BarryH
Posted: Mon Oct 28, 2013 8:41 am Post subject: Wing removal on a TR-1 |
Can anyone tell me if the wing will drop out with the gear in place on a tricycle gear TR-1? Any information would be greatly appreciated.
mantafs(at)earthlink.net Guest
Posted: Mon Oct 28, 2013 5:40 pm Post subject: Wing removal on a TR-1 |
On mine it will but it is not an easy fit. Some light bending of the wing skins and a little force are needed. But each build is a little different.
Keith.Miller(at)esa.int Guest
Posted: Tue Oct 29, 2013 12:07 am Post subject: Wing removal on a TR-1 |
Yes , it can be dropped out with all the gear in place, i did it on many
occassions during the build , and once after the completion.
Keith
To: kis-list(at)matronics.com,
Date: 10/29/2013 02:42 AM
Subject: Re: Wing removal on a TR-1
Sent by: owner-kis-list-server(at)matronics.com
sstearns2(at)yahoo.com Guest
Posted: Tue Oct 29, 2013 10:59 am Post subject: Wing removal on a TR-1 |
Here is a picture of the wing removal tool I built. It has 4x4s at the corners and is on wheels. The vertical 2x4s should be vertical and not angled like the picture. The wing drops out of the fuselage and slips between the 2x4s before it comes out of the fuselage so the wing is always supported. It is also really nice to have the wing on wheels.
It makes it a one man job and pretty low stress. The wing probably went on with the gear on so it should come off.
Scott
On Tuesday, October 29, 2013 1:13 AM, "Keith.Miller(at)esa.int" <Keith.Miller(at)esa.int> wrote:
--> KIS-List message posted by: Keith.Miller(at)esa.int (Keith.Miller(at)esa.int)
Keith
From: Mark Kettering <mantafs(at)earthlink.net (mantafs(at)earthlink.net)>
To: kis-list(at)matronics.com (kis-list(at)matronics.com),
Sent by: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)
--> KIS-List message posted by: Mark Kettering <mantafs(at)earthlink.net (mantafs(at)earthlink.net)>
390.13 KB |
19834 Time(s) |
Posted: Tue Oct 29, 2013 6:06 pm Post subject: Wing removal on a TR-1 |
All I can say is that picture makes me want a Yak.
And I love your tail wheel stand.
And your wing tool is very cool. I think I will be making one.
Posted: Tue Oct 29, 2013 6:56 pm Post subject: Wing removal on a TR-1 |
The Yak is for sale. Price is about $1M but open to offers. 1600 HP R-2000. It will just walk away from anything with a propeller short of the gold class at reno. It really pisses the mustang crowd off. "work of art" build quality.
Scott
On Oct 29, 2013, at 7:06 PM, Mark Kettering <mantafs(at)earthlink.net> wrote:
BarryH
Posted: Tue Oct 29, 2013 7:55 pm Post subject: Re: Wing removal on a TR-1 |
Thanks guys for the information. I just purchased a TR-1 and i am going to get it this weekend. Need to transport it home as it is not currently airworthy. That will make it much easier not having to remove the gear. I also have seen where some people have had some of the wing spar bolts seized as well. Hopefully this is not the case. This plane has been out in the weather for about 9 years though.
mark_trickel
Joined: 13 Dec 2011 Posts: 101 Location: Philadelphia, PA, USA
Posted: Wed Oct 30, 2013 7:24 am Post subject: Re: Wing removal on a TR-1 |
Hello Barry,
Congratulations on your purchase and welcome to the fraternity. Without a question you got the best bang for your buck despite any problems you may encounter. On this forum are plenty of qualified individuals that can help you with any need.
You might want to be packing a Sawzall just in case the main spar bolts are seized in place. There should be just enough room to get the blade between the spar and the fuselage spar box. The penalty would be the loss of the aluminum flanged bushings in the spar box (the bushing on the nut side should be removable if not gluded in place), but those parts should be available from Lyle Hendricks. You’ll need to disconnect the aileron push tubes from the bell cranks to side the tubes out of the fuselage. This past spring I moved my TR-1C 1200 miles from Minnesota to Philadelphia, PA, I did not realize the push tubes were disconnected as the wing was off when I arrived to pick up the airplane. I checked the airplane at each fuel stop but on the last run over the PA mountains one push tube slid out and I almost lost it but it got wedged in place by one of the wing supports. I used the spar bolts as the main attach point along with the wheel axles and the tail wheel to hold it on the trailer. My advices is don’t buy that cheap duct tape from Harbor Freight it sucks.
Robert Reeds website has a complete TR-1 builders manual if you do not have one. http://www.kisbuild.r-a-reed-assoc.com/
Good Luck,
Mark T. Pic attached of my arrival at home
PS: There is also a new owner of Ed Foresters TR-1 that was in Florida
168.3 KB |
19801 Time(s) |
BarryH
Posted: Wed Oct 30, 2013 7:31 am Post subject: Re: Wing removal on a TR-1 |
Very cool. Thanks for the info. Yes, i packed a sawzall with me just in case. We are moving it 2500 miles from Reno to Knoxville. Lond haul. But i look forward to getting it here and starting my refurbish of the plane. Definatly looks like there is some good advice to be had here on this forum. Barry
bakerocb
Posted: Wed Oct 30, 2013 7:47 am Post subject: Wing removal on a TR-1 |
10/30/2013
Hello Barry, You wrote:
1) "We are moving it 2500 miles from Reno to Knoxville."
Wow! I am really impressed with your ambition. Who built the plane and who
did you buy it from? Engine and any other particulars?
2) "Definatly looks like there is some good advice to be had here on this
forum."
Absolutely true and not just in the current postings, but in years of past
postings buried (but accessible) in the archives. We can help you find some
nuggets in there.
OC
Sent: Wednesday, October 30, 2013 11:31 AM
Barry
jconners(at)dot.state.nv. Guest
Posted: Wed Oct 30, 2013 7:57 am Post subject: Wing removal on a TR-1 |
Barry:
The fiberglass cover plates are 'glued' inplace and several of the screws that originally held the cover plates in place are stripped and the incorrect size...therefore removal of the cover plates will require some effort and a variety of tools to free the plates without damaging the attachment location.
Jer
N94K owner/pilot 2001-2012(?)
BarryH
Posted: Wed Oct 30, 2013 8:17 am Post subject: Re: Wing removal on a TR-1 |
Thanks for the info Jerry. Hopefully the main spar bolts are ok.
This plane was built by Kindig. N94K. #095. Has a 0-235 in it. Considering putting a 0-320 on it. Owned by Jerry Conners for quite some time there in Nevada. Needs some TLC, but looks to be a plane that can be really nice once it is refurbished.
Posted: Wed Oct 30, 2013 8:43 am Post subject: Wing removal on a TR-1 |
Barry:
When you get the construction manuals and other documents that I gave to Darren, then you will have a more accurate record of who the builders and owners were...although R Kindig was the 51% designated builder, much of the original kit assembly was performed by someone earlier.
Jer
BarryH
Posted: Wed Oct 30, 2013 8:51 am Post subject: Re: Wing removal on a TR-1 |
Yes, I have all the documents. He bought the fuselage from a guy, and then bought the wings from the manufacturer. I saw where the fuselage was partially built when he purchased it from Brett Nicolette.
mark_trickel
Posted: Wed Oct 30, 2013 5:43 pm Post subject: Re: Wing removal on a TR-1 |
Hey Barry,
Jerry is referring to the 6” X 6” access panels on the outboard underside of each wing located over the aileron bell crank. The left wing should also have the pilot static ports attached to it. These panels are cut into the wing skins by the builder and have 4 screws in the corners of each panel. There were supposed to be nut plates attached to the inner fiberglass layer of the laminated wing skin in each corner to secure the panel to the wing. Not all builders used nut plates, my build used plain sheet metal screws and they just do not hold up. I believe Jerry is saying the panel may be glued in place. You may want to pack two more tools – a Dremel with those little gridding discs and possibly a few other cutting attachments, and if that don’t work a jig saw to cut out the whole panel. Heck, its fiberglass and easy to patch up or fabricate a new one, but don’t cut to close to the corners where the nut plates are supposed to be just in case they may actually be there. You won’t want to be wasting too much time getting the cover panels off you’ll have you hands full getting the wing off and the plane loaded. It took me 4 hours to set up my trailer rigging and get the plane loaded and that was 2 hours more than I thought it would take.
There are other fairings on the bottom side of the fuselage you will need to remove. One covering the spar box opening. Two small removable leading edge fairings on underside of the wing. Two larger fairings that contour the wing to the fuselage. These should all have nut plates used to attach them but may also have sheet metal screws in place. If they are nut plate and corrosion has set in getting those screws out can be difficult. If the heads become stripped out the Dremel and thin griding disc deal is great to cut larger slots in the head for easier removal.
Richard Kindig did come to Oshkosh, maybe even more than once. I recall he was at one of the KIS get together dinners. It is hard for me to remember everything that happened but I do recall Richard K. telling us he liked building airplanes and was in the habit of buying derelict or unfinished projects and finishing them off, then enjoying them for a while, and then he'd sell them and move on to another project. Before he bought the KIS he previously finished off a Glasair. There are several post in the KIS archives by Richard K. He was unmarried and so he had plenty of time for airplane building. I am sure there were other airplane projects after his KIS. I think he did finally settle down and get married. He is now living in one of the Virginia States, though I am not sure which one.
Mark T.
BarryH
Posted: Thu Oct 31, 2013 4:06 am Post subject: Re: Wing removal on a TR-1 |
Great information. Thank you
bakerocb
Posted: Thu Oct 31, 2013 5:00 am Post subject: Wing removal on a TR-1 |
10/31/2013
Hello All KIS Builders and Maintainers, Mark Trickel wrote: “If they are nut plate and corrosion has set
in getting those screws out can be difficult.”
Amen. And a great way to avoid that head stripping problem in the future is to avoid using Phillips drive machine screws. Hex socket (Allen drive) and 6 lobe (Torx drive) machine screws are vastly superior and not just for avoiding the stripping out problem.
Every builder that has ever tried the non Phillips drive screws has become a believer. (Bill Harrelson, the guy that flew his Lancair IV non stop from Guam to Jax FL, recently thanked me profusely for steering him right on machine screw drives and told me that he had built his plane with almost no Phillips drive screws.)
You can obtain these hex socket and 6 lobe drive screws, in stainless steel if you wish, and with aviation 100 degree countersink on the flat heads, from Microfasteners:
http://www.microfasteners.com/
When working with these screws the proper drive tools such as a kit from Chapman is essential:
http://www.chapmanmfg.com/
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
Time: 06:44:08 PM PST US
From: "mark_trickel" <marktrickel(at)gmail.com (marktrickel(at)gmail.com)>
Hey Barry,
Jerry is referring to the 6 X 6 access panels on the outboard underside of each
pack two more tools a Dremel with those little gridding discs and possibly a
few other cutting attachments, and if that dont work a jig saw to cut out the
but dont cut to close to the corners where the nut plates are supposed to be
just in case they may actually be there. You wont want to be wasting too much
time getting the cover panels off youll have you hands full getting the wing off
for easier removal.
which one.
Mark T.
BarryH
Posted: Thu Oct 31, 2013 5:14 am Post subject: Re: Wing removal on a TR-1 |
Yes, I agree. I will definatly not use phillips heads when I attach it back on. I have already removed those panels and most all of the screws were stripped out.
galinhdz(at)gmail.com Guest
Posted: Thu Oct 31, 2013 8:52 am Post subject: Wing removal on a TR-1 |
I echo what OC posted. My TR4 is almost completely 6 lobe Torx and this makes a huge difference and the price difference is so small. It is a great investment.
On Thursday, October 31, 2013, Owen Baker wrote:
[quote] 10/31/2013
OC
Subject: KIS-List: Re: Wing removal on a TR-1
From: "mark_trickel" <[url=javascript:_e({}, 'cvml', 'marktrickel(at)gmail.com');]marktrickel(at)gmail.com[/url]>
Hey Barry,
for easier removal.
which one.
Mark T.
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
Posted: Thu Oct 31, 2013 9:15 am Post subject: Wing removal on a TR-1 |
It is just beyond my comprehension that we, in the 21st century, still use flat or phillips head screws for anything.
Scott
On Oct 31, 2013, at 5:59 AM, "Owen Baker " <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote] 10/31/2013
OC
Hey Barry,
for easier removal.
which one.
Mark T.
cs.com
matronics.com/contribution
