rowedenny
Posted: Wed Dec 04, 2013 7:50 am Post subject: Change of plans |
I recently approached my friend and co-owner of my Mk 3 about my desire to upgrade to a used 912 to improve our take-off performance. Due to his busy business schedule, he has only rode in the Kolb twice with me in the 10 years it has been in operation, and only participated in the construction as a financial partner. I did 100% of the build and also hanger and fly it from my home.
Not surprisingly he asked instead if I was interested in buying him out. Of course I am, but this unexpected expense, as well as doubling of my share of a new engine has eliminated any chance of me affording a 912 setup any time soon.
Enter plan B.
Have decided to build a 670cc Rotax sled engine into an 85hp aircraft engine.
I'll be relying on Rotax Rick to do the bottom end as there is extensive machine work on the PTO end of the crankshaft as well as the cases to make it work with the aircraft gearbox and to fit the 582 ceramic water pump seal. The top end and cooling system I'll handle.
Will also be using Ricks 618 style exhaust to insure the power delivery is smoothed out for our application.
Also helping to make this a more affordable installation is the ability to use the same prop from my current engine as well as all the probes and EIS unit. Additionally I'll also use two of the three Bing carbs from my 2SI engine as I swapped them out for 28mm Mikunis a couple years ago. Should be a very straight forward swap, and using the same prop is going to make it clear how much more power the new engine has over my 690.
My 690 has been a 'SMOOTH', solid engine and performs fine other than the gearbox being incessantly leaky, but flying out of my 600 foot strip in the middle of the woods makes me desire more climb performance.
The engine core is on it's way from a sled salvage outfit as I type.
Let the discussion commence.
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, PA
russk50(at)gmail.com Guest
Posted: Wed Dec 04, 2013 8:33 am Post subject: Change of plans |
Dennis, THANK YOU for sharing your experiences & future ones as well. That will be enormously helpful to the List;
this sort of thing is what it's all about
Fair winds & happy 670cc-ing
Russ
On Dec 4, 2013, at 10:49 AM, Dennis Rowe wrote:
Enter plan B.
Dennis "Skid" Rowe
Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Wed Dec 04, 2013 4:35 pm Post subject: Re: Change of plans |
I can feel your pain for the lousy partnership in your Kolb. I went through the same situation with a partner. Building an aircraft with a partner does not work, does not work.....will never do it again....
_________________ Rick Lewis
(VW Watercooled Engine) |
agramjak(at)gmail.com Guest
Posted: Wed Dec 04, 2013 5:11 pm Post subject: Change of plans |
My experience is: works great, really bad, works great. Afraid to try it again, seems like really bad is next
| Quote: | On Dec 4, 2013, at 6:43 PM, "Rick Lewis" <cktman(at)wildblue.net> wrote:
Rick Lewis
http://forums.matronics.com/viewtopic.php?p=414868#414868
rowedenny
Posted: Wed Dec 04, 2013 6:42 pm Post subject: Change of plans |
Guys,
Didn't mean to give the impression I have been unhappy with my Kolb co-owner. Even though I did all the building and maintenance, I enjoyed it and since it was my third aircraft build, I had strong ideas of how I wanted to do things. Also basing it at my home made it seem like I was the sole owner. since I was doing all the flying anyway, I haven't even asked him for any $ toward upgrades such as the carb conversion and other upgrades I've done. Which means my buy out cost has not gone up in 6 years
Jay was a low maintenance partner. Also was nice to have only half the financial burden during that building period when money was tight. I am blessed to have at least four friends who I wouldn't hesitate to partner in an airplane with. In fact two of them are my current partners in our 1948 Cessna 170 project and my outgoing Kolb partner Jay Swager is another. You meet the nicest people at airports.
Dennis "Skid" Rowe
| Quote: | On Dec 4, 2013, at 8:11 PM, Will Ricketts <agramjak(at)gmail.com> wrote:
> Rick Lewis
> (VW Watercooled
Carolina Flyer
Joined: 03 Oct 2010 Posts: 62 Location: Buffalo, South Carolina
Posted: Wed Dec 04, 2013 6:57 pm Post subject: Re: Change of plans |
Dennis,
Good luck with your 670 build. I know Rick real well, and I am sure he will
do a good job doing the Machine work for you. I have two 670's myself, but I have decided that a Rotax 618 has plenty of enough ponies for my Firestar II
The 618 I have needs to be rebuilt and I plan on having Rick do the work for me. I was real lucky this summer to find a Brand New 618 exhaust on E-Bay, it has never been used. I also plan on letting Rick doing a 670 for me as I plan to have a Two Place side by side one day. Hopefully it will be a Mark III Extra
or a stretched avid flyer.
Anyway keep us informed on your Progress
110.22 KB |
10894 Time(s) |
_________________ Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Carolina Flyer
Posted: Wed Dec 04, 2013 7:30 pm Post subject: Re: Change of plans |
Just some info that some may not know. All 670's that Rotax made are not a good candidate's to be converted for aviation use. That is if you want Dual Ignition. and some are not easily made to be provision 8. Their are 2 years that are preferred the 93 and 94 model year. If the 670 has a black rubber cover on the Mag end then you will not be able to have it become Dual Ignition
Many people think that Rotax was planning on making the 670 into an aviation engine like they did with the 617 that became a 618. If they did it would have been competition for the 912.
here is a picture of the early model PTO end, that can be made to accept a
c-box or e-box. you could even use a b-box but I think it would not hold up to all the extra HP
109.8 KB |
10886 Time(s) |
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Richard Pike
Posted: Thu Dec 05, 2013 7:37 am Post subject: Re: Change of plans |
| Carolina Flyer wrote: | Dennis,
Anyway keep us informed on your Progress |
Noticed that you are thinking of going big block on your FSII: feel free to contact me if you need any ideas or pictures of how we added structure to beef up the upper fuselage. Back before we began our conversion, Kolb was concerned about the extra torque from the bigger engine being a potentially serious problem for the stock tubing.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
rowedenny
Posted: Thu Dec 05, 2013 8:31 am Post subject: Change of plans |
Richard offers some sound advice, a 582 or 618 is really getting up there for a Firestar 2. Careful throttle control is highly advised.
Further clarification of the non 93-94 Rotax 670 engine cases that are not dual Ducati ignition compatible and possibly not provision 8 compatible. If there is a big hole in the top of the Magneto end housing that may have a black plastic cover over it, the Ducati ignition will not bolt up.
Dennis "Skid" Rowe
| Quote: | On Dec 5, 2013, at 10:37 AM, "Richard Pike" <richard(at)bcchapel.org> wrote:
> Dennis,
Richard Pike
richard (at) bcchapel(dot)org
Kingsport, TN 3TN0
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=414909#414909
Carolina Flyer
Posted: Thu Dec 05, 2013 9:16 am Post subject: Re: Change of plans |
Hello Richard Pike,
In regards to strengthening the cage for the additional torque of a 618. I called the Kolb Factory and they told me I should talk to Denise Jackson
(The Factory's Welder) and him and I discussed this matter and I am going to use his advice. I am having the modification done this winter once deer
season is over. I do not Hunt but the Welder that does all of my Welding for me is a Deer Hunter. Once the Modification has been completed I will post some Pictures.
Joe
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
