Going through someone else's work on an HDS
LNelson
PostPosted: Mon Oct 14, 2013 7:41 pm    Post subject: Going through someone else's work on an HDS Reply with quote
I am trying to get some information on the location of the aleron horn. I purchased a "90%" complete kit. And the aleron horn contacts splice plate just past the rear zee. Is this the correct location. Also any pics of the cut outs for the ib/ob wing sections would be appreciated.
carlossa52(at)gmail.com
PostPosted: Tue Oct 15, 2013 4:36 am    Post subject: Going through someone else's work on an HDS Reply with quote
Hello
I don't have the plans handy, but here are a couple of 601 websites that can be helpful:
http://mthobby.pcperfect.com/ch601/index.htm
http://www.macsmachine.com/
Good luck
Carlos
CH601-HD, plans
On 14 October 2013 23:41, LNelson <lk.nelson(at)juno.com (lk.nelson(at)juno.com)> wrote:
[quote] --> Zenith601-List message posted by: "LNelson" <lk.nelson(at)juno.com (lk.nelson(at)juno.com)>
jlatimer1(at)cox.net
PostPosted: Tue Oct 15, 2013 6:22 am    Post subject: Going through someone else's work on an HDS Reply with quote
Larry,
I think you are talking about 6-V-7-7. There is a note on the plans that state to "trim then to clear aileron control horn" so that you get the proper travel on the aileron. I've attached 2 photos where you can see that I've removed some metal to allow the spec'ed aileron throw.
Jerry Latimer
 Filesize:  198.66 KB
 Viewed:  4275 Time(s)
 Filesize:  191.79 KB
