bill.peyton
Posted: Wed Nov 20, 2013 3:03 pm Post subject: Re: life of the Odyssey |
I am not sure if you are addressing me, but I do not have two PC680's. I have a PC925L in the main tray, which will fit in the standard mount without modification, and a PC680 in a battery box supplied by Odyssey. The PC680 second battery is mounted on a shelf next to the existing tray.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
partner14
Posted: Wed Nov 20, 2013 3:50 pm Post subject: life of the Odyssey |
Really easy to modify the tray.... I originally had 2 ea 680's, but just modified it a second time to host a 925 and a 680.
To: <rv10-list(at)matronics.com>;
Subject: Re: life of the Odyssey
Sent: Wed, Nov 20, 2013 11:03:56 PM
40636 |
davidsoutpost(at)comcast. Guest
Posted: Wed Nov 20, 2013 4:10 pm Post subject: life of the Odyssey |
Here is how I did mine:
http://s403.photobucket.com/user/dclifford01/media/RV10/IMG_0006.jpg.html
Sent: Wednesday, November 20, 2013 5:18:15 PM
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net>
How did you mount the two 680s...just looking at dimentions, I don't thinbk they will sit side by side in the stock battery tray.
http://forums.matronics.com/viewtopic.php?p=413612#413612
Posted: Wed Nov 20, 2013 4:42 pm Post subject: life of the Odyssey |
I used two PC-625s and modified the mount. The hold down bolts remain in
the same place. I find the 625s (17ah, 200CCA and 15 lb) a better form
factor to work with than the PC-680s (16ah, 170CCA and 16lbs).
Carl
2.58 MB |
3639 Time(s) |
larkrv10(at)gmail.com Guest
Posted: Wed Nov 20, 2013 7:10 pm Post subject: life of the Odyssey |
Hey Don, why the change back to the 925 and 680 combo?
Thx, Rick
#40956
On Wed, Nov 20, 2013 at 6:49 PM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]Really easy to modify the tray.... I originally had 2 ea 680's, but just modified it a second time to host a 925 and a 680.
From: bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>;
To: <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>;
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
| [b]
