gregoryf.flyboy(at)comcas Guest
Posted: Tue Jan 21, 2014 3:13 am Post subject: Flap cross tube problem |
This is an old issue, but I never got back to it to close it out. Once the slots in the fuse were cut and the tube in place, it was indeed too short by just over a half inch or so (from memory). The company sent me some longer bearing holder's to install to the ends of the tube, and this was able to take up the distance. So for anyone else in my shoes, this might be the solution that works for them.
Greg
From: Greg Fuchs [mailto:gregoryf.flyboy(at)comcast.net]
Sent: Friday, June 03, 2011 5:04 AM
To: 'europa-list(at)matronics.com'
Subject: Europa-List: Flap cross tube problem
Hi all,
The flap cross tube appears to be about 2 inches too short, on my aircraft! I was hoping there would be some end pieces placed onto FL15 to lengthen it, but unfortunately, the GE12 bearing and the bearing holder do not increase the length. There does not appear to be any way it will be long enough to firmly grab the pins on both flaps, though it might just be able to span the gap to barely reach the in-board ends of the pins. The length of my flap cross tube (FL15) is 44 and one half inches from end to end. Can someone tell me what theirs measures? Anyone have this problem?
Thank you,
Greg A050
