aileron and flap close outs
wdaniell.longport(at)gmai
PostPosted: Mon Oct 21, 2013 4:27 am    Post subject: aileron and flap close outs Reply with quote
Has anyone filled these?  Is this the general practice?
I am thinking that the “hollow” area of the close out should be filled with something light like blue foam.
Will
nigel_graham(at)m-tecque.
PostPosted: Mon Oct 21, 2013 5:36 am    Post subject: aileron and flap close outs Reply with quote
I'm not sure if its general practice but I did it to both the flaps and ailerons. Makes for a neat end with a very clean gap and eliminates the eddies. I just tapped the flap end-on to the prepared foam to print the exact profile before cutting - easy.
Nigel
On 21/10/2013 13:26, William Daniell wrote:
<![endif]--> <![endif]-->
Will
 Filesize:  2.86 MB
 Viewed:  5863 Time(s)
rlborger(at)mac.com
PostPosted: Mon Oct 21, 2013 12:27 pm    Post subject: aileron and flap close outs Reply with quote
Will,
FWIW, I did as Graham and filled the ends of the flaps, ailerons and closeouts with foam, lightweight filler & a layer of glass. Don't know that it does much aerodynamically, but I think it looks better.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Oct 21, 2013, at 7:26 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will
style="color: purple; text-decoration: underline; ">http://www.matronics.com/Navigator?Europa-List
purple; text-decoration: underline; ">http://forums.matronics.com
style="color: purple; text-decoration: underline; ">http://www.matronics.com/contribution
Fred Klein
PostPosted: Mon Oct 21, 2013 12:46 pm    Post subject: aileron and flap close outs Reply with quote
Will...Ditto...Fred
Fred Klein
PostPosted: Mon Oct 21, 2013 12:58 pm    Post subject: aileron and flap close outs Reply with quote
Will...when I filled mine, I formed a guide for the flap drive pin...Fred
[img]cid:E601CFEE-237F-453A-801C-37F69ED6EC76[/img]
 Filesize:  17.52 KB
 Viewed:  5848 Time(s)
grahamsingleton(at)btinte
PostPosted: Mon Oct 21, 2013 1:51 pm    Post subject: aileron and flap close outs Reply with quote
That's what you need for one man rigging. Works too.
Graham
Sent: Monday, 21 October 2013, 21:57
Subject: Re: aileron and flap close outs
[img]cid:1.852549377(at)web87703.mail.ir2.yahoo.com[/img]
 Filesize:  17.52 KB
 Viewed:  5844 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Oct 21, 2013 2:23 pm    Post subject: aileron and flap close outs Reply with quote
Hi! Will.
I actually included a tapered guide tube to receive the flap drive shaft so it engages on the drive pin when doing self assembly rigging
And I recall that I included some backing foam within the construction and arranged for the close out to fit close to the fuselage but it needs fairing into match the wing to fuselage radius when the flaps are in retracted position.
There is photo on the site  which John Cliff runs.:- http://www.users.waitrose.com/~jcliff/BobH/FlapCov/Flapcovs.htm
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of William Daniell
Sent: 21 October 2013 13:27
Subject: aileron and flap close outs
Will
PostPosted: Wed Oct 23, 2013 12:32 pm    Post subject: aileron and flap close outs Reply with quote
Thats what I’ll do then!
Thanks everyone
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bob Harrison
Sent: Monday, October 21, 2013 17:23
Subject: RE: aileron and flap close outs
Hi! Will.
Bob Harrison G-PTAG
