Fuel Pump Issue
Goto page 1, 2  Next
rleffler
PostPosted: Sun Oct 20, 2013 1:11 pm    Post subject: Fuel Pump Issue Reply with quote
As several already are aware, I had some fuel flow issues on my first flight. At the time, in the air, I wasn’t quite sure what the issue may have been. It was initially looking like a blocked fuel line. The symptom was that the fuel pressure dropped significantly, but came back up with the electric fuel pump turned on and switching the tanks. I promptly landed and started looking for the root cause.
<![if !supportLists]>1. <![endif]>The left and right tank fuel flow (measured at the firewall, forward of the filter and pump) was 58 gallons/hour. Rules out a blockage aft of the firewall.
<![if !supportLists]>2. <![endif]>The fuel vents are not obstructed
I ran the engine in a static test. Was getting about 20psi on the engine fuel pump and about 26psi with the electric fuel pump enabled. Since this is all within specifications, this is the worst of all the scenarios. No root cause and everything seems to be working as designed.
This morning I flew for about an hour on flight #2.
When I turned off the electric fuel pump, fuel pressure started to immediately drop. I let it drop to about 10psi before I re-engaged the electric fuel pump. With the electric fuel pump running, I was getting 26psi. I repeated this scenario multiple times on both fuel tanks during the flight. Results were pretty consistent.
It’s looking like I may have a bad fuel pump on this 1 SNEW YIO-540-D4A5. I plan on giving Lycoming a call in the morning.
My questions is there any other scenarios that I’m overlooking that may yield similar symptoms?
bob
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
flying-nut(at)cfl.rr.com
PostPosted: Sun Oct 20, 2013 1:46 pm    Post subject: Fuel Pump Issue Reply with quote
With the info presented I think you're spot on. I agree with the call to Lycoming .... they should ship you a new pump. Up to you to do the R&R which has always been a PITA for me. My best guess is that there is some small piece of trash (don't know what else to call it) hung up in one of the valves.
Linn
On 10/20/2013 4:47 PM, Bob Leffler wrote:
1. The left and right tank fuel flow (measured at the firewall, forward of the filter and pump) was 58 gallons/hour. Rules out a blockage aft of the firewall.
2. The fuel vents are not obstructed
bob
Checked by AVG - www.avg.com
10/20/13 [b]
Kellym
PostPosted: Sun Oct 20, 2013 2:37 pm    Post subject: Fuel Pump Issue Reply with quote
You could download your engine data from your EFIS, and look at both
fuel pressure and fuel flow simultaneously. I don't think there is an
issue with your fuel pressure sensor, but it would be good to see what
was happening on fuel flow at the same time pressure was dropping. The
mechanical pump is supposed to be able to handle up to -2 psi input, i.e
overcoming an uphill flow on the input side.
There is one other possibility. You could have a leak between the
electric pump and the mechanical pump. If that is the case, the
mechanical pump sucks air through the leak, which reduces the pressure
to the engine, while the electric pump will over come this.
Rule out the chance of an air leak between boost pump and mechanical
before assuming that mechanical pump is bad.
Linn
> 1.The left and right tank fuel flow (measured at the firewall,
> 2.The fuel vents are not obstructed
> Thanks,
> bob
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> 10/20/13
Kelly McMullen
KCHD
rleffler
PostPosted: Sun Oct 20, 2013 3:05 pm    Post subject: Fuel Pump Issue Reply with quote
Here’s the Fuel Flow and Fuel Pressure overlaid. The dips are consistent when I turned off the electric fuel pump. An interesting anomaly is that the fuel pressure is higher during taxi with the boost pump off.
Finding a fuel leak is pretty straight forward, especially with the aid of the blue dye. How do you find a connection that doesn’t leak fuel, but does allow air?
bob
 Filesize:  15.89 KB
 Viewed:  16651 Time(s)
Bob Leffler
N410BL - Phase I
PostPosted: Sun Oct 20, 2013 3:10 pm    Post subject: Fuel Pump Issue Reply with quote
Good point Kelly. I had an air leak in the fuel line between the tank
and wobble pump on my Pitts. It almost drove me nuts .... well, more
nuts! I couldn't see that the rudder pedal had worn a hole in the hard
line. My fault .... the result of poor repairs .... but it was really
difficult to find since the problem .... engine surged like an old
Sopwith .... because the rudder pedal would cover the hole and 'fix' the
problem!!! The leaking fuel was so slight that it evaporated and left
no smell. Good call!
Linn
i.e overcoming an uphill flow on the input side.
> Linn
>> Thanks,
>> bob
>> 10/20/13
speckter(at)comcast.net
PostPosted: Sun Oct 20, 2013 3:11 pm    Post subject: Fuel Pump Issue Reply with quote
Since you can't reproduce this on the ground I am wondering if you have an airflow created vacuum on the tank vents. I may be all wet, but if there is a difference between flight and ground, it shouldn't be a mechanical problem.
Gary Specketer
Sent: Sunday, October 20, 2013 4:47:25 PM
Subject: Fuel Pump Issue
bob
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
Kellym
PostPosted: Sun Oct 20, 2013 4:05 pm    Post subject: Fuel Pump Issue Reply with quote
On the ground, throttle and mixture full aft, idle cutoff; turn on
electric pump with tunnel open and cowling off. After pressure comes up,
look for leaks. Anything that lets in air under suction will leak under
pressure. Ideally a couple observers, one in reach of the switch to kill
pressure as soon as leak is spotted.
pump off.
bob
Kelly McMullen
KCHD
cooprv7(at)yahoo.com
PostPosted: Sun Oct 20, 2013 4:54 pm    Post subject: Fuel Pump Issue Reply with quote
The likely culprit does sound like the fuel pump, although the fact that all is well on the ground is interesting. My first project was a Q-2 and when I upgraded from the VW engine to an O-200 I had lots of fuel starvation issues. After an eternity I chased it down to the fact that when I had to modify the shape of the cowl it created an area of negative pressure at the fuel vent. While not too likely your issue, I'd make sure you have your vents as directed in the plans. Even something as simple as having the angled cutoff facing the wrong way could make for interesting problems.
Good luck,
Marcus
On Oct 20, 2013, at 7:11 PM, speckter(at)comcast.net (speckter(at)comcast.net) wrote:
Gary Specketer
From: "Bob Leffler" <rv(at)thelefflers.com (rv(at)thelefflers.com)>n't
bob
style="color: purple; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
purple; text-decoration: underline; ">http://forums.matronics.com
style="color: purple; text-decoration: underline; ">http://www.matronics.com/contribution
PostPosted: Sun Oct 20, 2013 5:05 pm    Post subject: Fuel Pump Issue Reply with quote
rleffler
PostPosted: Mon Oct 21, 2013 3:55 pm    Post subject: Fuel Pump Issue Reply with quote
After shipping the data logs from my two flights and ground testing to Lycoming, they are recommending replacing my fuel pump. Naturally, I am just outside the warranty period.
They recommended a part #62B26931, which I can find that it is an approved substitute for the installed part, which is a LW15473. Anyone know what the difference may be?
Bob Leffler
N410BL - Phase I
Kellym
PostPosted: Mon Oct 21, 2013 6:28 pm    Post subject: Fuel Pump Issue Reply with quote
Looks like Lycoming has approved that part number. Have no idea the
difference. Maybe different vendor?
SL_L255_fuel_pumps.pdf
 Filename:  SL_L255_fuel_pumps.pdf
 Filesize:  41.09 KB
 Downloaded:  700 Time(s)
Kelly McMullen
KCHD
BPA(at)bpaengines.com
PostPosted: Tue Oct 22, 2013 4:37 am    Post subject: Fuel Pump Issue Reply with quote
Lycoming is notorious for part number changes. Any time they change a
vendor they change a P/N. Tempest makes the pump also. Call Justin at
Quality Aircraft Acc.
Allen Barrett
Kellym
PostPosted: Tue Oct 22, 2013 6:13 am    Post subject: Fuel Pump Issue Reply with quote
Seems rather poor customer service to sell an experimental engine, that
they know won't be put into service for many months after the sale, if
not a year or so, to not cover a fuel pump that only has an hour or two
of actual operation.
Allen Barrett
Kelly McMullen
KCHD
rleffler
PostPosted: Tue Oct 22, 2013 6:27 am    Post subject: Fuel Pump Issue Reply with quote
Allen,
Any opinion on the differences between the Lycoming part and the Tempest? The Tempest is $100 less expensive.
Allen Barrett
Bob Leffler
N410BL - Phase I
PostPosted: Tue Oct 22, 2013 6:32 am    Post subject: Fuel Pump Issue Reply with quote
They seem to work just fine in the test cell and I haven't heard of any
field issues.
Allen
Kelly McMullen
PostPosted: Tue Oct 22, 2013 6:35 am    Post subject: Fuel Pump Issue Reply with quote
Your guess is as good as any. Lycomng platinum gold dust sprinkled on the paperwork?
Go with the Tempest and spend the difference on 100LL/
On Tue, Oct 22, 2013 at 7:26 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
[quote] --> RV10-List message posted by: Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)>
Allen,
On Oct 22, 2013, at 8:39 AM, "BPA" <BPA(at)bpaengines.com (BPA(at)bpaengines.com)> wrote:
> --> RV10-List message posted by: "BPA" <BPA(at)bpaengines.com (BPA(at)bpaengines.com)>
> Allen Barrett
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
bwestfall
PostPosted: Tue Oct 22, 2013 8:57 am    Post subject: Fuel Pump Issue Reply with quote
Geez Kelly what do you expect for $45,800... decent customer service? Smile.
-Ben
Kelly McMullen
PostPosted: Tue Oct 22, 2013 8:14 pm    Post subject: Fuel Pump Issue Reply with quote
Well, I'm sure it would drive Lyc into bankruptcy to warrant that $200 pump.
On Tue, Oct 22, 2013 at 9:50 AM, Ben Westfall <rv10(at)sinkrate.com (rv10(at)sinkrate.com)> wrote:
[quote]--> RV10-List message posted by: "Ben Westfall" <rv10(at)sinkrate.com (rv10(at)sinkrate.com)>
-Ben
Kelly McMullen
KCHD
rleffler
PostPosted: Wed Oct 23, 2013 2:12 pm    Post subject: Fuel Pump Issue Reply with quote
Just an update.......
I sent off all the engine monitor data to Lycoming. They think it's the fuel pump. Fortunately, they authorized a warranty repair.
Bob Leffler
N410BL - Phase I
hotwheels
PostPosted: Mon Oct 28, 2013 5:42 am    Post subject: Re: Fuel Pump Issue Reply with quote
I went out on a weekend x-country flight (6 hours) and noticed some strange behavior.
In cruise, my fuel flow readings would occasionally fluctuate between 9.5 and 10.5 gph without me touching anything... At the same time, the fuel psi changed from ~18 (normal) and 14psi. At 14 the engine would stumble. Same behavior on either tank... even after richening the mixture. Turning on the electric fuel pump caused the symptom to go away. No obvious leaks and no fuel smells.
I'm wondering if I too have an issue lurking in the pump department. It's nearly time for my annual, so it's good timing as everything has to come apart anyway.
Jay
N433RV - flying
Goto page 1, 2  Next
Page 1 of 2
