rowedenny
Posted: Wed Nov 27, 2013 5:47 pm Post subject: Kolb Mk3 POH/checklist |
Mike,
Here is the front and back sides of my laminated sheets. These passed my airworthiness inspection as a POH. My engine is single ignition so you will have to edit in your dual ignition check, and you may not want to turn on your EIS (if you use one) until after the engine is started to avoid inductive spikes from the starter motor and solenoid coil that could harm your electronics.
I hope this helps.
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, PA
544.82 KB |
6423 Time(s) |
651.83 KB |
6423 Time(s) |
lownslow
Posted: Wed Nov 27, 2013 6:27 pm Post subject: Re: Kolb Mk3 POH/checklist |
awesome! thanks Denny! I appreciate it
Mike Welch
Posted: Sat Nov 30, 2013 10:08 am Post subject: Kolb Mk3 POH/checklist |
Denny,
Is it possible for you to scan and save your POH as a PDF file? That way we could make our
own unique changes and print the POH. It would be much easier than retyping your entire manual.
Mike Welch
rlaird
Posted: Sat Nov 30, 2013 10:29 am Post subject: Kolb Mk3 POH/checklist |
I have an unfinished (about 80% done) POH I created for my Kolb, in Microsoft Word format.
If anyone wants it, please send me a private email: rlaird(at)cavediver.com (rlaird(at)cavediver.com)
It's nothing special, and probably begs for improvement, but it was accepted at the time I got my N-number as being adequate.
It was based on a POH I wrote for the Aventura II that I used to own, and the content needs to be reviewed to make sure something leftover from the previous POH didn't get overlooked and included. Plus, the Appendix needs to be finished (diagrams/photos), which would have to be done by each individual since most of the Kolbs built are a little different.
-- Robert
On Sat, Nov 30, 2013 at 12:08 PM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
[quote]--> Kolb-List message posted by: Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)>
Denny,
Mike Welch
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
http://forums.matronics.com
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
rowedenny
Posted: Sat Nov 30, 2013 11:49 am Post subject: Kolb Mk3 POH/checklist |
Mike,
I'll try that when I get a chance, never made a PDF file in my life, but hey, can't be that hard. I'll try to get to it later today.
Dennis "Skid" Rowe
| Quote: | On Nov 30, 2013, at 1:08 PM, Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
Denny,
Mike Welch
