donjohnston
Posted: Thu Nov 14, 2013 9:45 am Post subject: Trim motor speed control |
I have two trim motors that I need to control. The motors provided are 24v motors (3-5amps). But they are intended for with a 12v electrical system. This is done because the 12v motors on a 12v system turn too fast and you keep overshooting when you try to adjust the trim.
This is the elevator trim motor.
http://www.grainger.com/product/WARNER-LINEAR-Linear-Actuator-18G685?s_pp=false
But my electrical system is 24v. Which means the motors will turn too fast. I looked for 48v versions and they're either too expensive or not available at all. So I'm going to have to slow down the existing motors. And to that end, I have come up with 3 possibilities:
1) Put in a DC-DC step down converter. I can get one for about $250. But it is a rather large box that I'll have to mount somewhere and put in the necessary breakers and wiring. I may need 14v for other things in the future so this wouldn't be the worst solution.
http://www.lonestaraviation.com/Step-Down-Conveter-24V-to-13.8-Volts.html
2) I had picked up a motor speed controllers for the heater fan speed controller. But it's only $10! You know the old saying about something being too good to be true?
http://www.amazon.com/dp/B009HKFAIQ/ref=pe_385040_30332190_pe_175190_21431760_M3T1_ST1_dp_1
3) Finally, I could get a dedicated trim motor controller. But I would need their "HD" version and I would need two them... at $245 each for a $490 total.
http://www.tcwtech.com/safety_trim.html
I've pretty much removed option #2 because I have to think that there's this $10 solution either generates noise, is unreliable, or... something else.
So the question(s) are: Does anyone have any experience with a situation like this and if so, which path did you chose? Or does anyone have any opinions on which would be the best solution? And finally, is there an option that I haven't considered? (and changing my entire electrical system to 14v is NOT an option)
Don
tim2542(at)sbcglobal.net Guest
Posted: Thu Nov 14, 2013 10:08 am Post subject: Trim motor speed control |
I would call TCW. I sent my Firgelli linear actuator (pitch trim) to them for approval. It was rated well over his specification, but in this application never sees much of a load. He approved it and it I'm using it now.
I would recommend his trim controller for just the stuck trim switch over ride protection alone. Speed control is also available and 2 speeds if you want that.
I'm not sure if they work with 28 v systems.
| Quote: | On Nov 14, 2013, at 9:45 AM, "donjohnston" <don(at)velocity-xl.com> wrote:
Don
http://forums.matronics.com/viewtopic.php?p=413041#413041
Posted: Thu Nov 14, 2013 10:18 am Post subject: Trim motor speed control |
First, why such a 'horse' of an actuator?
What are the force, speed and travel requirements
for moving the trim mechanism on your airplane?
With a full load current rating of 2.3A (assuming
that it's moving a 100# load), your voltage
control task is pretty simple. But with a PM motor,
inrush current is pretty high compared to the 2.3A
max running load.
things in the future so this wouldn't be the worst solution.'
How about this one?
Rated for 8A (plenty of headroom) but
in addition to an adjustable output voltage
(controls speed) there's an adjustable
current limit (controls inrush).
Use this dc/dc converter upstream of your
dpdt center off polarity control switch.
Set voltage for max desired speed. Then
set the current limit to some benign value
well above max rated load for the actuator . . .
say 3A.
Posted: Thu Nov 14, 2013 10:29 am Post subject: Trim motor speed control |
[img]cid:7.1.0.9.0.20131114122807.01f1ed78(at)aeroelectric.com.0[/img]
81.99 KB |
22437 Time(s) |
kuffel(at)cyberport.net Guest
Posted: Thu Nov 14, 2013 11:12 am Post subject: Trim motor speed control |
Don,
Agree with the others about the heftiness of your actuators. 100 pounds and
4 inch travel sounds like something for a jet. Finding a lower current
actuator would ease your problem.
But assuming you can't change actuators, here is a full featured 2 axis trim
controller:
Start with the circuit published in the June 2013 issue of Kitplanes
(schematic attached).
Modify the circuit to use an LM338 (40 volt, 5 amp, 7 amp surge, $2.03 from
Mouser) instead of the LM317 shown.
Power the low current logic part of the circuit with a separate regulator
(LM317) set to supply 12 volts. The heat sink specified is more than
adequate for both jobs.
This gives you all the features of the fanciest commercial controllers for
less than $35 in parts.
If you do not have access to the Kitplanes issue email me off list for a set
of figures, photos and text.
Tom
 Download |
| Filename: |
KPTrimAFig1.pdf |
56.98 KB |
| Downloaded: |
508 Time(s) |
Posted: Thu Nov 14, 2013 11:45 am Post subject: Trim motor speed control |
My link to the suggested power supply
didn't paste . . . her 'tis again.
| Quote: | How about this one?
http://tinyurl.com/mk6vs4l
| Quote: | Rated for 8A (plenty of headroom) but
say 3A.
Checked by AVG - www.avg.com
donjohnston
Posted: Thu Nov 14, 2013 5:22 pm Post subject: Trim motor speed control |
Don,
<< why such a 'horse' of an actuator? ... One word... Canard. >>
Must confess to still being confused. My Defiant had very light control
forces which were still heavier than any Eze I've seen. Assume you are
planning to use springs and not aerodynamic trim tabs? Could you supply
more information?
Tom
donjohnston
Posted: Fri Nov 15, 2013 4:37 am Post subject: Re: Trim motor speed control |
The aircraft is a Velocity XL. The trim motor is the one supplied by the factory.
donjohnston
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Fri Nov 15, 2013 5:56 am Post subject: Re: Trim motor speed control |
Motor Speed Control--
An important point of trim motor speed controlling is that the torque should not be reduced when the speed is reduced (in fact, it could go up...but not down). This makes regular voltage controllers undesirable except where torque isn't an issue.
The second point is that trim speed should usually be reduced as a function of airspeed. Often this is critical and can give the pilot sudden difficulties. Tee-ing off the pitot line and using the pressure signal is easy to do.
Many speed controls use an LM3524 modulating PWM chip and a P-fet to drive the trim motor that will take a voltage-input based on the pitot pressure. This makes the motor go faster at slow speeds and slower at high speeds. No input from the pilot is needed.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
bakerocb
Posted: Fri Nov 15, 2013 9:48 am Post subject: Trim motor speed control |
11/15/2013
Hello Don, Thanks for the quick response. I’ve got the picture. Take a look at the Firgelli Automations FA-SC24 Actuator Speed Controller seen here:
http://www.firgelliauto.com/product_info.php?cPath=99&products_id=362
Note the the 12V to 40V operating range.
OC
Sent: Friday, November 15, 2013 10:36 AM
To: Owen Baker (bakerocb(at)cox.net)
Subject: Re: Trim motor speed control
Owen,
Thanks for reaching out to me.
The aircraft is a Velocity-XL. I am trimming a canard-width elevator. I have been told by the factory and other builders that existing trim is right at the upper limit of usable speed. The trim motor is connected to a fiberglass leaf spring.
Fon
Sent from my Android mobile device.
Posted: Fri Nov 15, 2013 12:43 pm Post subject: Trim motor speed control |
At 07:56 AM 11/15/2013, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
An important point of trim motor speed controlling is that the torque should not be reduced when the speed is reduced (in fact, it could go up...but not down). This makes regular voltage controllers undesirable except where torque isn't an issue. |
Not true. Speed and torque are not directly related
in terms of motor performance. Speed of a motor is a
function of terminal voltage AND load on the motor.
Torque requirement for moving a flight control surface
is a function of aero-dynamic loads. For example, the
average torque needed to extend a flap from 0-10
degrees is often a small fraction of that required to
push it all the way out to 30 degrees.
Assuming one wishes to slow flap motion as it approaches
fully deployed, there is risk of having the motor STALL
under some conditions of load . . . the risk is a function
of motor resistance and a REDUCTION in available torque
at voltages intended to simply slow it down. It has NOTHING
to do with the manner in which voltage is controlled. You
can set the terminal voltage of the motor by means of regulated
power supply, battery, PWM controller, variable resistor,
you name it. As long as you're holding the motor voltage
constant, then it's possible to experience an unintended
STALL which is illustrated in the following plot of
an exemplar motor's performance in a pitch trim actuator.
[img]cid:.0[/img]
Folks that would like to explore all the details of
my assertion are invited to download the data package
at http://aeroelectric.com/articles/Motors
The figure above is an excerpt from one of the figures
in that data package. In high speed trim, applied voltage
was 26.5 volts which means that for ALL other conditions,
the motor speed can be predicted right off the plots.
Aerodynamic loads reflected to the motor ranged from .72 oz-in
to 1.82 oz-in. With high speed voltage applied, the motor
can be expected to run someplace between 3870 and 5304 rpm
for a variation of +/- 16%.
With low speed voltage applied, the same motor's speed
variance from center was predicted to be +/- 100
percent . . . with the motor stalling at max loads.
The data package speaks to the characterization of
motor stall current as (Eapplied-Ecemf)/Resistance
of the motor. Motors being operated at FIXED voltages
appear to 'lose torque' because their speed regulation
is terrible compared to the higher speed operation.
Note that torque-current demand on the motor at say 1.5 oz-in
is exactly the same irrespective of speed (applied
voltage). The motor appears 'crippled' because the SAME
variations in current (CAB) over designed torque range
is a LARGER PERCENTAGE of motor's predictable
behavior at the lower speed (FDE).
Virtually ALL voltage control methodologies popular
with the OBAM aviation community are simply modifications
to applied voltage. The seemingly 'crippled' behavior
of the motor will be the same no matter HOW that
voltage is adjusted. LM317, pwm . . . you pick it.
There ARE ways to close the loop on speed control
by sensing motor current and inserting a derived
correction of speed by increasing terminal voltage
as load increases . . . or by sensing motor speed
with some form of tachometer and closing the loop
on measured speed.
Assertions for expecting loads on a motor to
go UP as shaft speed goes down are incorrect,
the flight surface has no way to know that it's
moving slower . . . it IS influenced only by change
of dynamic pressure and moment arms.
| Quote: | | The second point is that trim speed should usually be reduced as a function of airspeed. Often this is critical and can give the pilot sudden difficulties. Tee-ing off the pitot line and using the pressure signal is easy to do. |
I've designed a number of pitch trim controllers.
The first two went on the Lear 55 and the second
was a fleet retrofit to the 30 series. I
proposed a continuously variable pitch trim rate
based on IAS but it proved unnecessary. Trim rates
optimized for cruising flight fell into one fairly
narrow range, speeds for approach to landing in another
narrow range. Turns out that approach:cruise trims
in the Lear systems were 4:1 ratio. Use a flaps-not-stowed
switch to select high speed and we were done.
Posted: Fri Nov 15, 2013 12:55 pm Post subject: Trim motor speed control |
At 11:46 AM 11/15/2013, you wrote:
Note also the notation:
The FA-SC24 is intended to control the speed of one Linear actuator or motor, Do not connect two actuators/motors to the same FA-SC24. The slowest the actuator/motor will run is about 10% of the full speed. Reducing the speed can affect the maximum load the actuator can move.
Motor current is proportional to load torque
at any speed. There will come a time as voltage
falls that STALL torque (Eapplied/Resistance of
Motor) is some number smaller than load torque
and the motor stalls.
The load torque doesn't rise because the speed
went down; ability to CARRY rated torque fell
off because stall current came down proportionally
with the drop in applied voltage.
If we could wind the motor with unobtainium having
zero resistance, the speed torque curve would not
have that left-to-right, downward slope . . . it would
be flat. This means that speed is absolutely locked
to applied voltage no matter what load is applied.
The same motor would be 100% efficient because it
doesn't get hot!
I've worked with designs that deliberately picked
a too-large motor with lower values of internal
resistance just to get a flatter speed-torque
curve without use of external electronic controls.
Bob . . . [quote][b]
Eric M. Jones
Posted: Mon Nov 18, 2013 12:52 pm Post subject: Re: Trim motor speed control |
EMJ said: An important point of trim motor speed controlling is that the torque should not be reduced when the speed is reduced (in fact, it could go up...but not down). This makes regular voltage controllers undesirable except where torque isn't an issue.
BN said: Not true. Speed and torque are not directly related in terms of motor performance. Speed of a motor is a function of terminal voltage AND load on the motor.
EMJ said: That’s absurd and examples are so trivial I won’t even bother to note one. Besides, I didn’t say they were related. The point is that motor speed for trimming and flaps should be reduced at high airspeed to prevent overstressing the pilot and the aircraft. This is common practice. I didn’t invent this idea. Furthermore reducing the voltage is a poor man’s way to reduce the speed of any actuator. I didn't invent that idea either.
BN said: Torque requirement for moving a flight control surface is a function of aero-dynamic loads. For example, the average torque needed to extend a flap from 0-10 degrees is often a small fraction of that required to push it all the way out to 30 degrees….
Folks that would like to explore all the details of my assertion are invited to download the data package at http://aeroelectric.com/articles/Motors ....
Virtually ALL voltage control methodologies popular with the OBAM aviation community are simply modifications to applied voltage….
EMJ said: And they are all wrong. Start with yours. The modern methods for changing motor speed without reducing torque … as I said…should be used.
BN said: Assertions for expecting loads on a motor to go UP as shaft speed goes down are incorrect…
EMJ said: And WHO said that Bob? I said the torque should not be reduced as the motor speed decreases…as is the case if the voltage is merely reduced.
EMJ said: The second point is that trim speed should usually be reduced as a function of airspeed. Often this is critical and can give the pilot sudden difficulties. Tee-ing off the pitot line and using the pressure signal is easy to do.
BN said: I've designed a number of pitch trim controllers. The first two went on the Lear 55 and the second was a fleet retrofit to the 30 series. I proposed a continuously variable pitch trim rate based on IAS but it proved unnecessary. Trim rates optimized for cruising flight fell into one fairly narrow range, speeds for approach to landing in another narrow range. Turns out that approach: cruise trims in the Lear systems were 4:1 ratio. Use a flaps-not-stowed switch to select high speed and we were done.
EMJ said: Whatever... but I’m not sure Learjet experience (where the amount of trim motion needed at 500 knots is tiny and the motor are big) is relevant for the stock RVs that have speed/trim problems using reduced voltage at high airspeeds.
Thanks...the loyal (occasional) opposition.
113 Brentwood Drive
(508) 764-2072
Posted: Mon Nov 18, 2013 1:54 pm Post subject: Trim motor speed control |
At 02:52 PM 11/18/2013, you wrote:
Help me out. Are you talking about available torque or
demanded torque? In the examples I cited and data plots
published, torque demanded is a function of the mechanism
being powered. I'm aware of no piece of machinery that
demands more torque as the speed is reduced.
A speed/torque 'curve' is not really curved but a
straight line that depicts motor speed/torque performance
based on terminal voltage applied. The 'curve' has
downward slope and is set by the motor's internal
resistance. Internal resistance limits AVAILABLE torque
at that voltage. My assertion is that for any applied
voltage you choose, performance of the motor is
predictable and easily illustrated by plotting the
appropriate 'curve'.
| Quote: | EMJ said: And they are all wrong. Start with
Okay, suppose the target speed is satisfied
by reducing applied voltage to say, 5 volts.
Describe the mechanism by which a motor's performance
is improved by using one form of voltage 'adjustment'
over some other form. I.e., what is the "modern method"
to which you refer?
| Quote: | EMJ said: And WHO said that Bob? I said the
Okay, you've answered the question. My apologies. Yes,
AVAILABLE torque can be degraded to the point where a
motor is at risk for stalling at the lower extreme of
RPM vs. available torque for the voltage applied. My
assertion is that 5 volts average applied voltage produces
the same performance irrespective of the mechanism by
which that voltage is produced.
| Quote: | EMJ said: Whatever... but I’m not sure Learjet
No argument that adjustable trim rates for aircraft
with broader operating speeds is a good thing and
may apply to airplanes of any size . . .
Pilots would like to ask for and get very tiny movements
in the trim system at cruise. If the motor speed is
optimized for that condition, then it's painfully slow
for setting the airplane up to land. The idea that
there was value in crafting a continuously adjustable
trim rate was rejected as unnecessarily complex. Lear's
pilots were quite happy with the 4:1 ratio.
Trim motor motion on a Beechjet at Mach cruise needed
to be so small that servoing to a speed was impossible.
The smallest trim adjustment offered by the autopilot
is a mere 133 milliseconds long.
The Lear systems were SERVOed speed controllers where
motor characteristics did not impact available torque
from the motors. Voltage was adjusted to hold target speed
irrespective of voltage or load. The controller that
finally went onto the airplanes held +/- 1% of target
speed over the full range of load, voltage and temperature.
In the Lear system, tachometers on the motor shafts
provided speed feedback data. The motors used in
OBAM aircraft are seldom fitted with such devices.
The PM motor CAN be used as it's own tach generator.
If you PWM the applied voltage 0ne can sample the Cemf
of the motor and use that value to report motor speed
to the servo-loop.
With a servoed speed control loop, the motor's
speed/torque curve no longer defines performance
limits at slow speed. The controller drives voltage to
maintain target speed even at the maximum expected load.
