Posted: Sun Oct 13, 2013 8:42 pm Post subject: looking for help with "mushy" brakes on CJ |
When is the last time the brake differential and the proportionator been rebuilt?
Doc
On Oct 13, 2013, at 10:02 PM, "keithmckinley" <cetopfed(at)gmail.com> wrote:
My brakes started to feel progressively mushy starting about 50 hours ago. Just checked the drums and they looked fine and the pucks did not show much wear at all (pucks and drums have around 200 hours on them ). I find that I'm pulling the brake handle right up to the stick. I have some room to adjust the cable on the front stick. Is there anything else I should be looking at? Steering is normal, brake handle just doesn't seem crisp.
brakes just barely hold for prop check on run-up.
Keith
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=410469#410469
cd001633(at)mindspring.co Guest
Posted: Sun Oct 13, 2013 9:21 pm Post subject: looking for help with "mushy" brakes on CJ |
Keith,
The braded steel cable stretches over time - this is the reason it is
getting closer and closer to the stick. If not mistaken (I did it a few
years ago), you can shorten the cable by adjusting the retaining nut in
front side of the stick column...
At some point you may want to replace with a braded stainless steel cable.
Sam Sax
keithmckinley
Posted: Mon Oct 14, 2013 4:43 am Post subject: Re: looking for help with |
Hi Sam and Doc,
It is my feeling that the differential and proportioner are in good shape. The cable is no doubt an original Chinese cable that I believe has stretched some. Good news is I do have SS cable from Doug in stock.
I may try the adjustment the retaining nut, but there is not much left on it
Keith
jackpot
Joined: 13 Jul 2010 Posts: 65 Location: Las Vegas, Nevada
Posted: Mon Oct 14, 2013 6:55 am Post subject: looking for help with "mushy" brakes on CJ |
Several years ago I had the same brake problem found the old cable was coming apart inside of the outer covering. Don't mess with adjustment. Install the replacement cable. Or you might get a nasty surprise. Made a new inside cable I think that was before anyone was selling replacement parts. Gary G. CJ. N22YK
| Quote: | On Oct 14, 2013, at 5:43, "keithmckinley" <cetopfed(at)gmail.com> wrote:
Hi Sam and Doc,
Keith
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=410488#410488
Posted: Mon Oct 14, 2013 9:01 am Post subject: looking for help with "mushy" brakes on CJ |
Guy's, cable stretch to the degree that it would effect your brakes is a "wives tale". The cable is not stretching, your swedge might be slipping or the gob/ball of solder (on the stock cable) might be giving way, but the cable is not stretching. I would estimate that 75% of the guys who adjusted their cables because of "stretch" had the cable break soon after the adjustment.
On Mon, Oct 14, 2013 at 5:43 AM, keithmckinley <cetopfed(at)gmail.com (cetopfed(at)gmail.com)> wrote:
[quote]--> Yak-List message posted by: "keithmckinley" <cetopfed(at)gmail.com (cetopfed(at)gmail.com)>
Hi Sam and Doc,
Keith
Keith McKinley
700HS
X26 Sebastian, FL
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Posted: Mon Oct 14, 2013 10:20 am Post subject: looking for help with "mushy" brakes on CJ |
1 - The cable is probably stretched because there isn't much adjustment left
2 - You should remove the wheel assemblies and check for glazed brake
pads. Then check for a broken or missing felt grease seal on hub. It's
the grease seal that fits into the large "cup" behind the rear bearing.
If the felt grease seal is messed up or missing, grease from the rear
bearing will sling outward onto the drum and brake pads causing the
brake pads to glaze. Once glazed, the brakes will feel 'spongy'. Clean
the brake pads with avgas and dry thoroughly. Then scuff the brake pads
up with 60 grit wet/dry sandpaper.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 10/14/2013 7:43 AM, keithmckinley wrote:
Hi Sam and Doc,
Keith
Keith McKinley
700HS
X26 Sebastian, FL
PS
Posted: Mon Oct 14, 2013 10:49 am Post subject: Re: looking for help with |
Keith,
I believe I replaced the proportioning valve in 2006.
Phil
_________________ Phil |
keithmckinley
Posted: Mon Oct 14, 2013 1:33 pm Post subject: Re: looking for help with |
Brakes pads, drums good to go, brand new felt seals. Minor adjustment on the stick at brake handle of maybe an 1/8" and the brake handle feels normal again. I plan on putting the SS cable I have on as soon as I can remember where I put it.
Keith
jackpot
Posted: Tue Oct 15, 2013 4:33 am Post subject: looking for help with "mushy" brakes on CJ |
Guys on my cable the strands of the cable had worn so much inside the outer housing that several of the strands were broken and only one strand was actuating the brakes. A few more applications of the brakes and I would have had no brakes. They were broken inside the housing where you can not see to cable. Don't screw around with it, CHANGE THE CABLE!!!! CJ N22YK. Gary G.
[quote] On Oct 14, 2013, at 9:54, doug sapp <dougsappllc(at)gmail.com> wrote:
jblake207(at)comcast.net Guest
Posted: Tue Oct 15, 2013 9:49 am Post subject: looking for help with "mushy" brakes on CJ |
I would strongly suggest that you replace the old brake cable and housing. It is the single point of failure in the brake system... it fails and you're SOL. My cable broke while I was taxing and I instantly realized that the only option I had, since no one was in the back seat, was to kill the mags and hope for the best. Fortunately, the airplane rolled to a stop a few feet from another airplane. I went to a local motorcycle shop and bought a new cable and housing (I think it was actually a throttle cable for an ATV) that fit perfectly. I now squirt a little oil in it each year and so far no signs of wear or stretch. Much better solution than trying to swag an end to a new cable and then trying to route that through the old housing. Or maybe Doug has the perfect replacement.
Jon Blake
To: yak-list(at)matronics.com
Sent: Monday, October 14, 2013 9:47:53 AM
Subject: Re: Re: looking for help with "mushy" brakes on CJ
--> Yak-List message posted by: Gary Gabbard <ggg6(at)att.net>
--> Yak-List message posted by: "keithmckinley" <cetopfed(at)gmail.com>
Hi Sam and Doc,
Keith
Keith McKinley
700HS
X26 Sebastian, FL
Pete Fowler
Posted: Mon Oct 21, 2013 4:32 pm Post subject: Re: looking for help with |
I had mushy feeling brakes. The cable inspected fine but was at the end of its adjustment. As a rule, I always brief the GIB about using the brakes and have them hold the plane with the brakes when I'm pulling the prop through.
I was taxiing down-hill at Catalina (which has a several hundred foot cliff with no barriers at the end of the taxiway I was on when the cable failed. Had I been alone, I would have gone for the dirt off the taxiway but I thought to tell the GIB briskly "GRAB THE BRAKES".
As mentioned, the solder and cable had failed underneath the wire wrap so there were no visual signs that it was failing other than that "mushy" feeling.
I replaced both cables with full aircraft quality cable and swages. No bicycle parts for my plane. Grabbing a non-brake heading towards a cliff should be a once-in-a-lifetime bit of excitement.
87.73 KB |
11594 Time(s) |
jonboede(at)hotmail.com Guest
Posted: Mon Oct 21, 2013 7:11 pm Post subject: looking for help with "mushy" brakes on CJ |
I had mushy brakes in my CJ as a result of a sudden increase in mushiness... immediately got a new cable from Doug. These things are signs of things to come.
Amazing how much rust was in the old tube... much better control with the new one and it took hardly any time to replace it.
| Quote: | Subject: Yak-List: Re: looking for help with "mushy" brakes on CJ
Date: Mon, 21 Oct 2013 17:32:43 -0700
--> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net>
http://forums.matronics.com/viewtopic.php?p=411043#411043
http://forums.matronics.com//files/brake_cable_912.jpg
keithmckinley
Posted: Wed Oct 23, 2013 7:53 pm Post subject: Re: looking for help with |
Pete,
WOW! thanks for sharing and the great pics!
Keith
