W (total 42W) of heat.
a failure mode for the Ducati device is reportedly the loss of
continuity of a diode pill attachment through thermal cycling; fitting
external parallel diodes has been proposed as a solution; replacing the
whole device seems more sensible
Jan de Jong
&g=======================
&g=======
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Sun Jan 26, 2014 6:50 am Post subject: Cowl mods for front belt driven alternator |
Greg, there is a bit of a philosophical issue here! Do you
want to include every possible bit of kit and duplicate
all important functions with considerable addition to your
overall weight, or do you want to build to the lowest
possible weight whilst including all vital functions.
Flying an overweight plane carries its own performance and
safety penalties which can possibly outweigh the marginal
safety gains of the extra kit. When it was possible to
find plane weights on the Europa website (hopefully soon
to be possible again!), it was noticeable that the weights
of 914 Europas varied from under 800lbs to well over
900lbs if my memory serves. That of course equates to a
load capacity for passengers & fuel etc of between 470+
lbs (fairly comfortable) and perhaps 350 lbs.( very thin
passengers or no fuel!). Admittedly in the US you get away
with more than 1270 MAUW, but only at the expense of
eroding performance and safety margins.
For what it is worth my standard 914 alternator
(&Ducatti regulator) with Single Odyssey battery (16
amp/hrs) has for 1000+ hrs coped perfectly well with
wobbly prop, EFIS, autopilot, GPS, twin Nav Com,
transponder, EMS and both electric fuel pumps (although of
course you only normally have one of them on as each is
capable of supplying more than full power fuel flow)
I would personally follow the build as light as
possble approach and have that little bit of extra
power/weight ratio to help you in the dodgy situations you
may possibly unintentionally find yourself in some time
down the line.
Regards, David Joyce, G-XSDJ (833 lbs)
On Sat, 25 Jan 2014 13:54:17 -0800
"Greg Fuchs " <gregoryf.flyboy(at)comcast.net> wrote:
| Quote: | >Perhaps in the situation above, it would be prudent for a
>914 builder (914
consider a belt
driven ??
>keep the Rotax as
likely need the
extra Watts.
cowl mod? I am
handle on how it
the cowl terminate
tube? Are the
then, requiring the
considered an
extensive change?
Greg
_____
Behalf Of Bud Yerly
To: europa-list
stereo high quality
it.
a 914 builder (914
consider a belt
front and keep the
autopilot for
should be fine. The
the current
least it does in my
Just my thoughts.
Bud
> To: europa-list(at)matronics.com
>the AC input or
> "dump" anything.
>AC input when
>diode and one
>identical branch
> also half the time.
>and the voltage
>development
>pill (typically
>2N6504 (typically
>loss of
>cycling; fitting
> Cheers,
> Jan de Jong
&g=======
Posted: Sun Jan 26, 2014 11:00 am Post subject: Cowl mods for front belt driven alternator |
David,
I agree in principle, about keeping it light....not planning on doing an
extra alternator at the moment, just information gathering in advance for
when the ship has been airborn awhile. For example, in case I ever want to
be IFR-capable...
Just keeping the options open. One can always place a small lightweight
alternator off the back of the crank as well without being too
jelly-bellied..some have done it per the forum.
Besides, in keeping it light now, I'll know what I'm missing later when it
tips the scales a bit more steeply...
It looks like your Rotax power source goes a long ways to power your stuff,
and your ship is not gadget-poor by any means. That is good news.
Thanks for the info.
Greg
paul.the.aviator(at)gmail Guest
Posted: Sun Jan 26, 2014 11:42 am Post subject: Cowl mods for front belt driven alternator |
Greg,
I echo David's thoughts on this. With the right design choices it is easy to stay well within the electrical capacity of the standard Rotax. Modern avionics, EFIS, LED position lights & strobes do not draw much current. Attached is the load analysis I did for my aircraft in 2004. I have not updated it since then but LED strobes, landing lights and low draw current contactors make it possible to have an even lower electrical load during cruise.
My 914 XS + Airmaster came in at 860 lb. Over the years I have taken weight out by removing the vacuum instrument system and small tweaks in other area's but I sure wish I had paid much more attention to this during the build.
My favorite comment from Burt Rutan was, "If you are thinking of putting something on your airplane, first toss it in the air. If it doesn't stay there by itself then don't put it on."
Cheers, Paul
 Download |
| Filename: |
Load_Analyisis_Europa_N378PJ.XLS |
16.5 KB |
| Downloaded: |
242 Time(s) |
budyerly(at)msn.com Guest
Posted: Sun Jan 26, 2014 9:02 pm Post subject: Cowl mods for front belt driven alternator |
Greg,
I hope you don't get too carried away. Every ounce you add, or increase to the frontal area, the more performance you loose.
To see an example of one of my cowl mods, look at Jerry Hope's 914 with belt drive alternator. (www.customflightcreations.com click on accessories and tips.) I cut the front of the cowl off, and Jerry and I made a floppy glass cover then began the task of filling, smoothing, making a mirror image for the other side and continuously checking for clearance for the belt and pulley. I made a mold of the front early on and it is rough. I should have cleaned it up. The belt drive alternator really does deliver the amps.
Note in the photo, you can see the alternator is right up against the intake opening. It also extends the cowl forward about 1/8-1/4 inch because of the pulley.
I still believe my Europa simple VFR cruiser is the best idea.
All LEDs, (including the feeble Kuntzelman landing light at .6 amp), no pitot heat, all EFIS and light draw radio/transponder, keeps my amps in check. Even with all my toys running, I do not draw over 15 amps until I key the mic button.
If I do go on to do a light IFR (health permitting) I'll add a Garming Nav Com like the SL30, and purchase a simple pitot heat (like Angus Aviation/Dynon). I'll add an Aux battery and an Alternator to the back of the gearbox to power the pitot heat and a proper landing light for night. (Aveo has an LED unit, which is expensive, but bright. I still would prefer an HID light, however check out the new 13000 Lumen flashlights by Trusfire.)
The aux battery and alternator will most likely be similar to the B&Cs small unit which will keep the aux battery charged but only have enough battery life for about 30 minutes at idle for the HID/or LED light and supply the pitot heat for just the time necessary to penetrate a thin deck.
Just the ramblings of an experimenter.
Bud
Subject: Cowl mods for front belt driven alternator
Date: Sat, 25 Jan 2014 13:54:17 -0800
Greg
To: europa-list
Just my thoughts.
Bud
"dump" anything.
also half the time.
Jan de Jong
&g=======
target="_blank">http://www.matronics.com/Navigator?Europa-List
Posted: Mon Jan 27, 2014 1:21 pm Post subject: Cowl mods for front belt driven alternator |
Hi Paul,
THANKS! Wow, that's quite a detailed load analysis. I can see why you needed
it. It seems that the available Mega-micro (heehee) Watts available from the
Rotax generator are being well used in most modes of flight. I especially
like the slight rest it gets during cruise, ensuring it can top off the
batteries....and possibly lowering the chance of a failure during this phase
of flight.
Looking at the spreadsheet, I can't help but wonder if there is a need (or
at least used to be..before the changes) for a slightly bigger battery
capacity to help handle the load when the plane isn't at high rpm? Of
course, experience is what matters. If you can recall, what battery size is
working for you?
One side note: Over a decade ago, in order to save a few $$, I replaced the
normal extra-capacity battery on my car (they are quite a bit larger than
the normal size), with one that was smaller...and it kept leaving me
stranded during the winter when running the accessories like fan, electric
window heaters, etc. Granted, I was running the car at idle for periods of
about a half hour, to try to keep warm. I replaced it back to the beefier
battery rather quickly, and all starting problems went away. Of course,
there is no penalty of bigger batteries in a ground-bound vehicle and only a
last resort in an airplane.
Hmm.. some HAVE paid more attention to the weight during the build, and
still end up bloated.. 860 is not too bad, IMO.
I'll be trying to use lower power items, such as external LED lights and
EFIS. Since none of them pass Burt Rutans qualification of staying in the
air when tossed there, I will now be adding helium-balloon ballast to the
ship to compensate for it.
Thanks again for the detail,
Greg
Posted: Mon Jan 27, 2014 1:56 pm Post subject: Cowl mods for front belt driven alternator |
The lightest Mono I know of was less than 750lbs. A showroom finish must weigh 20 lbs
at least and adds nothing to performance.
Graham
Greg
Posted: Mon Jan 27, 2014 2:13 pm Post subject: Cowl mods for front belt driven alternator |
Hi Bud,
Time will tell about that getting carried away part, hahaha.
I absolutely figured you had a mold for the cowl!
I looked in anticipation, but could not find the info on Jerry Hopes belt drive alternator. Perhaps I am doing something wrong, but would certainly like to find it.
A Garmin SL30 (maybe someday a 430 or 530) and an EFIS to show its output has long been on my wish list, along with a HID landing light (lower power draw, higher intensity light output).
I looked at a video on You|ube that was demo-ing that flashlight and must say WOW. It has an amazing output. Imagine that one would work just great as a Europa landing light. Might have to give the HID lights another thought.
Thanks for the informative Ramblings,
Greg
Sent: Sunday, January 26, 2014 9:01 PM
To: europa-list
Subject: RE: Cowl mods for front belt driven alternator
.hmmessage P { PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px } BODY.hmmessage { FONT-FAMILY: Calibri; FONT-SIZE: 12pt } Greg,
Bud
Greg
To: europa-list
Just my thoughts.
Bud
"dump" anything.
also half the time.
Jan de Jong
&g=======
Posted: Mon Jan 27, 2014 2:23 pm Post subject: Cowl mods for front belt driven alternator |
Yes, I think I read somewhere (maybe here), that one light mist coat and one full coat of paint should do it, and save some weight.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
Sent: Monday, January 27, 2014 1:53 PM
Subject: Re: Cowl mods for front belt driven alternator
Graham
Greg
Posted: Tue Jan 28, 2014 1:40 am Post subject: Cowl mods for front belt driven alternator |
Graham, Are you sure? You usually are, but competition
gliders are produced with amazing attention to their
finish - gel coat rubbed down progressively to 2000 grit
and then polished with hard wax. We share their laminar
flow aerofoils which are said to be highly sensitive to
surface imperfections.
Regards, David Joyce G-XSDJ (with gel coat finish!)
On Mon, 27 Jan 2014 21:53:13 +0000 (GMT)
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
| Quote: | The lightest Mono I know of was less than 750lbs. A
Graham
the build, and
of staying in the
Greg
Posted: Tue Jan 28, 2014 2:55 am Post subject: Cowl mods for front belt driven alternator |
Having re read what I said I take your point, oversimplification.Nevertheless it's surface imperfections
ie any bump or hollow more than a couple of thou over a 2" length is too much. 2000
grit finish is probably as good as it needs for performance.
Bird's wings intrigue me, there are incredibly efficient. I'd love to see a comparison of the fuel burn
of an albatross or an arctic tern with a Europa. Grey Lag goose might be interestin too. How far do they fly without refueling?
Point being I guess boundary layer control is everything, vortex generators had an amazing effect on my Long EZ,
lowered the stall by 9 kts and little effect at higher speeds. (didn't get chance to measure it but the mod developer claims only 2kts
penalty.
Graham
Sent: Tuesday, 28 January 2014, 9:39
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Graham, Are you sure? You usually are, but competition gliders are produced with amazing attention to their finish - gel coat rubbed down progressively to 2000 grit and then polished with hard wax. We share their laminar flow aerofoils which are said to be highly sensitive to surface imperfections.
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
| Quote: | The lightest Mono I know of was less than 750lbs. A showroom finish must weigh 20 lbs
Graham
From: Greg Fuchs <gregoryf.flyboy(at)comcast.net (gregoryf.flyboy(at)comcast.net)>
Greg > http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Posted: Tue Jan 28, 2014 4:38 am Post subject: Cowl mods for front belt driven alternator |
Grahah, Aother point is that although Roger Targett
probably did spray 20 lbs of gel coat on my plane I am
certain that I wet & dry sanded more than half of that
off, and my 914 mono has ended up as one of the lighter
ones around (at 833lbs) in spite of a very full range of
kit. David
On Tue, 28 Jan 2014 10:54:38 +0000 (GMT)
| Quote: | Having re read what I said I take your point,
imperfections
performance.
without refueling?
Long EZ,
penalty.
Graham
driven alternator
<davidjoyce(at)doctors.org.uk>
> Graham
> ________________________________
> From: Greg Fuchs <gregoryf.flyboy(at)comcast.net>
>the build, and
>of staying in the
> Thanks again==
klinefelter.kevin(at)gmai Guest
Posted: Tue Jan 28, 2014 6:07 am Post subject: Cowl mods for front belt driven alternator |
833 lbs is fantastic. My XS Mono/914/Airmaster came out weighing 50 lbs more! Thinking about that lighter mono wheel and brake to shave off, how much was it?
Kevin
| Quote: | On Jan 28, 2014, at 4:37 AM, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
Grahah, Aother point is that although Roger Targett probably did spray 20 lbs of gel coat on my plane I am certain that I wet & dry sanded more than half of that off, and my 914 mono has ended up as one of the lighter ones around (at 833lbs) in spite of a very full range of kit. David
> penalty. Graham
> From: David Joyce <davidjoyce(at)doctors.org.uk>
> To: europa-list(at)matronics.com Sent: Tuesday, 28 January 2014, 9:39
>> Graham
>> Thanks again==
Posted: Tue Jan 28, 2014 8:44 am Post subject: Cowl mods for front belt driven alternator |
I did this using my mates Bridgeport Mill and it took about 700 grams out.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Zutrauen
Sent: Tuesday, January 28, 2014 8:33 AM
To: europa-list
on the subject of weight savings, I can't help but notice how heavy the mono swingarm is. I noticed in Germany one builder had put many lightening holes in it (among many other mods). I had also wondered if indeed it was over-designed and could use some strategically placed holes. Is that the only builder who has lightened it? Has anyone done any math on that heavy piece?
Cheers & thx,
Pete
A239
Posted: Tue Jan 28, 2014 8:49 am Post subject: Cowl mods for front belt driven alternator |
Greg, I am using an Odyssey 680.
Posted: Tue Jan 28, 2014 8:52 am Post subject: Cowl mods for front belt driven alternator |
David, 833 lb is very impressive. Do you have wet wings?
Posted: Tue Jan 28, 2014 9:34 am Post subject: Cowl mods for front belt driven alternator |
Paul, Not sure what you mean, but presumably you are
talking about the classic fabricated wings - mine is the
standard XS mono with 914/ Woodcomp SR 3000W/ speed kit/
blue mountain EFIS/ garmin 495/ Flydat (now being replaced
by MGL EMS) Garmin SL 30/ Garmin Transponder,/Autopilot/
fuel flow meter + odds & ends. Odyssey 680 mounted
forward. I suppoe the Flydat or equivalent weighs much
less than a panel full of individual instruments, and
likewise a solid state EFIS rather than a vacuum system. I
tried very hard to build light by for instance making sure
that all added fibreglass wasnot overwet and all bolts
were cut to leave just 3 threads clear. All wiring was
done in wire gauge called for rather jan everything being
wired in a largish gauge.My upholstery is a pleasing
fabric system adapted from some Citroen seats in a scrap
car and I guess that saves several pounds over leather.
Ihave Alcantara + foam backing lining the cockpit from
seats forward, but just equivalent coloured paint in the
luggage compartment.
Apart from sanding most of it off, other
positives for a gel coat finish are that it needs no
undercaot and no UV blocking coat.
The plane initially weighed 831lbs befre I put
some lead in the tail to get the CoG just right.
Regards, David
On Tue, 28 Jan 2014 10:50:30 -0600
wings?
Fred Klein
Posted: Tue Jan 28, 2014 9:47 am Post subject: Cowl mods for front belt driven alternator |
On Jan 28, 2014, at 6:32 AM, Peter Zutrauen wrote:
| Quote: | on the subject of weight savings, I can't help but notice how heavy the mono swingarm is. I noticed in Germany one builder had put many lightening holes in it (among many other mods). I had also wondered if indeed it was over-designed and could use some strategically placed holes. Is that the only builder who has lightened it? Has anyone done any math on that heavy piece?
Pete...here's a pix of Paul McCallister's swingarm...Fred
[img]cid:C6E4B40D-0F4F-42DB-BF1E-8F885C09842B[/img]
60.53 KB |
6196 Time(s) |
Fred Klein
Posted: Tue Jan 28, 2014 2:47 pm Post subject: Cowl mods for front belt driven alternator |
On Jan 28, 2014, at 5:34 AM, Kevin Klinefelter wrote:
| Quote: | | 833 lbs is fantastic. |
By any chance, might one of you XS builders have the weights for the stock upper and lower cowls?
I'm looking for a data point in assessing my non-stock cowls...
thanks in advance,
Fred
