Garmin stack
thornytoo1(at)hughes.net
PostPosted: Tue Oct 15, 2013 5:11 pm    Post subject: Garmin stack Reply with quote
I just picked up my Tiger with a new Garmin stack. Eliminated the vacuum system completely, but I just couldn’t get by without one round dial left over!!! This pic shows the new number, but right now I still operate with N28546. Work was done by Santa Fe Aero Services.
 Filesize:  922.45 KB
 Viewed:  27497 Time(s)
Discover
PostPosted: Tue Oct 15, 2013 6:38 pm    Post subject: Garmin stack Reply with quote
Wow!
I want a G500...and , well I like your whole panel
Ned
On Oct 15, 2013, at 8:09 PM, "Patricia Kirkpatrick" <thornytoo1(at)hughes.net (thornytoo1(at)hughes.net)> wrote:
<![endif]--> <![endif]-->
<Tiger Panel.jpg>
halb221(at)centurylink.ne
PostPosted: Wed Oct 16, 2013 4:01 am    Post subject: Garmin stack Reply with quote
GREAT LOOKING Panel!!!!!!!!!!!!!!!!!
Hal B
jamey
PostPosted: Wed Oct 16, 2013 7:54 am    Post subject: Garmin stack Reply with quote
Sweet looking panel Patricia. Autopilot?
From: Patricia Kirkpatrick <thornytoo1(at)hughes.net (thornytoo1(at)hughes.net)>
Reply-To: Team-Grumman <teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)>
Date: Tuesday, October 15, 2013 6:09 PM
Subject: Garmin stack
lverrone(at)gmail.com
PostPosted: Wed Oct 16, 2013 9:31 am    Post subject: Garmin stack Reply with quote
Really nice.
On Tue, Oct 15, 2013 at 9:09 PM, Patricia Kirkpatrick <thornytoo1(at)hughes.net (thornytoo1(at)hughes.net)> wrote:
teamgrumman(at)yahoo.com
PostPosted: Wed Oct 16, 2013 10:56 am    Post subject: Garmin stack Reply with quote
Nice panel.
Route the static line and wires down along the pitot line.
On Wednesday, October 16, 2013 11:27 AM, Lee Verrone <lverrone(at)gmail.com> wrote:
Really nice.
[quote]http:/t; htt
stockercarolm(at)gmail.co
PostPosted: Wed Oct 16, 2013 11:06 am    Post subject: Garmin stack Reply with quote
Wow!!! How much? Really nice...Sent via BlackBerry by AT&T
Sender: owner-teamgrumman-list-server(at)matronics.com
Date: Wed, 16 Oct 2013 13:17:07 -0400
To: Teamgrumman<teamgrumman-list(at)matronics.com>
ReplyTo: teamgrumman-list(at)matronics.com
Subject: Re: TeamGrumman-List: Garmin stack
Really nice.
On Tue, Oct 15, 2013 at 9:09 PM, Patricia Kirkpatrick= <thornytoo1(at)hughes.net (thornytoo1(at)hughes.net)> wrote:
I just picked up my Tiger with a new Gar= min stack.=A0=A0 Eliminated the vacuum system completely, but I just couldn= =92t get by=A0 without one round dial left over!!!=A0 This pic shows the ne= w number, but right now I still operate with N28546.=A0 Work was done by Sa= nta Fe Aero Services.
cannuck
PostPosted: Wed Oct 23, 2013 6:11 pm    Post subject: Re: Garmin stack Reply with quote
Who's the moderator here? I didn't think we were allowed to post porn.
AA1 and AA5B former (future?) owner
pkuhns
PostPosted: Thu Oct 24, 2013 5:14 am    Post subject: Re: Garmin stack Reply with quote
Go do a registry search on his N number. Would like to know the story behind it...
http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=731PK
N27161, 1979 Grumman (Gulfstream) Cheetah
PostPosted: Fri Oct 25, 2013 8:54 am    Post subject: Garmin stack Reply with quote
What's the mystery? I do not see anything out of line.
cannuck
PostPosted: Sat Oct 26, 2013 6:39 am    Post subject: Re: Garmin stack Reply with quote
First of all, let me congratulate you on the cleanest panel I have ever seen in a AA/GA/AG airplane.
I assume the little horizon is the autopilot annunciator, but what autopilot?
BTW: fantastic high res pic of the panel - just can't read annunciator brand name anywhere.
PostPosted: Sat Oct 26, 2013 7:25 am    Post subject: Garmin stack Reply with quote
The little horizon is a "Sam" by Mid-Continent Instruments. It is strictly a backup instrument in case of loss of the G500, as it has it's own battery. The reason I had to keep the turn coordinator is because when I get an autopilot installed it will need to go in that hole and uses the turn coordinator data. As of now I have no autopilot installed. Maybe next year after my bank account recovers a bit!! Thank you for the compliments.
cannuck
PostPosted: Sun Oct 27, 2013 6:37 am    Post subject: Re: Garmin stack Reply with quote
Obviously, your avionics supplier has a very good understanding of what does what, and what plays well with others. Just thought you might be interested in this Aviation Consumer article - that pretty much precludes going with STec if you want simplest interface with G500.
http://dealers.aspenavionics.com/pdfs/Aviation-Consumer-Aspen-Garmin-Glass_0511.pdf
Thanks for identifying "Sam". At 10 Gs a pop, not exactly for the faint of heart, but what a fantastic bit of kit for someone serious about avioncs and backup!!!
Discover
PostPosted: Sun Oct 27, 2013 6:57 am    Post subject: Garmin stack Reply with quote
I would question this thesis of an interface problem between G/500 and STEC as the article is from a pro Aspen view.
http://forums.matronics.com/viewtopic.php?p=411523#411523
Discover
PostPosted: Sun Oct 27, 2013 9:10 am    Post subject: Garmin stack Reply with quote
Here is another Tiger equipped with a G-500 AND interfaced with an STEC 30 that I understand work quite well together.
Also has an MT Prop
Makes me drool;)
 Filesize:  477.1 KB
 Viewed:  27318 Time(s)
 Filesize:  331.86 KB
cannuck
PostPosted: Sun Oct 27, 2013 2:41 pm    Post subject: Re: Garmin stack Reply with quote
Discover:
WOW, that is another stunning display of neat hardware. This time with the full blown 930 instead of 900, but the SAM trumps the lot for going all of the way.
I did go back and read the AC article more carefully, and it does indeed have a definite bias, but I believe based on the cost/benefit to those who might not have the full set of Garmin radio gear to run a G500.
The autopilot deal is not that it won't communicate, but that it can not be in full command of the servos without retaining the autopilot's gyro reference system instead of direct output from the G500 AHRS. The 1000 won't do that either (but IIRC WILL with Century). Also, I think the G500 needs a card to send to STec autopilot???
