Contactors
Goto page Previous  1, 2
PostPosted: Mon Dec 02, 2013 6:51 am    Post subject: Contactors Reply with quote
Yes the Faston tabs are 3/8" instead of the regular 1/4". Here's a pic I took yesterday but its not easy to see how the connections are made on the cube.
Sacha
Note that he appears to be using something (on the left) that looks to me like a battery contactor in lieu of a starter contactor. The master contactor is the red "384" series cube on the right.
I am not comfortable with the notion of tying
4AWG wires to these 70A plastic cube relays . . .
Consider the terminals on a 70-series contactors
. . . or any other "contactor". They are mechanically
robust.
[img]cid:.0[/img]
The whole idea behind terminal posts on a contactor
is to provide rigidity . . . wiring induced bending
and torque moments do not move the terminal . . .
hence they do not affect contact alignment inside
the contactor.
Terminals on the plastic cube relays are simply
held in place by virtue of the housing molded
around them. I think if I were going to incorporate
one of the 70A cubes into a system, I would wire
with no greater than 6AWG and use welding cable
at that (soft and flexible).
The reasoning driving substitution of the plastic
cube as a battery relay seems to be rooted in
power consumption . . .
The 'savings' between a cube (180mA) and a
70-series (700mA) coil current is only about
1/2 amps.
Are you sure you NEED to save that 1/2A for
other tasks? If 1/2A has so much influence
on your load analysis, then perhaps you're
proposed sources/loads are not practical.
I suggest you consider finishing up the load
analysis task before you commit to incorporation
of an extra-ordinary substitution for a battery
contactor with a known service history.
 Filesize:  69.34 KB
 Viewed:  1132 Time(s)
uuccio(at)gmail.com
PostPosted: Tue Dec 03, 2013 9:12 am    Post subject: Contactors Reply with quote
Thanks for your comments Bob. In effect I had not considered the mechanical suitability. I generally tend to like to do things with the simplest most commonly available automotive type parts but maybe this is one case where it's simply not a good idea.
Sacha
On Dec 2, 2013, at 15:49, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Sacha
robust.
<18a022d3.jpg>
the contactor.
1/2 amps.
Page 2 of 2
