rv6awingman(at)gmail.com Guest
Posted: Thu Jan 09, 2014 10:02 am Post subject: DYI Marker Beacon Antena |
Roger,
I followed Bob's advice when building my RV-6A. ran a piece of cable from my radio to the firewall and used a bulkhead BNC connector to get to the front side of the firewall. I then took a piece of cable about 48" long and attached a female end on that for the forward connection and proceeded to strip 40" of the sheath from the cable. Subsequently I fiberglassed that to the inside of my cowling running forward horizontally. Works fine and I've not ever forgotten to disconnect the cable from the firewall when removing the cowling.
YMMV
Marty, RV-6A N826ME
Time: 09:07:15 AM PST US From: "Roger & Jean" <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> Subject: DIY Marker beacon antenna I have a wooden airplane in which I will be installing a Marker beacon receiver. My question is: Is it relatively simple to fabricate an antenna, or should I consider purchasing one? I assume it can be put on the inside of the airframe without a significant loss of signal strength. Roger
