rlborger(at)mac.com Guest
Posted: Sun Dec 15, 2013 11:46 am Post subject: 5 Meter LED String Info |
Friends,
Last month I ordered a 5 meter string of white LEDs ($9.25), a power pack/dimmer unit ($2.97) and a pack of 4 extra connectors ($6.50) on Amazon. Needless to say, they shipped from China and they took about 2 1/2 weeks to arrive here. The LED string is supposed to be weatherproof and it has an adhesive backing with peel-off cover/protector. One end is provided with red/black pigtails for connection to the power pack/dimmer:
[img]cid:9B90AA56-E1A9-4421-B443-B9C6EF7931C1[/img]
The string may be cut to length every three LEDs. You can see the scissor symbols where cutting is permitted. Also available are connectors to attach to the end of the cut-off section of string to allow them to be used. I have a pack of those connectors on order but they have not arrived yet.
[img]cid:852CB291-24D7-4AF8-AC41-9D5CC170FFF3[/img]
The connection to the power pack/dimmer is simple and I connected the power pack to my power supply for testing. The power pack/dimmer is for use with 12v-28v DC. I set my power supply to 12v to check it out. With the power pack/dimmer set to minimum power there was a surprising output of light with a current draw of 0.1A.
[img]cid:C86145EA-4747-4C2B-B3D3-14592AEA7C56[/img]
With the dimmer turned to max brightness the light output was impressive and only 1.5A of current draw.
[img]cid:3624743C-5A0D-4E14-B0BA-CC399BEA0C32[/img]
My initial plans for the string were to backlight the fuel sight gage which I believe will work quite well. But that will only take about 1 - 1.5 meters of string. I’m thinking about running the remainder inside the center tunnel of the Europa for lighting when I’m working inside there. I think my biggest problem will be mounting that funky, big power pack/dimmer in an unobtrusive location.
These LED strings are available in single color red, green or blue sets as well as white. They are also available in multi-color LED’s with programmable power supply to do visually interesting things with the string. I haven’t gotten up the courage to tackle the multi-color string yet. And the prices are very affordable for the tinkerer.
The mind boggles at the potential interior and exterior uses of these lights!
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop.Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
51.5 KB |
10895 Time(s) |
54.06 KB |
10895 Time(s) |
55.54 KB |
10895 Time(s) |
46.37 KB |
10895 Time(s) |
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Sun Dec 15, 2013 12:12 pm Post subject: Re: 5 Meter LED String Info |
I am tinkering with the same idea but will use the smaller dimmer from aircraft spruce.. Saved money on the lights and will use it to spend on the dimmer.
Cris
Posted: Sun Dec 15, 2013 12:28 pm Post subject: 5 Meter LED String Info |
Chris,
Which dimmer from ACS? Can you give a link or P/N?
On Dec 15, 2013, at 2:12 PM, chris Sinfield <chris_sinfield(at)yahoo.com.au> wrote:
Cris
glastar(at)gmx.net Guest
Posted: Sun Dec 15, 2013 2:30 pm Post subject: 5 Meter LED String Info |
that is what is lighting up my new house, impressive the white strip
gives around 1900 lm/m the load being 18W/m
The RGBW is used as well however stays mostly white
The pool is on the plan for next year with RGB fully enclosed in that
silicon tube you show. There are ample differences in the kind you can
buy (quality etc.)
Cheers Werner
| Quote: | The mind boggles at the potential interior and exterior uses of these
lights!
Posted: Sun Dec 15, 2013 2:33 pm Post subject: 5 Meter LED String Info |
At 01:46 PM 12/15/2013, you wrote:
| Quote: | Friends,
This is the same class of lighting strip I mentioned
about a year ago. I'm using these for under the cabinet,
over the counter lighting in the kitchen. I'll be using
them for general room illumination in the upgraded
kitchen and a bathroom project.
Eric has a dimmer suited to these lights in airplanes.
http://tinyurl.com/mmuvz7z
His design allows customizing min-max voltage
to accommodate the unique dimming nature of
series-string leds. Your max dim is about 7
volts while max bright is full bore.
I'm planning on putting segments of these strips
in polycarbonate tubing for gee-whiz and general
work light on Dr. Dee and Son Zach's cotton candy
and shaved ice concessions.
These are exceedingly versatile products. The
only shortcoming I've identified so far is the
grade of peel-n-stick adhesive supplied. DOES
NOT stay put with temperature effects outdoors
and in vehicles. Get some 3M mounting tape of
appropriate width and use it to attach these
strips down in a high temperature environment.
ransman
Posted: Sun Dec 15, 2013 4:47 pm Post subject: 5 Meter LED String Info |
Robert Borger skrev 2013-12-15 20:46:
| Quote: | le the multi-color string yet. And the prices are very affordable for
the tinkerer.
lights!
These are very nice things to play with indeed.
The weak point is the cheapy dimmer that is very noisy (electrically) if
you are going to use it in the aircraft.
There are better ways to control these strings.
I am going to make some "ultralight" versions with non-weatherproof and
spray with a plastic film used on circuit boards.
You should try playing with the multicolor and start with a cheap
controller it's no more than three slings together.
My wife loves it! 5 meters in the bathroom and shower with a cheap and
simple controller "making waves" with colors.
You get all from slow ambient-hypno-color-fading to total
alien-disco-flashing!
Cheers from
Sauli
_________________ "Cum propris suis alis volat"
He flies with his own wings |
donjohnston
Posted: Sun Dec 15, 2013 6:23 pm Post subject: Re: 5 Meter LED String Info |
This looks similar to the products that I've been getting from superbrightleds.com (They're located in St. Louis and I typically get the products within two or three days. )
I'm using a strip in my glareshield with one of Eric's dimmers.
DPizza
Posted: Sun Dec 15, 2013 11:50 pm Post subject: 5 Meter LED String Info |
Posted: Mon Dec 16, 2013 7:04 am Post subject: 5 Meter LED String Info |
At 06:46 PM 12/15/2013, you wrote:
(electrically) if you are going to use it in the aircraft.
Eric's dimmer that I cited earlier is a linear
regulator . . . LM317 based. It's not a noise
generator. If you want to go one step further
up the DIY ladder, you can craft your own dimmer
from parts readily available at RadioShack and
others.
Don't let logistics of acquisition dry
up your creative juices.
ransman
Posted: Mon Dec 16, 2013 7:32 am Post subject: 5 Meter LED String Info |
Robert L. Nuckolls, III skrev 2013-12-16 16:03:
<nuckolls.bob(at)aeroelectric.com>
> <sauli.aalto(at)gmail.com>
>> these lights!
others.
I meant the cheap (almost free.. 1 - 2 $) stuff things. But they are
nice to start playing with.
The LM317 is a very nice analog circuit for LED:s! And one more thing
is LM317 will not have
is that annoying flickering that especially comes with simple switched
circuits.
The best way is to just rig up some stuff and play with it before
putting it into a plane.
>> found a nice small thing on ebay
http://www.ebay.com/itm/LM317-DC-In-5-24V-Out-1-5-15V-Volt-Regulator-Converter-/121173879393?pt=AU_B_I_Electrical_Test_Equipment&hash=item1c3686aa61
Enjoy!
//// Sauli
Posted: Mon Dec 16, 2013 7:43 am Post subject: 5 Meter LED String Info |
I have one of Eric’s dimmers on order. I selected it for the reason you state, lower noise potential than a PWM dimmer.
I’m not quite ready to start crafting electro-goodies myself yet, but would like to get there once all aircraft have been built and are flying.
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Dec 16, 2013, at 9:03 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
The weak point is the cheapy dimmer that is very noisy (electrically) if you are going to use it in the aircraft.
others.
