Any know is there a typical faliure mode for Soild State Rel
jskiba(at)icosa.net
PostPosted: Sun Dec 22, 2013 8:28 am    Post subject: Any know is there a typical faliure mode for Soild State Rel Reply with quote
Any know is there a typical failure mode for Solid State Relays?
Like do they typically fail OPEN ??? or do they Typical fail CLOSED (just like sometimes of a typical mechanical relay that the points weld together or the spring fails ?)
I am considering using solid state relays to replace mechanical relays but do not know if the ssr has a failure mode worse than them.
I have attached one relay I found thus far to possibly replace a hydraulic motor contactor for a landing gear pump.
Thanks in advance and HAPPY HOLIDAYS !
Checked by AVG - www.avg.com
p>
ssr.pdf
 Filename:  ssr.pdf
 Filesize:  1 MB
 Downloaded:  274 Time(s)
sprocket(at)vx-aviation.c
PostPosted: Sun Dec 22, 2013 9:44 am    Post subject: Any know is there a typical faliure mode for Soild State Rel Reply with quote
The failure mode for these devices are highly dependent on the internal construction. Contacting the manufacturer is only way to be sure.
If it was just the internal powerFET that was the issue, the failure modes are well understood but details of the mechanical packaging may dominate.
Vern
Sent: Sunday, December 22, 2013 8:27 AM
Subject: Any know is there a typical faliure mode for Soild State Relays
p>
Version: 2013.0.3462 / Virus Database: 3658/6941 - Release Date: 12/22/13
berkut13(at)berkut13.com
PostPosted: Sun Dec 22, 2013 9:00 pm    Post subject: Any know is there a typical faliure mode for Soild State Rel Reply with quote
That’s what I did...less weight, less space, less environmental issues, cleaner operation (no contact bounce), etc.
http://www.berkut13.com/berkut50.htm#SSR
If you hydraulic system is anything like mine, you should also be used the snap action hydraulic pressure switches.
Good luck,
James
Berkut/Race 13
www.berkut13.com
Facebook: Berkut13
Sent: Sunday, December 22, 2013 10:27 AM
p>
jluckey(at)pacbell.net
PostPosted: Sun Dec 22, 2013 9:52 pm    Post subject: Any know is there a typical faliure mode for Soild State Rel Reply with quote
they sure are pricey - $130 ea. (at) Mouser, ouch!
From: "berkut13(at)berkut13.com" <berkut13(at)berkut13.com>
Sent: Sunday, December 22, 2013 8:59 PM
Subject: Re: Any know is there a typical faliure mode for Soild State Relays
Good luck,
James
Berkut/Race 13
www.berkut13.com
Facebook: Berkut13
[url=][/url] No virus found in this message.
p>
[quote]www.aeroelectric.com * HomebuiltHELP [url=http://wwe [b]
edpav8r(at)yahoo.com
PostPosted: Mon Dec 23, 2013 9:03 am    Post subject: Any know is there a typical faliure mode for Soild State Rel Reply with quote
On Dec 22, 2013, at 10:51 PM, Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
eBay is your friend. A search for "SSR 100A" returns 91 hits, including appropriate heatsinks, starting at ~$9 delivered.
This presumes the words "China" and "Hong Kong" don't scare you. For solid state devices like these, I wouldn't lose any sleep.
Eric
