genie(at)swissmail.org Guest
Posted: Mon Jan 06, 2014 1:22 pm Post subject: MTOW of RV-6 with Lycoming O-320-D3G and 79" Sensenich Fixe |
Does anyone have a Pilot's Operating Handbook which shows the take-off
weights of an RV-6 with a Lycoming O-320-D3G engine and a 79" Sensenich
Fixed Pitch Metal Propeller? I need these to justify to the aviation
administration an increase in the take-off weight of my RV-6. At present
it is rated at 726 kg which is equal to 1600 lbs. Based on my aircraft's
performance at this weight I find that an increase in MTOW would be
appropriate.
Thank you.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
n146wb(at)cfu.net Guest
Posted: Mon Jan 06, 2014 2:38 pm Post subject: MTOW of RV-6 with Lycoming O-320-D3G and 79" Sensenich Fixe |
Van's originally specified 1600 lb gross for the RV-6, increased it to 1650 for the RV-6A. During the inspection of my RV-6 I called Van's and let the DAR talk to them. They said they would approve 1650 so that's what mine is rated for. I haven't followed what's happened with Van's specs since. The above happened in 2007 and it meant the difference between just carrying two people and carrying two people with some luggage.
Warren
| Quote: | On Jan 6, 2014, at 3:21 PM, George Nielsen <genie(at)swissmail.org> wrote:
Does anyone have a Pilot's Operating Handbook which shows the take-off weights of an RV-6 with a Lycoming O-320-D3G engine and a 79" Sensenich Fixed Pitch Metal Propeller? I need these to justify to the aviation administration an increase in the take-off weight of my RV-6. At present it is rated at 726 kg which is equal to 1600 lbs. Based on my aircraft's performance at this weight I find that an increase in MTOW would be appropriate.
Thank you.
George Nielsen
RV-6 PH-XGN
