CJ Questions
PS
PostPosted: Wed Oct 30, 2013 8:12 pm    Post subject: CJ Questions Reply with quote
My latest Red Star aircraft is on it's way from Vancouver BC by way of a less than friendly customs. Customs was asking for 30% duty but finally relented and let my friend and aircraft continue south. This particular CJ is a 1996 model.
I would like to know what mod was done to replace the nosewheel and why?
This aircraft has an intake scoop on the right cowl side, I have never seen this. What is it for?
Lastly, it has all the Chinese radios and from what my friend told me, the ADF is digital. Anyone ever see one of those? Is the comm radio usable?
I am very curious to see this aircraft with my own eyes, it sounds like a nice plane.
 Filesize:  365.78 KB
 Viewed:  14678 Time(s)
Phil
jdeuchar
PostPosted: Thu Oct 31, 2013 5:34 am    Post subject: CJ Questions Reply with quote
Wow sounds like some changes have been made to the basic model. I thought
about going out and seeing what a 1996 looks like, but I didn't think they
would have made any changes.
Jeff
jetjockey
PostPosted: Thu Oct 31, 2013 1:27 pm    Post subject: Re: CJ Questions Reply with quote
I have been curious about the new intake on the cowling for some time. I suspect it is associated with a cabin heat system. Please report what you find and upload some pictures if able.
kelmonroe(at)comcast.net
PostPosted: Thu Oct 31, 2013 2:49 pm    Post subject: CJ Questions Reply with quote
I have a 1976 CJ that also has an intake vent on the right side of the
engine lower cowling. It also has a tube running between the fire walls on
the lower right side. With a hole in both fire walls. I also would like to
know what these are for. I have owned 6 CJ's and none of the first 5 had
this on them.
Kelley
PS
PostPosted: Thu Oct 31, 2013 7:56 pm    Post subject: Re: CJ Questions Reply with quote
I guessed the same, cabin heat. I believe my last CJ had it also, Keith McKinley now flies it, maybe he has an answer. It also had the holes in the bulkheads. I will take pictures when able.
Phil
Phil
wlannon(at)shaw.ca
PostPosted: Thu Oct 31, 2013 8:37 pm    Post subject: CJ Questions Reply with quote
How about improved cooling for the air compressor?
Walt
keithmckinley
PostPosted: Wed Dec 04, 2013 5:49 pm    Post subject: Re: CJ Questions Reply with quote
I have never been able to figure it out Phil. There are tube flanges on both sides of the bulkhead. I assumed one was for a heating system and the other maybe just fresh air off that scoop you mention. I've since added an additional blast tube in the gills and use the flanges you describe to run a scat tube to the rear cockpit. The positive pressure helps keep smoke entering the cockpit from my smoke system to a minimum.
PS
PostPosted: Wed Dec 04, 2013 9:33 pm    Post subject: Re: CJ Questions Reply with quote
Thanks Keith,
I was able to visit my CJ in CA and found I have scoops on both sides of my cowl. Both have felt seals on the inside which sealed the heat muff to the cowl. From the firewall back, there is around 2 1/2" metal insulated tubing to a heat valve on each side of the cockpit. The right side feeds the front heat and defrost, the left side tube feeds the rear cockpit.
I do not have the heat muffs and the firewall inlets are sealed.
Phil
Phil
PS
PostPosted: Thu Dec 05, 2013 2:47 pm    Post subject: Re: CJ Questions Reply with quote
Heat system in my CJ.
 Filesize:  89.32 KB
 Viewed:  14416 Time(s)
 Filesize:  71.29 KB
 Filesize:  88.02 KB
 Filesize:  99.44 KB
 Filesize:  117.99 KB
 Filesize:  82.17 KB
Phil
rmhou(at)yahoo.com
PostPosted: Thu Dec 05, 2013 3:36 pm    Post subject: CJ Questions Reply with quote
Very interesting.
I have been working on my cabin heat install for the last couple weeks. It is a DIY system. Sonic Headers made my heat muff: http://sonicheaders.com/
This picture was taken when I put the heat muff on no. 8 which is the cylinder I told Sonic Headers to build my heat muff for. They built it for no. 4 instead, so the picture does not represent its final installation. It turns out that having the heat muff on no. 4 is a better location than on no. 8.
I just received some SCAT duct from Aircraft Spruce and should finish my installation this weekend. I will take more pictures this weekend.
Robin
To: yak-list(at)matronics.com
Sent: Thursday, December 5, 2013 2:47 PM
Subject: Re: CJ Questions
--> Yak-List message posted by: "PS" <psalter(at)aol.com (psalter(at)aol.com)>
Phil
http://forums.matronics.com/viewtopic.php?p=414946#414946
http://forums.matronics.com//files/img_0172_254.jpg
http://forums.matronics.com//files/img_0150_103.jpg
http://forums.matronics.com//files/img_0108_143.jpg
http://forums.matronics.com//files/img_0107_210.jpg
http://forums.matronics.com//files/img_0098_159.jpg
http://forums.matronics.com//files/img_0095_109.jpg
ber is the Annual List Fund lectric www.aero="_blank" href="http://www.buildersbooks.com/">www.buildersbooks.com</a* My Pilot Store <a target="_blank" href="http://www.mypilotstore.com/" &nbs========================<br========
 Filesize:  1.64 MB
 Viewed:  14409 Time(s)
wlannon(at)shaw.ca
PostPosted: Thu Dec 05, 2013 7:07 pm    Post subject: CJ Questions Reply with quote
Interesting! Thanks Phil
Walt
Harv
PostPosted: Mon Dec 09, 2013 1:59 am    Post subject: Re: CJ Questions Reply with quote
Thanks for sharing
Flying about in the uk at this time of year its cold, i'm interested to fit a system to warm both cockpits.
I noticed Doug S lists a heater conversion, anyone fitted one of these kits?
Rgs
Harv
cjpilot710(at)aol.com
PostPosted: Mon Dec 09, 2013 5:07 am    Post subject: CJ Questions Reply with quote
Harv,
Being a swamp dweller, there isn't much need for one here, but you might look into electric heaters. I've seen "Yankee" CJs with small electric quarts heater mounted that run off 24v who's pilot swore were more than adequate. The installations were small, neat, and most important, simple.
Jim "Pappy" Goolsby
In a message dated 12/9/2013 5:00:43 A.M. Eastern Standard Time, martin.harvey(at)kbr.com writes:
--> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com>
Thanks for sharing
Rgs
Harv
http://forums.matronics.com/viewtopic.php?p=415173#415173
