rowedenny
Posted: Mon Nov 04, 2013 5:50 am Post subject: E-gearbox on a 582 powered Slingshot |
My friend Dave Lewis is considering swapping his B box for an E box to get the electric start and keep his pull start the way it is. Anyone know if the E box will bolt right on without interfering with the airframe? He has his engine raised slightly in the rear to get the prop close to square with the tail boom, and to increase rear fuselage prop clearance.
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, PA
Richard Pike
Posted: Mon Nov 04, 2013 7:43 am Post subject: Re: E-gearbox on a 582 powered Slingshot |
Here is how it fits on the FSII, don't know if it is the same, but this may help. You can at least see the relationship between all the usual Kolb parts and the starter.
130.72 KB |
5645 Time(s) |
120.9 KB |
5645 Time(s) |
126.41 KB |
5645 Time(s) |
118.5 KB |
5645 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
gajindra(at)sbcglobal.net Guest
Posted: Mon Nov 04, 2013 11:27 am Post subject: E-gearbox on a 582 powered Slingshot |
Don't know about the slingshot. On the Mark 3 you have to raise the motor or move it back. The starter hit the rear mount
Gary Jindra
To: Kolb-list <kolb-list(at)matronics.com>
Sent: Monday, November 4, 2013 8:49 AM
Subject: Kolb-List: E-gearbox on a 582 powered Slingshot
--> Kolb-List message posted by: Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)>
Dennis "Skid" Rowe
Mk3, 690L-70, Leechburg, om/contribution" sp; &tronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com= - MATRONICS WEB FORUMSttp://forums.matronics.com/" target="_blank">http://forums.matronics.com/=================
Thom Riddle
Posted: Tue Nov 05, 2013 4:05 am Post subject: Re: E-gearbox on a 582 powered Slingshot |
Raising the rear of the engine a bit on the Slingshot is a good idea anyway because the thrust line is higher than ideal (pointed up in front) if parallel to the engine mount tube. This is not the case for most Kolbs but it is for the Slingshot.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
